Pro comp wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by TaCoJoE650, Dec 9, 2017.
  1. Dec 9, 2017 at 9:00 PM
    TaCoJoE650
    TaCoJoE650 [OP] Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Will pro comps series 51 15x8 wheels fit without adding spacers or rubbing on calipers?
    jtanner21 likes this.
  2. Dec 9, 2017 at 10:18 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Not sure what the specs are on the wheels you listed but I had pro comp 7069's 15x8 that fit my 03. They were 3.5" BS, -19mm offset.
    Edit - just saw that the wheels you are talking about are steel, not aluminum. So in that case, I have no idea. Some 15" steelies fit, some don't from what I hear.
  3. Dec 10, 2017 at 8:33 PM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
  4. Dec 10, 2017 at 9:04 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Pro comp series 51 16x8 w/4" b.s. did not fit my 2004 4x4 xtra cab. They rubbed on the caliper. Ended up with pro comp series 98 rockcrawler wheels. The ones I have now are 3.75 b.s. Part number also had a "T" designating Toyota as opposed to GM 6 lug.
    YMMV
  5. Dec 14, 2017 at 5:18 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I did a search on Pro Comp's website and they don't even make a wheel that fits my truck.
  6. Dec 14, 2017 at 11:39 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Well that's a stockpile of crap, cause they sure do.
  7. Dec 15, 2017 at 11:21 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Pro-Comp absolutely makes wheels that fit Tacomas.
    I'm actually debating between a set of Pro-comp aluminum or a set of US Wheel steel for my truck now.
    Pro-comp makes steel wheels that will fit though. I just like the look of the US Wheel steel better... they are powder coat gray.
  8. Dec 15, 2017 at 11:41 AM
    jtanner21
    jtanner21 Well known scammer
    2004 Tacoma 3.4l Extra Cab
    They will rub, I have pro comp 15x8 Steels and ran a .75 hubcentric spacer from Bora. Fit just fine :)
  9. Dec 15, 2017 at 3:40 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    No Tundy brakes for you then :boink:
    jtanner21[QUOTED] likes this.
  10. Dec 15, 2017 at 3:51 PM
    jtanner21
    Ehh, I can live without em. Power stops do just fine. More money for LT parts :rolleyes:
  11. Dec 15, 2017 at 6:10 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Screw LT. how are you going to road trip a squeaky bouncy rig? haha
    But seriously, I'm hoping the 16" pro comps fit tundra brakes. I will update once I get around to it. Which is when these pads wear out. So a long time since I don't DD. +1 for engine braking :rolleyes:
  12. Dec 16, 2017 at 9:38 AM
    TaCoJoE650
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
    Yota came with 17's and low pro tires like 35 :annoyed:
    I swapped a set of jeep rims I had laying around for now but want to get an all black 15.
    What offset/B.S Should I be looking at with no issues?
  13. Dec 16, 2017 at 2:09 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Depends on tire size. 4.5" bs on a 7" wide wheel is stock, so that will work with ~265mm tire width. If you want ~285mm width, look into 4" bs. 305s will probably need 3.5" bs to not rub frame. This is on an 8" wide wheel.
    But you said 17" wheels. So then width sizes will be in inches. 10.5", 11.5", and 12.5 or there abouts.
