Price of a Used 1GR-FE Engine, Rebuildable?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billygoat, May 30, 2022.
  1. May 30, 2022 at 11:16 AM
    billygoat
    billygoat [OP] Well-Known Member
    American Southwest
    08 TRD Offroad 4x4
    6” Fabtech Lift, 35’s, lots o’ goodies
    What is a used 2006 200k mile running 1GR-FE with rod knock worth? I picked one up for free thinking I could rebuild it when/if mine ever bites the dust, or just sell it and buy some new tires. I’m reading the blocks can’t be bored or resleeved but don’t usually need to be anyway. Does this sound right?
  2. May 30, 2022 at 11:25 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    billygoat[OP] and TnShooter like this.
  3. May 30, 2022 at 12:11 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    Dm93[QUOTED] likes this.
  4. May 31, 2022 at 9:59 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    With a good machine shop they can put sleeves in. It will be on the pricey side. I think a rough quote was $1200ish. They have to bore out the old liner and machine in a recess for the flange on the liner.
    If you need to go over on the bore max is .040" put that is cutting it close.
    The crank l, if it needs to be machined under that is a common practice and there are bearing out there for it, just not factory. The crank is forged too.
    Price wise on the rebuild, I did add mine up. Still scared to know.
    I did splurge on a lot of upgrades though.
    TodayWasTHeDaY, BassAckwards and Dm93 like this.
  5. May 31, 2022 at 12:52 PM
    TacoTuesday1
    FL
    If it’s got rod knock you might get away with being able to just replace the bearings
    There should be specifications on how to check clearance with new parts to make sure it’s good. Using tools like plastigauge. Dial indicator. Etc
    you won’t know what’s messed up inside until you tear it apart and look.
    You can buy a cheap engine stand from harbor freight and get started.
    to keep track of which part goes where if you disassemble it and then walk away for a while forgetting, you can do things like paint mark. Label. Bag or boxes. Cardboard. Stuff on shelves.
    Which shouldn’t be much because this simple old engine with no power stock probably has 3 moving parts
  6. May 31, 2022 at 12:58 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I had a blow head gasket 4.0 engine. Post it on Craigslist for $500.
  7. May 31, 2022 at 1:50 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    I replaced the head gaskets on my 4.0 about 5 years ago and man, there’s a lot more than 3 parts in this SOB :rofl:. I’ve rebuilt more old cast iron Jeep engines than I can shake a stick at but if I open a 1GR-FE I’m setting aside a full week followed by a therapy session. I’m either doing a full rebuild so I never have to touch it again or nothing at all.
    69 Jim, Weissenheimer, henryp and 2 others like this.
  8. May 31, 2022 at 2:27 PM
    pahaf
    paul
    NorCal
    Lol that bad? What was the worst thing for you? Just curious.
  9. May 31, 2022 at 3:00 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    Doing it outside in December after work in the dark in a snowstorm was the worst part lol. It was like 10F outside. It’s a fairly complicated motor though, especially compared to a pushrod motor. 4 camshafts, one big timing chain, oil pressure driven valve timing, and lots of small parts. I don’t usually use manuals but I followed the FSM step by step for that.
    Weissenheimer and SR-71A like this.
  10. May 31, 2022 at 3:24 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    OP, I'm curious why you think it has "rod knock" - which is such excessive rod bearing clearance that you can hear the rod journals banging at TDC and BDC. It's a very unusual condition, even more so on modern engines like ours.
    If you don't know, then just mic the crank journals and rod big ends and let us know what you find.
    Dm93 likes this.
  11. May 31, 2022 at 4:22 PM
    billygoat
    American Southwest
    08 TRD Offroad 4x4
    It was a free engine on Craigslist. The guy said it had rod knock and instead of rebuilding it he replaced it.
    I was kinda wondering if something else was wrong too tbh. On one hand I don’t want to mess with it right now, but on the other I want to tear it open to see its condition. The only likely reasons I could think of for it to get rod knock at 200k is if he didn’t change the oil or it spun a bearing…but I think he swapped the engine himself so he’s probably changing the oil regularly? I don’t know, I’m just excited to have a spare engine to go with my spare axles and transfer case. Now all I need is a spare 6spd transmission!
    Dm93 likes this.
  12. May 31, 2022 at 4:52 PM
    Fullboogie
    Dave
    Houston
    No knock against you - so you don't know anything about the engine or whether it has "rod knock." Get a set of inside and outside mics, do some due diligence, and let us know what you find. Otherwise this is all all an exercise in "what if."
    goforbroke123 and Dm93 like this.
  13. May 31, 2022 at 7:30 PM
    Waasheem
    Waasheem
    2007 xrunner
    A suggestion. If you decide to not tear into it, donate it to your local high schools auto shop class.
    whatstcp likes this.
  14. May 31, 2022 at 7:47 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Do they still have auto shop class?? One local school shut down their industrial arts programs 20+ years ago.
    (too dangerous for modern children probably :rant:)
    OP: Get a Harbor Freight engine stand, don't disassemble the engine -- instead do some easy low cost assessment, pull the base pan and Plastigauge the bearings, inspect the crank, if they pass pull the rocker covers and have a look there.
  15. Oct 22, 2022 at 12:59 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Any updates OP
  16. Oct 23, 2022 at 6:00 AM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    I graduated in 2011. We had auto mechanics, welding, carpentry, all kinds of stuff. There was an entire separate facility dedicated for it.
    ToyoTaco25 and Reggie4x4 like this.
  17. Oct 25, 2022 at 5:30 AM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Dude a used FREE motor from Craigslist is going to have more problems than what he told you.
  18. Apr 21, 2025 at 9:35 AM
    cookoff013
    cookoff013 New Member
    I’ve sold a couple engines with rod knock over the years—last 1GRFE I let go with a knock went for $300. As long as it’s not cracked or hydrolocked, someone always wants a rebuild project. A 1GRFE Engine For Sale that’s rebuildable is gold to the right buyer.
