Presto's full part out 97 3rz (tophers build)
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by presto, Aug 5, 2015.
  1. Aug 5, 2015 at 2:30 PM
    presto
    presto [OP] Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    8/1/15 got a bad misfire, checked compression and it's done..
    Everything must go!!
    Prices are negotiable! Need to sell this stuff within a month or two (open to combo deals!)
    Will send lots of pics + detailed description of any damage/wear before sale.
    Some stuff will be local pick up only (Half moon bay, CA) all shipping is @ buyer expense. This isn't on Craigs yet, TW gets first dibs.
    1997 ext cab 2.7L 4x4 auto (8port intake)
    Things that will be for sale:
    (Nothing includes shipping $)
    Reserved
    -2x CVJs reserved for @TashcomerTexas )
    125$(both)
    -steering rack, OTRs, LBJs reserved for @quetzal
    180$
    -coilovers reserved for @MattJakobs
    560$ (shipped)
    -CBI brackets reserved for @wildfyr3
    25$
    -UCAs reserved (maybe) for @rjsimz
    500$
    -cb radio setup reserved for @Jayjayb96
    80$
    -trail gear leds, led pods(x3), redline oil + filter, BAMF BPV reserved for @jsway9
    70$
    Armor
    -front bumper(all pro Baja style) includes custom fit skid plate from @isu2014
    450$
    -BAMF 80" kick up sliders (custom fit to bolt onto 95-97, should be able to weld onto any 1st gen ext cab.. Beat the BAMF wait time!!)
    350$
    -CBI outback 1.0 rear bumper (sides were custom length to fit bed bob, could cut them off, mounts were also custom fit for bed bob. Might have to extend the mounts or cut your bed a little.)
    400$
    Suspension/axles
    -10" travel 2.0 resi Kings(1.5"x.5" bushings) minor wear and tear, will send detailed pics
    400$
    -rear Dakar leafs w/ OME shackles, 3degree toytec shims, & timbren bump stops (must drill out leafs, drill bit included) (95-97 ONLY! Includes OME bushings 30k)
    320$
    -7.5" front diff/clamshell w/ 5.29 gears (built diff from ECGS, includes ECGS bushing, has less than 500 miles on it)
    250$
    -8.4" rear axle (whole axle assembly) w/ ARB locker+all parts needed including compressor, 5.29 gears, solid spacer, trail gear diff guard welded on, and BAMF shock relocation. (has under 8k miles, built from ECGS, no metal chunks/shavings in gear oil)
    1350$ (Both diffs = 1400$)
    -front and rear drive lines
    30$/ea (50$ for both)
    -relentless u bolt flip kit w/ powder coat (7k miles)
    50$
    Steering/wheels
    -OEM rims w/ 33x12.5x15 General grabbers (10k tires basically brand new, rims painted black, lug nuts come with)
    650$
    Engine/exhaust
    -brand new autozone reman engine (upper & lower) 0 miles never installed (hopefully getting this from warranty 3k+ brand new)
    2000$
    -a340F transmission + j shift Tcase (automatic 2.7L 182k)
    150$transmission 150$tcase
    250$both
    -AFE drop in filter used offroad once (6k)
    20$
    -new radiator + hoses from Autozone (15k front was sprayed painted black)
    50$
    -reman aternator from autozone (15k)
    40$
    -borla muffler magnaflow cat (both weld in 15k)
    50$
    -gas tank & pump
    50$
    -04 exhaust manifold painted w/ black grill paint (9k needs new studs)
    50$
    -ngk spark plug wires for the coil style 2.7 (9k)
    10$
    -4x brand new (in box) denso/OEM spark plugs
    5$
    Exterior
    -OEM passenger side fender (antenna hole needs to be fixed, fender was tubbed a little)
    10$
    -cab (includes doors needs new paint/windshield/radiator support)
    500$ (With all interior + seats 650$) (doors = 200$/ea)
    -OEM passenger mirror
    10$
    -fuel door + lock (locks been rebuilt once and has back plastic piece glued on..)
    10$
    -60/40 blueish/grey seats(driver side is ripped)
    50$
    Misc
    -spare tire cross member
    10$
    -31x10 spare w/ steel rim
    15$
    -ARB tire inflation kit + blue ARB filler gauge brand new
    50$
    -linerextreeme kit comes with 3 gallons + spray gun + rubber material.. I paid over 200. (Cannot ship hazardous items)
    150$
    -any and all interior/exterior including but not limited to:
    intake manifold/plenum/throttle body/injectors/air box/cruise control/calipers/4x4 spindles/gas tank /brake booster/ps pump/water pump/valve cover(182k)
    Junk/free (local pick up or add-on only)
    -driver side fender (non OEM cut/dents)
    -grille(broken tabs/cut out center)
    -hood(non OEM/dents)
    -bed (has 13" bed Bob)
    -LCAs (pretty rusted out)
    -ps pump resivoir (leaks and has silicone on it)
  2. Aug 5, 2015 at 4:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  3. Aug 5, 2015 at 4:10 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC King Ranch Edition
    Dibs on CVs
  4. Aug 5, 2015 at 4:50 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    X2.. Although if I end up finding a nice low mile v6 Tacoma id be pretty stoaked
    Dibs granted.
  5. Aug 9, 2015 at 7:31 AM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    Do the lower control arms come with the cam bolts? Will you ship on my dime?
    Do you have the factory bumpstops for the rear?
    Do you have the factory u-bolts for the leafsprings?
  6. Aug 9, 2015 at 12:09 PM
    grrillA
    grrillA Well-Known Member
    Long Beach, CA
    '99 3.4L 4x4
    2nd in line for CV's
  7. Aug 9, 2015 at 12:39 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    i was going to make the LCAs local pick up only because I was giving them away, I was also going to sell the cam bolts seperate for 15$. If you want to buy the cam bolts I would ship you the LCAs and cam bolts if you want both (shipping on your dime)
    I only have extended length u bolts from toytec that came with my Dakar leafs (5$, have to check for all nuts/washers), no factory bumpstops.
    Copy that.
    truck will start getting dismantled on Wednesday.
  8. Aug 9, 2015 at 2:31 PM
    xcmtb83
    Iowa
    OK, I am waiting to hear back from the local yard in regards to LCA and cam bolts. I will know more on Monday. What is the distance from the bottom of the U that contacts the spring to where the threads start? As long as there are enough threads I can always trim them to length. I could also run a die down them to get more threads but I would rather not. Thanks!
  9. Aug 10, 2015 at 9:31 AM
    xcmtb83
    Iowa
    Have you ever had the cam bolts out? I am wondering if they are siezed like mine were.
  10. Aug 10, 2015 at 9:36 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Rare axle? E-locker?
  11. Aug 10, 2015 at 9:45 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    It's non e locker (8.4") but it has an ARB air locker in it. Also has/includes trail gear diff skid welded on, 5.29 gears, ARB cksa12 & all wiring/air line/switches.
    Still kind of up in the air about the rear/front diffs, but I put a price @ 1700$ for the rear (entire diff) & 400$ for the front diff.
    might be hard to ship..
  12. Aug 11, 2015 at 1:58 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Not up in the air about the axles anymore, they gotta go. More stuff from the not for sale list will probably be making it on the list too, so claim what you want now.
    Today I found out I can't get another Tacoma, the bank won't do a loan for a vehicle pre 2005 or over 100k miles. A 1st gen Tacoma will be in my future someday but not soon. (Unless I win the lotto :anonymous::fingerscrossed:) I think I'm going to get an scion FRS or a Subaru BRZ.
  13. Aug 11, 2015 at 2:10 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well that's shitty! if it were a DC I would of bought the cab for sure!
    Fernando, bayareataco and presto[OP] like this.
  14. Aug 11, 2015 at 2:20 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Interested in:
    It would help to know if the Rack DR would honor the life time warranty, didn't you just buy it from them a little while ago?
    Thanks.
  15. Aug 11, 2015 at 2:42 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Yea, it sucks! at least now I'll have a legit DD now and when I get a Tacoma it can be garaged! Lol..
    Good question, I'm not sure about the warranty transferring over. I just purchased it on 5/22/15, received a week and a half later.
    When I take this stuff off I will send/post individual pictures of the items and any defects I see.
  16. Aug 11, 2015 at 2:48 PM
    quetzal
    Mario
    Long Beach, CA
    Ok, I sent them an email asking them about it. Either way, please put me down on the list. Thanks and I'm sorry this is happening to you.
  17. Aug 11, 2015 at 3:00 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Ok sounds good, thanks for asking them for me. Will do! Figure it will be for the best in the end, I always wanted the 6cyl model anyways haha..
    quetzal[QUOTED] likes this.
  18. Aug 14, 2015 at 9:03 PM
    Madjik_Man
    Colorado Front Range
    Are you parting out any interior pieces?
    I'm looking for the A/C push button switch.
    PM'd
  19. Aug 14, 2015 at 9:39 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Pm replied, pulled some stuff off tonight and will take some pics.
  20. Aug 14, 2015 at 10:27 PM
    Murdered Out Tacoma
    Murdered Out Tacoma NightRunner
    Socal (IE)
    Black 06 DCLB Sport
    Tricked out dents on the outside and custom love stains on the inside. To many citiations to count, but one hell of a sweet ride.
    Deng, I'm kinda interested the whole rear axle assembly. If we can confirm it'll fit on my '06 Prerunner Sport. I know it has the 8.4'' dif lsd w/o locker. Maybe it'll fit, kinda, sorta....who knows?
