Pressure Washer Recomendations
Discussion in 'Detailing' started by Captains1911, Jun 18, 2023.
  1. Jun 18, 2023 at 6:14 PM
    jsi
    jsi Well-Known Member
    native earthling
    Watching the Karcher video on Amazon it looks like it comes with a medium tip for car washing, a rotary tip for concrete, and an adjustable tip for everything else. I have a rotary tip for my Sun Joe that I use a lot for cleaning concrete
    https://www.amazon.com/AURORA-CAR-P...x=pressure+sprayer+tip,lawngarden,128&sr=1-16
    For car washing I use the 25, 40 and rotary the most. I might get out the 15 if the bug splats are really bad. And, I almost never use the 0 for anything. The spray is too concentrated and will strip the paint off your house or leave marks on the concrete.
    I got mine in 3 years ago and share it with my brother in law. We both use it a lot in the spring cleaning up the mess left by winter. We'll use it to wash our cars too, but if my truck is muddy I take it to the car wash and leave mud with them and not in my driveway.
  2. Jun 18, 2023 at 6:33 PM
    4Stents
    4Stents Roost or be Roosted
    Appleton Wisconsin
    2013 White Tacoma SR5 , w/peeling paint.
    Frame recall done
    Yamaha
  3. Jun 18, 2023 at 6:57 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    My apologies it’s a 2700psi unit. It’s a Lowe’s exclusive. It’s not on their website.
    soggyBottom[QUOTED] likes this.
  4. Jun 19, 2023 at 7:17 AM
    Captains1911
    Captains1911 [OP] Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
  5. Jun 19, 2023 at 7:54 AM
    Firn
    Firn Well-Known Member
    White OR
    Do yourself a favor and get a surface cleaner rated for your washer.
    Such as I cannot tell if the pressure washer you linked uses the "Pressure washer association" standard connector, if so it should be easy to find other attachments.
    Edit: From the looks of it yours does not use a standard fitting. You will need to get sunjoe attachments then and the surface cleaner linked above won't work for you
  6. Jun 19, 2023 at 8:10 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    [​IMG] Looks like OP has made a choice. FWIW; usually I rent a nice Commercial unit from the local rental joint one weekend a year ($100 ish). Run it 2-3 days straight with the house, fence, deck etc. it’s a daunting task, and gets put off a lot.
    Don’t want another large and $ gas machine at the house and figured a good electric unit would allow me flexibility to break it down into separate sessions as time permitted.
    ~$225 I picked up the top electric unit at Horror Freight. I’d say it’s good enough, all in not as efficient as a 5HP gas unit for sure in terms of power. But getting the job done; just takes more time. (I’ll also be able to store it in basement and share with Family)
  7. Jun 19, 2023 at 8:17 AM
    MGMDesertTaco
    For car washing you don't need a ton of psi. I use a Kranzle 1322TS from obsessed garage and keep an older gas 3100psi Honda pressure washer for heavy duty tasks like driveway/patio cleaning.
    Obsessed Garage has an active 2.0 that's around $350 with stellar reviews. You can upgrade the hose and accessories from MTM Hydro later on.
    https://www.obsessedgarage.com/products/active-2-0-pressure-washer
    https://www.mtmhydroparts.com/
    Send that joeblow back for the active 2.0 imo.
  8. Jun 19, 2023 at 11:11 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This. This. This. I've had a couple of the standard homeowner, box store pressure washers and started using a foam cannon. It was an improvement to regular hose washing but still not a great experience. When my pressure washer crapped out I ponied up the $$ for the Active 2.0 pressure washer and upgraded accessories.
    I'm blown away at the difference between this setup and what I had before. A better pressure washer, properly setup with the right orifices and accessories makes a difference I just couldn't imagine before using it. This is one of those things that you have to use it to believe it. I should have done this years ago. Now combined with a deionized water setup I've cut my car washing time at least in half. Time is money.
    MGMDesertTaco[QUOTED] likes this.
  9. Jun 19, 2023 at 11:23 AM
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
  10. Jun 19, 2023 at 1:39 PM
    MGMDesertTaco
    Yeah, a deionized tank helps a ton. I'm using this DI Rinse Pro 100, but any size tank and the rest of the components can be sourced separately for cheaper.
    https://dirinse.com/product/d-i-rinse-pro-100-system/
    grissom likes this.
  11. Jun 19, 2023 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Rocketball likes this.
  12. Jun 19, 2023 at 1:47 PM
    landaemon
    landaemon Well-Known Member
    Dan
    Central PA
    2023 TRD OR DCLB
    I went down the pressure washer research rabbit hole a couple months ago and finally decided on the AR Blue Clean BC390HSS (https://www.amazon.com/dp/B08HQXLX5J) for small jobs around the house and eventually for use with a foam cannon on the vehicles. I was worried about the quality as it's a name that wasn't known to me, but it seems to be built well and it performs about as well or better than the older gas-powered Craftsman unit I had a few years ago.
  13. Jun 19, 2023 at 1:57 PM
    clenkeit
    Colin
    Lakewood, CA
    I bought essentially the same thing from another source. Similar pricing by my place may have been a little cheaper but hard to tell without looking at all the specific add ons and such. Either way, great setup. I've only used it a couple times and it's been great, now just need to do a more "permanent" install of the tank.
    https://www.servapure.com/WashPak-1...Serv-A-Pure-835-DI-Tank-10-Cu-Ft_p_12474.html
    We have pretty darn hard water so the big question is how long it's gonna last before I have to buy expensive replacement resin. Even if it only lasts a year it'll be well worth the time and headaches it saves me.
  14. Jun 19, 2023 at 2:09 PM
    MGMDesertTaco
    I get about a year on the resin, but I have a whole house water purification system and an Aquasure whole house 48k grain softener with an extra in line carbon and sediment filter. (Also have R.O. in the kitchen.)
    For whatever reason the last two times I've ordered replacement resin from Di Rinse they've shipped me 2 bags in separate shipments even though I only paid for one. :cookiemonster:
    clenkeit likes this.
  15. Jun 20, 2023 at 7:25 AM
    #35
    clenkeit
    Colin
    Lakewood, CA
    No other filtration here at our place, although we are planning to get a soft water system at some point - unfortunately it will probably need to wait until we do a full repiping :(
