Pressure Washer Recomendations
Discussion in 'Detailing' started by Captains1911, Jun 18, 2023.
  1. Jun 18, 2023 at 6:04 AM
    Captains1911
    Captains1911 [OP] Well-Known Member
    2023 Tacoma TRD OR 4x4 AT DCSB
    I’m looking for a decent a pressure washer to use primarily for cleaning my truck, and whatever other tasks around the home I may find a use for. I’m having my truck ceramic coated in a few weeks, and am hoping that I can just pressure wash it for quick cleanings as needed. I honesty know very little about these tools, so just looking for some recommendations based on stated use. I’m not sure what max pressure, nozzle attachments, etc. work best for this application. Thanks for the help.
  2. Jun 18, 2023 at 6:29 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    A karcher electric pressure washer 1800 -2000 psi the one with the adjustable end on the gun and wheels. For a car or truck this is way more than enough. You don’t want to have too much pressure like a commercial washer produces. You can do damage.
    Also side note when you use it don’t go to close to the paint with the stream and your all good
    jsi and Rocketball like this.
  3. Jun 18, 2023 at 6:31 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    IMG_2560.jpg I’m too nervous about pressure washers and car paint. I use a good nozzle and a chemical bros foam cannon.
    oneikr likes this.
  4. Jun 18, 2023 at 6:33 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Karcher electric models get a lot of great reviews in the detailing forums I belong to. Sun Joe is also a good choice, but at a low price.
    jrallan26 likes this.
  5. Jun 18, 2023 at 6:33 AM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    To do your truck you really need minimal pressure and one of the smaller electric ones will run a foam gun and spray off dirt just fine. Now for around the house a more powerful gas powered machine will do a much better job.
    I have a Ryobi from HD running 2600 PSI and has a basically bullet proof Honda engine motor on it. 2600 PSI is way more than necessary for truck purposes and as a matter of fact used carelessly that power will easily do damage. Just make sure you ONLY use the white tip on your truck if you go that route and keep it reasonably away from the truck when spraying it. The white tip has the widest pattern and spreads the pressure out the most.
  6. Jun 18, 2023 at 6:38 AM
    Captains1911
    I don’t have any interest in taking the time to wash it myself by hand. My plan is to pressure wash myself and then run through the touchless wash. Hopefully with the ceramic coating this will be sufficient for my needs. I live on a dirt road so getting it spotless is pointless.
    hooliganrick likes this.
  7. Jun 18, 2023 at 6:43 AM
    Captains1911
    Which specific Karcher electric model would you guys recommend? My limited research suggests I want both 25 and 40-degree nozzle options. Also, hoping to keep it under $200.
  8. Jun 18, 2023 at 6:50 AM
    TruckGuy63
    Gilbert
    New York
    I have the K3 style and it works great. I use it to clean concrete , my deck when I want to re stain , areas on my house , and such. It hooks up to a hose , plug in and good to go. Just again DO NOT bring the stream too close too the paint or the gaps by the wheel flairs. Underbody you can go closer in areas and you’ll be fine. Also it’s fairly quiet and very convenient. I use it all the time for lots of stuff
  9. Jun 18, 2023 at 6:56 AM
    Captains1911
    Is it one of these two models?
    https://www.amazon.com/Karcher-Cont...lectric+pressure+washer&qid=1687096425&sr=8-3
    https://www.amazon.com/Karcher-Foll...washer&qid=1687096585&sprefix=,aps,336&sr=8-5
  10. Jun 18, 2023 at 6:59 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    Love mine, use it with a foam cannon and Chemical Guys foaming wash. Also more than adequate for my deck, walkways, etc.
  11. Jun 18, 2023 at 7:02 AM
    TruckGuy63
    Gilbert
    New York
    I have the first one but either is good
    The one I have tucks away for me when I put away. I love it.
    Also one more major note with any pressure washer ALWAYS connect the water and make sure water is going in BEFORE you turn it on. Same for turning off
    Turn power off then shut water. If you do that all the time it will last for a very long time .
  12. Jun 18, 2023 at 7:05 AM
    Captains1911
    How do you set the spray angle with this one? I can’t tell from the description. Thanks.
  13. Jun 18, 2023 at 7:14 AM
    avi8or_co
    Spray angle is adjusted by the tip you put on the end of the gun
  14. Jun 18, 2023 at 7:37 AM
    jsi
    jsi Well-Known Member
    native earthling
    I bought this one when my gas powered sprayed took a dump.
    https://www.amazon.com/gp/product/B00CPGMUXW?ie=UTF8
    With a gas washer you have to keep spraying or it will over heat. And sometimes if it doesn't catch on the first pull it can be a pita to get running. An electric washer shuts off when you don't need it which is SUPER handy. Having had both gas and electric sprayers I'll never do gas again. The linked sprayer is more than enough to do anything I'll ever do around the house. I think most sprayers come with different tips and that is something you will want. The one downside on my sprayer is the big chonkin GFCI plug at the end doesn't play nice with my weatherproof outside plugs. I just plug it into an extension cord and all is good.
    Firn likes this.
  15. Jun 18, 2023 at 10:30 AM
    Captains1911
    I understand, but does it come with those tips (several for different angles) or do you have to buy them separately?
    The Sun Joe model linked above shows it coming with several different tips to control the angle. I don’t see that with the Karcher. Just trying to understand.
  16. Jun 18, 2023 at 12:07 PM
    TruckGuy63
    Gilbert
    New York
    Karcher is a known brand and has good stuff but what ever your comfortable with .I personally never needed anything more and I use it all the time
  17. Jun 18, 2023 at 12:10 PM
    TacomaWorld2023
    TacomaWorld2023 Well-Known Member
  18. Jun 18, 2023 at 12:24 PM
    soggyBottom
    soggyBottom Well-Known Member
    You don't really need much for washing your truck. I would say that 2000psi is way overkill and can ruin bearings if sprayed directly.
    I used to own a Ryobi one that I think was $80 new. It had more than enough power to wash a car. I had it for a couple years and sold it when I moved.
    I've had mixed experiences with Ryobi. I have a sawzall that has lasted me a long time so far but many other things break too quickly. DeWalt makes a small electric one that runs about $250.
  19. Jun 18, 2023 at 3:50 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I have a Greenworks 2800psi. Zero issues after 5 years. Runs a foam cannon great. Just use the 40 degree tip and you’re fine. I always use a foam cannon and hand wash, just use the pressure washer for initial wetting and rinsing. Also get a 50ft hose you’ll be glad you did.
    ToyoTaco25 and soggyBottom like this.
  20. Jun 18, 2023 at 3:55 PM
    soggyBottom
    I can't find a 2800psi model. Can you post a link?
