Pressure washer and foam cannon
Discussion in 'Detailing' started by ppham444, Dec 24, 2012.
  1. Apr 13, 2018 at 12:05 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    The point of the cannon is provide more soap/lubricity to help reduce swirls.
    PackCon likes this.
  2. Apr 13, 2018 at 7:13 PM
    gorram
    gorram Well-Known Member
    2016 Limited
    I meant if you're using the foam cannon and a soap bucket with the 2 bucket method.
    But then you get swirls from particles in the mitt/towels, when you're spraying off dirt with a pressure washer, when you're drying with towels....
    Was only making the point that the foam cannon is neat and all, as is the two bucket method and grit guards. You can probably wash a vehicle with much less fuss and still result in the same amount of swirls.
    But to each his own, particularly when talking about a $20-40,000 Toyota painted truck.
  3. Apr 14, 2018 at 1:41 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I used mine last night. It works amazing!
    It took 30 seconds to coat the entire truck. Crazy how much foam is created.
    Mitt scrubbed then pressure wash rinse.
    My 15 year old paint turned out just fine.
    scottalot likes this.
  4. Apr 14, 2018 at 2:22 AM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Didn't achieve the same thing for me.
    Didn't produce the volume of foam and then afterwards the washing power was insufficient.
    With the pressure washer/foam cannon you can loosen up the surface debris and get it off and then have a nice surface to hand wash.
  5. Apr 14, 2018 at 4:00 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Washing your vehicle will always result in some type of paint damage, which is why you only wash your truck when you have to.
    I don’t get your point. Washing your truck damages your paint so therefore all washing methods are a waste?
    Foam cannons, the two bucket method and drying with a blower are the most paint safe ways to wash a vehicle.
  6. Apr 14, 2018 at 4:47 AM
    gorram
    2016 Limited
    All I'm saying is I think it's a bit overrated in it's usefulness as a presoak step when you're going to turn around and wash with two buckets. Sure every little bit of techniques helps, you're not wrong on any of your points (blow drying for example).
    I find that the pressure washer alone does most of the cleaning work than the foam cannon if the vehicle is very dirty.
    I'm finding I prefer a rinseless wash with Uber anyway since I tend to keep the truck clean.
  7. Apr 15, 2018 at 7:44 AM
    Stripedbass
    Stripedbass Well-Known Member
    2015 double cab
    I just ordered a foam cannon. when using it
    Do you spray it down then let it sit or sponge it with the foam.
  8. Apr 15, 2018 at 7:59 AM
    tonyinsight2
    tonyinsight2 Well-Known Member
    i honestly dont see the benefit of doing this, besides looking cool
  9. Apr 15, 2018 at 8:03 AM
    koditten
    Kirk
    Central Michigan
    I only used mine for the 1st time 2 days ago.
    I foamed the shit out of the truck then deck scrub brushed the (think car wash foaming brush) truck right away. 6 minutes later the whole truck was scrubbed.
    Pressure washer rinsed the truck then used compressed air to blow the water off.
    It turned out great.
    I'm sure you pro's watching the thread are cringing at my use of the soft deck brush. This method has been my wash routine for years. It works fine for me.
    In addition, I used Dawn dish soap. I thinned the soap by filling the soap bottle 1/2 full of water then topped it off with soap. It only took the bottle down to the 2/3 mark.
    I figure that really aught to really work you up:)
  10. Apr 15, 2018 at 9:04 AM
    ace96
    Western KY
    :puke:
  11. Apr 15, 2018 at 10:40 AM
    PackCon
    Connor
    Apparently this requires clarification in this thread. FOAM CANNONS DO NOT CLEAN. They serve the purpose to increase lubricity in the surface of the truck so that when you use the two bucket method you are reducing the chances of swirls as much as you can.
    So if you let the truck sit so long with the foam you lose all of it before cleaning... you defeat the purpose of the foam cannon.
    Also, letting the foam sit really isn't going to help you with cleaning. Outside of having a mud caked truck, letting moisture sit on the truck doesn't make it any easier to clean.
    I go right into washing after blasting with the foam cannon. The only exception might be if my front end if caked with bugs. Then I just make that the last part I hit with my wash mitt (which you should hit the dirties parts of the car last anyways).
    Not everyone cares about their vehicles. If you don't care about scratching the heck out of your truck, that's your prerogative.
    ace96 and koditten[QUOTED] like this.
  12. Apr 15, 2018 at 11:20 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Your choice. But I wouldn't use dish soap personally
    ace96 and PackCon like this.
  13. Apr 15, 2018 at 12:29 PM
    koditten
    Kirk
    Central Michigan
    Then don't.
  14. Apr 15, 2018 at 12:30 PM
    ace96
    Western KY
    I see nothing wrong with using a harsh soap on paint. It has a great drying effect on plastic too. :rolleyes:
    PackCon likes this.
  15. Apr 15, 2018 at 2:01 PM
    #35
    ABA180
    East Bridgewater MA
    Plus it's great to use a soap that cuts oil on paint .
  16. Apr 24, 2018 at 6:32 PM
    #36
    noahf
    noahf Well-Known Member
    noah
    2003 Silver Tacoma TRD
    Air Freshner
    if your car is properly sealed/waxed, you can use a foam canon + 5minute soak + pressure wash off + leaf blower dry and get a touchless wash. This generally only happens when you have a good layer of sealant or wax.
    I use my foam canon as a presoak, then I rinse it off to remove as much dirt as possible. Then I bucket wash with a mitt to get all the dirt off.
    But washing cars is like making sexy time, people have their own preferences and always think their way is the better way.
    Biscuits, ABA180 and koditten like this.
  17. Apr 24, 2018 at 6:36 PM
    #37
    koditten
    Kirk
    Central Michigan
    That last line is on point and hilarious.
    Thanks for the giggle.
    ABA180 likes this.
  18. Apr 25, 2018 at 8:35 AM
    #38
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    I just have fun using the foam cannon lol. I do think it works well to add lubrication to the surface before washing with a mitt. I normally give the truck a good rinse, then spray it down with the foam cannon. Let it sit a couple of mins and then spray it again and jump into the normal two bucket wash. While I'm washing, I'll go back and spray the areas that I've already cleaned and basically keep the truck covered in suds. I really started doing that to use up the last little bit of soap in the bottle. After that, I rinse the truck and dry it with a drying microfiber towel and a drying agent. So far, so good. The foam cannon may not be necessary, but it makes the whole process a lot more entertaining!
    koditten likes this.
  19. Apr 25, 2018 at 4:36 PM
    #39
    koditten
    Kirk
    Central Michigan
    So true!
    I had bird shit on my window today. Asked the wife if I had time give the truck a quick blast?
    Turned the FC on her window and scared the shit out if her. I'm glad she couldn't see me laughing because if all the foam on her window.
    Her response was "damn! That thing makes a lot of soap"!
    Yeah, it does entertain me. $22 well spent!
