Pressure washer and foam cannon
Discussion in 'Detailing' started by ppham444, Dec 24, 2012.
  1. Dec 24, 2012 at 1:08 PM
    ppham444
    ppham444 [OP] Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I bought myself some Christmas presents and decided to test it out. It's a portable electric pressure washer and a foam cannon. This works great for removing caked on dirt and road grime. Just spray the foam on, let it sit for 5 minutes or so, wash it off, then hand wash your truck like usual. This method of washing reduces scratches on your paint because the majority of the dirt is already removed from the foam soap and pressure washer. It's kind of hard to see the foam because my truck is already white, but it's awesome!
    http://youtu.be/dCohtW4kjSY
    Cudgel, DubfromGA and Batman! like this.
  2. Dec 24, 2012 at 6:12 PM
    WarDamn
    WarDamn Well-Known Member
    Davenport, IA
    07 Tacoma
    Thats cool. Where do you get it?
    Looks cold.
  3. Dec 24, 2012 at 6:15 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
  4. Dec 24, 2012 at 6:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Yes, please.
  5. Dec 24, 2012 at 6:23 PM
    ppham444
    Phuong
    Portland, OR
    Batman! likes this.
  6. Dec 25, 2012 at 8:03 AM
    conquistador
    conquistador Well-Known Member
    Tulsa, OK
    88 4Runner
  7. Dec 25, 2012 at 2:22 PM
    YOTACO
    YOTACO Active Member
    Bradford
    Birmingham AL
    05 PreRunner
  8. Dec 29, 2012 at 10:07 PM
    ppham444
    Phuong
    Portland, OR
  9. Apr 20, 2013 at 6:29 AM
    ppham444
    Phuong
    Portland, OR
    Works good, but you still need to agitate the surface in order to get it totally clean. It helps a lot to remove the majority of the dirt and grime though.
    DubfromGA likes this.
  10. Apr 26, 2013 at 12:35 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    Nice stuff man! if y'all dont want to use the foam cannon and pressure washer setup you can always just go with a . just plug into your water hose and achieve the same thing!
  11. May 2, 2013 at 6:38 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    The foam is an excellent tool.
    However, I would not pressure wash the foam off. Pressuring that dirt and mud into your paint can and will scratch it.
    After foam, remove with a light spray and then move it up to medium pressure.
    You should be gently removing contaminants, not forcing them into the paint ;)
    Batman! likes this.
  12. Mar 16, 2018 at 5:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I know this is an old thread. But I really like this unit.
    What type of soap is used?
  13. Mar 17, 2018 at 8:11 PM
    ppham444
    Phuong
    Portland, OR
    Chemical Guys Honeydew snow foam.
    WebberLander likes this.
  14. Mar 18, 2018 at 2:56 AM
    koditten
    Kirk
    Central Michigan
    Thnx
    ppham444[OP] likes this.
  15. Apr 13, 2018 at 4:52 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Continued bump of an old thread.
    How realistic is it to expect a somewhat clean truck result if I were to only foam cannon, let soak, and then rinse off the truck? Theoretically this process, sans hand wash, would be akine to a touchless (soap/foam/spray/rinse only) drivethrough car wash.
    I ask because I don't wash my truck regularly, but I like the concept of the foam cannon/pressure washer. What I don't like is that utilizing the foam cannon/pressure washer method, you still have to hand wash the vehicle.
    I fully recognize and agree that from time to time a hand wash is necessary, but for the casual washer, would the foam cannon/pressure washer only method be a worthwhile investment?
  16. Apr 13, 2018 at 5:37 AM
    koditten
    Kirk
    Central Michigan
    That's my routine. I use the pressure washer to remove most of the dirt.
    I expect the foam cannon will enhance how well the pressure wash rinse will work. Hopefully this lengthens the number if pressure washes before I need to do a deep hand wash.
    backcountryj likes this.
  17. Apr 13, 2018 at 5:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It depends.
    On a vehicle with no outer protection such as a sealer or coating, will likely hang onto dirt and debris more than a car with a quality sealer or coating.
    The blast and rinse method is good for getting salt off your truck in the winter. Dirt doesn’t harm your paint, so if that hangs around who cares, your main goal is to get the corrosive salt off.
    Heres the thing though, if you do not wash the truck with a mitt and a two bucket method YOU CANNOT DRY THE TRUCK WITH TOWELS. The truck will still be dirty and any attempt to dry will result in a lot of swirling.
    I’m going to assume you do not have a water filtration system to give your truck a spot free rinse (ie removal of all minerals and salts in the water).
    So really if you want to use this method it’s fine but your stuck if you don’t have access to filtered water (or youll get calcium build up on the paint and glass).
    So its probably easier to just take the truck to the quarter wash and use their spotless rinse.
    The issue I have with the quarter places is typically you are stuck with their soaps that strip sealers and waxes...
    So in essence there is no way yo be lazy about autocare. Short of being rich and paying a pro detailer to wash the truck for you properly on a regular basis lol
    A little aside, my dad is lazy like this. I went with him in his Porche Carerra 911 (dark grey metallic) to take his car through the quarter wash.
    He blasted it down, rinsed, then pulled the car out into the parking lot and pulled out old bath towels from his trunk and started wiping the car down. The beige towels were BLACK after a single swipe on the lower door panels.
    Needless to say I nearly had a stroke.
    Use a gas powered leaf blower to dry... while it will still scratch the paint its probably better than hand drying.
  18. Apr 13, 2018 at 6:37 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    The main thing the foam cannon is good for is wasting soap. Personally I spend more time using an electric pressure washer to get most of the dirt off. You really need to touch the vehicle with a mitt(s) or microfiber towel(s). Use more than one of either or both.
    The foam cannon and two bucket method are a couple of techniques that I'm starting to find are overrated steps.
    Now replacing the foam cannon for the soap bucket I'm finding may be a better technique. Working in panels or sections of vehicle. I use the pressure washer to spray out the wash mitt, hence not needing a dirty water bucket. Use extra mitts and or towels if you're paranoid about scratching.
    Leave the buckets for collecting the ditry wash mitts and carrying your wash supplies.
  19. Apr 13, 2018 at 6:55 AM
    backcountryj
    Jonathan
    GA
    Wow, thanks for all the feedback. Being as this is the Detailing section, I should have anticipated responses from folks that are more enthusiastic about cleaning vehicles than myself.
    I don't currently use a 2 bucket method, I don't wax or seal anything, and the only thing that gets towel dried after a wash in my house are beings with a pulse. Truly, I don't ever see myself utilizing any of those either.
    My original inquiry was inspired more out of laziness rather than a desire for the best possible car wash methodology. By no means am I knocking those that enjoy a clean vehicle and pursue that end goal vigorously, I just recognize that isn't me.
    Steve Urquell likes this.
  20. Apr 13, 2018 at 7:33 AM
    PackCon
    Connor
    You only use about 1oz of soap in a foam cannon. I waste more in my bucket.
    Foam cannons conserve soap, they don’t waste.
    PzTank, DubfromGA and ace96 like this.
