Pressure solenoid false positive?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Keistercough, Apr 8, 2022.
  1. Apr 8, 2022 at 2:28 PM
    Keistercough
    Keistercough [OP] Well-Known Member
    2003 Tacoma TRD
    TRD supercharger
    Has anyone ever had a check engine for a pressure solenoid in their automatic transmission and found it to be something entirely different.
    I am having this issue with my 03 3.4L supercharged, and have currently swapped the solenoid in question and the ECU.
    Any ideas on possible solutions, or what may be causing this?
    Or even tacoma mechanics in the North West corner of CT / surrounding areas?
    jwizzmasterwet likes this.
  2. Apr 8, 2022 at 3:46 PM
    02hilux
    Planet: EARTH
    What's the code?
  3. Apr 8, 2022 at 3:54 PM
    Keistercough
    2003 Tacoma TRD
    TRD supercharger
    The code is P2716
  4. Apr 8, 2022 at 4:16 PM
    02hilux
    Planet: EARTH
    Dumb question but after you swap solenoid, you did clear the code?
  5. Apr 8, 2022 at 4:43 PM
    Keistercough
    2003 Tacoma TRD
    TRD supercharger
    Yes and it came back almost immediately
  6. Apr 8, 2022 at 4:57 PM
    02hilux
    Planet: EARTH
    Did you test to make sure you have good power (~9-12v) at the pigtail going to the solenoid? Check for good ground (good continuity) on the housing?
    Did you check if the original solenoid click (turn on) by applying power and grounding the solenoid?
  7. Apr 8, 2022 at 8:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Ok, you've discovered it's not likely just a solenoid issue. So what elsr are you going to do?
    What Repairs Will Fix P2716?
    1. Changing the fluid and filter.
    2. Replace faulty pressure control solenoid.
    3. Repair or replace a faulty transmission pump.
    4. Repair or replace defective transmission valve body.
    5. Transmission flush to clean passages.
    6. Cleaning corrosion from connectors.
    7. Repairing or replacing wiring.
    https://www.transmissionrepaircostguide.com/p2716/
  8. Apr 10, 2022 at 7:12 AM
    Keistercough
    2003 Tacoma TRD
    TRD supercharger
    From what my transmission guy told me it's looking like an electrical issue. Just had the solenoid swapped and nothing changed. He is confident the transmission has no issues.
    Does anyone have a wiring schematic of the vehicle. Is anything else wired into the circuit going to and from the ECU and Transmission?
  9. Apr 10, 2022 at 7:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You have a wiring problem if the PCM and the solenoid have been replaced already.
    gearcruncher likes this.
  10. Apr 13, 2022 at 5:32 PM
    Keistercough
    2003 Tacoma TRD
    TRD supercharger
    Thank you for the diagram, I will be using it.
  11. Apr 13, 2022 at 5:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  12. Apr 14, 2022 at 12:04 PM
    gearcruncher
    Canadain bumper technician
    I think you guys covered his issue very well .
    I am also going with broken or corroded wires .
    Most common is at the harness plug where the wiring goes into the transmission .
    Check for resistance at the case connector going into the transmission , You will have to identify the color of the wires and what pins to probe . If the wiring inside the transmission going to the solenoid is showing good resistance , unplug the wiring from the back of the PCM and test the solenoid for resistance up there using the same procedure you used at the transmission harness . Pop some pictures . Show us what you are doin :thumbsup:
    You see this problem constantly on the 5 speed automatics but this will be a first for me seeing this with the 4 speed auto
    https://rostrapowertrain.com/products/52-9029/
    Dm93 likes this.
