Pressure Bleed Master Cylinder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqrivera, Oct 20, 2021.
  1. Oct 20, 2021 at 10:00 AM
    abqrivera
    abqrivera [OP] Active Member
    David
    Albuquerque NM
    2005 Tacoma Access 4 Cyl
    Has anyone ever pressure bled a master cylinder on their truck? After bleeding all 4 wheels, the brakes are still a little spongy. I believe that I still have air in my master cylinder from letting the fluid go too low while bleeding wheels. I am considering using a pressure system to do that if that is feasible.
  2. Oct 20, 2021 at 10:24 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Probably air in the abs. I believe the only option are to hook it up to techstream to activate the abs pump or take it out and do a bunch of hard braking to activate the pump and purge the air.
  3. Oct 20, 2021 at 10:27 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    If you lift all four tires off the ground put it in drive and apply light braking force the abs will kick on.
    I only recommend this if you have a lift of some sort though :anonymous:
  4. Oct 20, 2021 at 6:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Gravel or dirt road.
    Hard braking to make the abs come on.
    Yes, I’m serious. It’s been done by more than a few people on here.
    Or, buy a scan tool that will activate the ABS.
    Most that can run $300+. (Last time I looked)
  5. Oct 20, 2021 at 8:49 PM
    vtdog
    vtdog Well-Known Member
    NH
    I had issue with spongy brakes as well. I had the system flushed at a local shop as trying to bleed the ABS required a tool I did not have. The whole job, including fluid was about $ 90
    TnShooter likes this.
  6. Oct 20, 2021 at 8:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you sure the fluid was allowed to get too low?
    Might have to "bench bleed" it on the car and crack each line at the MC. It's messy but it can work
    or the MC can get damaged and have to be replaced
  7. Oct 20, 2021 at 9:21 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, start with the easy stuff first. The master cylinder can be easily bled on the truck. If you like I can send you the procedure but I need to know if you have VSC (Vehicle Stability Control, some '05s may have it as an option) or not.
  8. Oct 20, 2021 at 9:43 PM
    TacoTuesday1
    NC
