Prep of plastic center caps for paint; what kind of paint?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Keats, Aug 11, 2009.
  1. Aug 11, 2009 at 11:45 PM
    Keats
    Keats [OP] Well-Known Member
    Phoenix, Arizona
    2010 SR5 DC LB
    I just picked up my TRD Off-Road alloy wheels the other day after having them powdercoated. I now want to paint the center caps to match. The plastic surface of the center caps is very sheen and I want whatever paint I use to adhere properly. I know Krylon makes a paint specifically for use with plastics. I hoping to find out from someone here the best way to prep and type of paint to use. I was thinking of sandblasting the caps with a light media to "rough" them up prior to paint, or maybe just some scotchbrite or light sandpaper. I'd appreciate any helpful info. Thanks, Tom
  2. Aug 12, 2009 at 12:40 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I wet sanded them first, then put rustoleum primer, then rustoleum black wheel paint.
  3. Aug 12, 2009 at 6:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I didn't even sand mine....Just cleaned them real good with soap and water, then alcohol...Sprayed primer and then paint.
  4. Aug 12, 2009 at 7:18 AM
    jonny
    jonny Betty White Edition Heep ZJ
    i'm not sure if my way is safe...but my center caps of my stockers would bubble up when i painted them with krylon fusion. i held a blow dryer on low and from a distance sprayed the caps with krylon fusion and had the blow dryer on low as i was spraying. it seemed as if it dried the paint instantly.
  5. Aug 12, 2009 at 7:20 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    what are the advantages of wet sanding versus dry sanding for painting in this application? is it a dust issue? less dust when wet sanding.
  6. Aug 12, 2009 at 7:37 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Well honestly I just did it because thats what my other friends did when they did theirs. Mine are perfect imo. And i used a $2 tack cloth and wiped everything down before the primer.
  7. Aug 12, 2009 at 7:41 AM
    jonny
    i'm sure if you wipe them down with alcohol after the sanding you will be fine
    :thumbsup:
  8. Aug 12, 2009 at 8:06 AM
    phynyx38
    phynyx38 Believe
    San Antonio, TX
    08 Tacoma PreRunner
    I wet sanded mine also, used dupli-color primer and wheel paint. I think they came out really well and I haven't had any problems since I painted them.
