Prep for lift kit check list
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rsanson, Feb 23, 2021.
  1. Feb 23, 2021 at 9:49 AM
    Rsanson
    Rsanson [OP] Well-Known Member
    02 Toyota Tacoma
    None yet
    Alright guys I think the time has finally come!!! I’ve heard from some that I need to do a lot of fluid changes and Lower ball joints and things like that. Is that all I need to do, or is there more to it?
  2. Feb 23, 2021 at 9:57 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    I'd definitely agree that you should get up to date on regular maintenance items before diving into "optional" stuff like a lift. If you're talking about installing some preventive measures in advance, this thread might be helpful:
    https://www.tacomaworld.com/threads/stuff-that-breaks-after-installing-a-lift.667252/
    I got my CV axles re-booted and replaced the front differential needle bearing with an ECGS bushing before getting my lift installed. Not sure if those components cause trouble for 1st gen trucks, though.
    Rsanson[OP] likes this.
  3. Feb 23, 2021 at 10:14 AM
    Rsanson
    02 Toyota Tacoma
    None yet
    Thank you for the help man, I appreciate it
    ardrummer292[QUOTED] likes this.
  4. Feb 23, 2021 at 12:51 PM
    Krogers128
    Krogers128 Well-Known Member
    Kyle
    WA
    1995.5 Paradise Blue Tacoma SR5 V6
    OME complete kit. 881 coils. Dakar Leafs. JBA UCA. 265/75-16 Goodyear Ultraterrain.
    Before I even thought of a lift I did maintenance like timing belt/water pump job with all accessories and full valve cover gasket job. During or before the lift install I also did front and rear diff fluid, T-case fluid, Lower Ball Joints, Upper ball joints (or UCA if it's in the budget), inner/outer Tie Rods, ECGS bushing. It's a bit of a list but makes for more peace of mind.
    Rsanson[OP] and whatstcp like this.
  5. Feb 23, 2021 at 1:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Didn't go as in depth last time we talked but since were on the subject; all the fluids as mentioned. Add crush washers and such as needed for your drain and fill plugs; I can text you the part numbers sometime just remind me. If you've got an automatic, you can add a transmission filter as part of your recommended maintenance.
    Check other items such as your transmission mount and carrier bearing as well, and get yourself a grease gun so you can lubricate all components as needed! I need to do the last part myself :anonymous:
    Rsanson[QUOTED][OP] likes this.
