Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Apr 16, 2024 at 3:23 PM
    #4961
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    Would anyone in here be interested in buying the set of speakers (front and rear) from the OP, with the mounts and adapters off of me?
    I bought everything from the OP minus the Kicker hideaway or anything like that with intentions of doing all of this. I ended up doing the tweeters, then getting conflicted on what I wanted out of the rest of the system, and eventually just decided to leave it stock for now.
    Everything is still in the box, and has never even been opened, just sitting in my closet going to waste.
  2. Apr 27, 2024 at 9:08 AM
    #4962
    Jason12085
    Jason12085 Well-Known Member
    2013 MGM Access cab
    What do you guys think about this?
    Buying this component system, mount the 6x9's in the obvious location.
    https://www.amazon.com/Kicker-47KSS6904-Component-Speakers-KSS6904/dp/B084HL82KK/
    Buying these to put in the door tweeter location. Then externally mounting the tweeters that come with the component system.
    https://www.amazon.com/gp/aw/d/B0CRLFQWQV
    I referenced crutchfield for fit and they said it should work.
    Should be noted that I'll likely be using the factory head unit so tuning won't be optimal.
    And where would you guys recommend mounting the tweeters?
  3. Apr 27, 2024 at 10:07 AM
    #4963
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you really don't need the tweeters with those midranges.
    if you're interested in the setup you posted, kicker does make a 6x9 and 2.75" component set using those same components that would greatly simplify your wiring and setup, and provide as good of sound quality as the parts you've linked so far.
    Jason12085 likes this.
  4. Apr 27, 2024 at 10:50 AM
    #4964
    Jason12085
    2013 MGM Access cab
    Thanks.
    Yeah I saw the KSS269 and the fact that the mid rangers cover a similar frequency range as the tweeters. I didn't think it was an option because crutchfield said it wouldn't fit for whatever reason.
  5. Apr 27, 2024 at 2:20 PM
    #4965
    soundman98
    NW Indiana
    crutchfield is really over-zealous with their 'will it fit' calculator. my last vehicle, it came with 6.5" door speakers. crutchfield stated this. but then said that zero 6.5" speakers would ever fit in the doors and insisted that only 5-1/4" speakers would fit the vehicle.
  6. Jun 29, 2024 at 5:31 PM
    #4966
    WannabeLT
    WannabeLT New Member
    Tyler
    2023 MGM tacoma TRD OR
    king 2.5 front and rear coastal offroad armor
    Hey folks so I installed the ds18 tweeters and they worked great but adding in the front KS kickers they’re scratchy and it feels like the door speakers are barely playing any sound
  7. Jul 26, 2024 at 1:31 PM
    #4967
    MFG
    MFG Well-Known Member
    Saw the kickers were on sale at crutchfield so pulled the trigger on them as well as the Subaru tweeters. Excited
    1Crusader likes this.
  8. Jul 29, 2024 at 3:03 PM
    #4968
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    It's been 4 years and my front door kicker speakers are starting to rattle. Before I go and buy the same exact ones again, is there a model that's recommended as an upgrade? I like loud music, and am looking for a front door model that's up to the task!
  9. Jul 29, 2024 at 10:00 PM
    #4969
    Syrihl
    Syrihl Well-Known Member
    Exact same thing is happening to me after almost 7 years. Interested in hearing if there are any better replacement options.
  10. Aug 5, 2024 at 2:00 PM
    #4970
    SIK99Tacoma
    SIK99Tacoma Well-Known Member
    Taylor
    Big Sur
    2020 OR DCLB
    FOX IFP front 2nd clip 1/2" spacer, FOX 2.0 adjustable resi rear, RXT leaf pack, SSO slimline front w/ baricade 9500lb and amber light bar, ARE Cap, allpro steps, TRD pro style wheels w/ Kenda Klevar skins
    aduio guys.... I am very limited in my amp knowledge so be gentle....
    Is the kicker key 200.4 capable of bridging? not true bridging but...
    Running both front door and rear doors off the same 2 channels and leaving the other 2 channels (normally for the rears unused?
    I already have it installed and the gains turned up to a little hiss and the fader set just behind center. rear doors are still pathetic.
    If the head unit driving them at reduced output is the real problem, could I get them to perform better this way as the fronts are pretty good with the upgrade?
  11. Aug 5, 2024 at 2:01 PM
    #4971
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    check you are wired up correctly. seems like a duh I already checked. but I had a similar issue and everything worked great once I corrected my one bonehead.
  12. Aug 5, 2024 at 2:42 PM
    #4972
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    A "Premium" head unit is a 50W unit. It will pump 20W to each front speaker, and 5W to each rear speaker. The baseline input to the rear is 1/4 the power to the fronts. Therein lay the problem. The amp cannot compensate for that. It can help, but cannot compensate.
    I recently installed the Kicker Key 200.4 amp in my Taco, and yes, the rear is still WAY behind the fronts, but it's much better than factory. At least now I know they exist. Beforehand, it was like, "Huh? There are speakers back there?" I am done with upgrading. I've gotten the sound I need. Maybe not what I want, but definitely what I need.
    If you really want to get sound to the rears, it's time to start thinking about a new head unit and possibly a subwoofer. As they always say.... :spending:
  13. Aug 5, 2024 at 5:00 PM
    #4973
    soundman98
    NW Indiana
    you can wire the front input to the front and rear input. that would make the front/rear signals equal. but the amp doesn't support bridging the output channels.
    SIK99Tacoma[QUOTED] likes this.
  14. Aug 5, 2024 at 5:16 PM
    #4974
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    is the 2020 wiring diagram on this thread in the 249 pages? I remember seeing the 2016-19 diagram but the 2020 is different
  15. Aug 8, 2024 at 7:10 PM
    #4975
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts
    Good stuff! Thanks for sharing!
  16. Aug 13, 2024 at 2:11 PM
    #4976
    ScotWithOne_t
    ScotWithOne_t Active Member
    Scot
    Twin Cities, MN
    Red 2023 TRD Sport
    ok, dumb question: If I replace the front door speakers with a 2-way, or 3-way (like the popular kickers) do I need to do anything special, or are they pretty much plug and play? The OEMs are more of a component 6x9 (paired with the dash tweeter), are they not? Is there anything going on there with crossovers than need to be bypassed since I'd be upgrading to a full-range (3-way) speaker?
    Also, everything I read says the subaru tweeters are the best upgrade, but I feel like my system is lacking more in midrange and bass than treble, hence why I may do the 6x9s in the door first.
    BTW, I have a 2023 TRD Sport with non-JBL system.
    Is all of this even worth it? I read the stock head unit EQ's all the bass out of the signal at higher volumes anyway, so aren't aftermarket speakers still going to sound crappy when you turn it up?
    atc250r likes this.
  17. Aug 13, 2024 at 3:03 PM
    #4977
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I did the the plug and play DS18 in dash tweeters first, then the front and rear doors with the popular Kickers. The biggest improvement to me was the tweeters, they made the highs crisp and gave more of that frontal "stage" you look for to replicate going to a concert. The 6x9 front door speakers helped, and the rear door 6.75's were kind of pointless with the stock head unit that barely puts any power to the back. However, I did the doors with the plan of either adding a small, in dash amp to the stock head unit, or possibly install a more powerful aftermarket head unit down the road. I'd say adding some dynamat type material inside the front doors would help the bass response of those speakers. I have a roll of it to put in and will probably do it when the weather cools off a little.
    SIK99Tacoma likes this.
  18. Aug 14, 2024 at 6:44 AM
    #4978
    ULURU
    I installed 3-way Kicker KS speakers in the front door after I did the Subaru tweeters in the dash. The only special thing I did, outisde of using adapters to not alter factory wiring, was to add sound deadening. Lower frequency response was much improved. I didn't replace the rears (3-way KS, too), until I installed the 200.4 Kicker Key amp...
    I have a 2018 w/ the Premium non-JBL head unit. Unless things changed in more recent models, it may not be advantageous to upgrade the door speakers at all. The standard baseline unit can't drive better speakers. The premium unit can. The JBL unit has a different upgrade path... You better check, first.
    atc250r likes this.
  19. Aug 14, 2024 at 7:35 AM
    #4979
    ScotWithOne_t
    Scot
    Twin Cities, MN
    Red 2023 TRD Sport
    How do I know which head unit I have? I know there are like 3 different entune head units, but I can't seem to find a list of what was available what year, and how to determine which one you have. All I know is that I don't have the JBL system.
  20. Aug 14, 2024 at 7:54 AM
    #4980
    ULURU
