Pre-runner vs. X-Runner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Feb 1, 2013.
  1. Feb 1, 2013 at 5:49 PM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    What's the difference? I suspect that my Taco is a X-runner or some sort but I'm not sure. How can I tell? I know this seem to be the dumbest question but I have to ask. Fairly new to the taco world.
    Cocolocobean likes this.
  2. Feb 1, 2013 at 5:51 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    you've got neither of those...you have a trd sport 4x4...might I ask how you ended up buying a truck before you even knew anything about it?
  3. Feb 1, 2013 at 5:51 PM
    Aw9d
    Aw9d That one guy
    The Xrunner has more frame bracing, 18" wheels, it is lowered about an inch, ground effects kit, and the Xrunner has a different final drive ratio.
    You do not have either of the two.
  4. Feb 1, 2013 at 5:53 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    x runner is low to the ground 2wd. Are x runners 5 or 6 lug?
    pre runner has 4wd suspension but is only 2wd.
  5. Feb 1, 2013 at 5:56 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    X-runners are 5 luggers, have a body kit and an X-brace for the rear to stiffen the frame.
  6. Feb 1, 2013 at 5:56 PM
    Pugga
    Massachusetts
    Not necessarily, Prerunners are 6 lug and 2wd...
  7. Feb 1, 2013 at 5:57 PM
    Kevinztaco
    none yet
    :):infantry::popcorn:
    I know I know!!! I wasn't thinking too much of a truck but ended up buying it kinda deal.
    I was looking at an upscale SUV instead but ended up with this TACO as an offer by the stealership :):)! I hope that answers your question.
  8. Feb 1, 2013 at 6:01 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    This
  9. Feb 1, 2013 at 6:02 PM
    113tac
    Stephen
    Northern Virginia
    Yeah i just found it odd that someone would buy a truck before knowing what it was. I guess those terms don't matter to you though.
    Like they have said before, the main difference is suspension.
    Xrunners have a completely different front suspension compared to a prerunner. where a prerunner has the same suspension as a 4x4 but is only 2wd.
    i have a 5lug base model which suspension wise is almost the same as an xrunner except for the shocks/struts/coils
    xrunners also get their name from the x brace which is like an x at the rear of the frame for stiffness
  10. Feb 1, 2013 at 6:08 PM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    I lol'd a little. You got neither as everyone said.
  11. Feb 1, 2013 at 6:10 PM
    Kevinztaco
    none yet
    Now I know . TRD Sport it is.
  12. Feb 1, 2013 at 6:21 PM
    Kevinztaco
    none yet
    Obviously not as you can tell ;). I was shoping online and the only trim options listed are BASE, PRERUNNER, OR X-RUNNER. Does that mean the TRD Off-Roads and TRD Sports are out of the question?
    http://www.amazon.com/aFe-31-10114-...acoma&keywords=2013+toyota+tacoma+accessories
  13. Feb 1, 2013 at 6:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    X-Runner = lowered 5-lug 2WD with 18" rims and a rear swaybar.
    Pre-Runner = 2WD 6-lug with 4x4 suspension
  14. Feb 1, 2013 at 6:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    For most accessories, select Prerunner.
    The only difference is your 4x4 has a transfer case and front driveline.
  15. Feb 1, 2013 at 7:01 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    What you have is a damn nice truck, congratulations :cheers:
  16. Feb 1, 2013 at 7:04 PM
    Kevinztaco
    none yet
    Very much appreciated, Rich.
  17. Feb 1, 2013 at 7:13 PM
    Kevinztaco
    none yet
    Thanks, Failure2Comply.
  18. Feb 1, 2013 at 7:17 PM
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    X-Runner
    Pre-Runner
    Base
    Everyone pretty much pointed out what the main difference the X-Runner is from everyone else except mentioning the X-Runner is only available with a 6 speed manual and in Access Cab/Long bed configuration.
  19. Feb 1, 2013 at 7:37 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    this was pretty helpful...I have always wondered what the exact differences were...
  20. Feb 2, 2013 at 7:10 AM
    Kevinztaco
    none yet
    a
    The phrase "A picture worths a thousand words" is true. Thanks, GuyWithCamera.
