Pre fill oil filter housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GeorgiaAsh, Aug 10, 2020.
  1. Aug 10, 2020 at 12:39 PM
    GeorgiaAsh
    GeorgiaAsh [OP] Well-Known Member
    Acworth, Georgia
    2019 Silver SR5 DCSB
    As I’m sure y’all know, oil capacity is 6.2 quarts for the 3rd gens. When you change it yourself, do you pre fill the housing with the .2 quarts? Any pros or cons to it?
  2. Aug 10, 2020 at 12:41 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The only time I ever pre-fill a filter housing is on a brand-new/rebuilt engine that hasn't run. Regular oil changes? Never bothered, and never had an issue. I can't think of any real-world pro ,and the main con is the risk (probability in my case) of getting that .2 qt all over the under-carriage, the driveway, and me.
  3. Aug 10, 2020 at 12:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't bother pre-filling on our trucks.
    Lt. Dangle, Junkhead, Chew and 3 others like this.
  4. Aug 10, 2020 at 1:01 PM
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    I do, not sure if it helps.
    I always fill 6.5qts
  5. Aug 10, 2020 at 1:21 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I never do it or have done it to any vehicle I’ve done an oil change in. I’m sure it doesn’t effect it that much. I put 6 qts in mine because that .1 to .2 qt is so small I just don’t drain the oil all the way so everything balanced out.
    Barsoom and shakerhood like this.
  6. Aug 10, 2020 at 1:29 PM
    shakerhood
    Southern Ohio
    I go the extra step and add the .2, lol
  7. Jan 4, 2025 at 3:17 PM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Good info here on what really kills an engine. Pre filling the filter or not isn't it!
    For the record I do pre fill the filter housing and then fill the engine with 6 quarts. I figure the housing holds the .1 or .2 quarts it requires over 6.
  8. Jan 4, 2025 at 3:20 PM
    Billybrew
    Billybrew Member
    2023 Mag Gray Off-Road
    I pre fill the canister. Why not. Takes 30 seconds.
    BillF1564, MOC221_ and auskip07 like this.
  9. Jan 4, 2025 at 3:23 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Pre-filling is a waste of time and an old wives tale benefit from the 1960's as far as I'm concerned. Not only that, if you're old and/or clumsy and drop it, there's gonna be a mess.
    TS4x4 likes this.
  10. Jan 4, 2025 at 3:25 PM
    Bishop84
    Bishop84 Well-Known Member
    I dont judge anyone for doing it, but I only do it on a fresh build engine, never on an oil change. The risk of mess alone isnt worth it. Especially at home on your back.
    Junkhead and Chew like this.
  11. Jan 4, 2025 at 3:41 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I always do. Used to doing it on my motorcycle.
    Easy and quick enough to do it I figure. Can't hurt anything. I've never spilled it either.
    Smudge2075, MOC221_ and Irons like this.
  12. Jan 4, 2025 at 3:56 PM
    jpg366
    jpg366 Well-Known Member
    AL
    09 Silver Prerunner SR5
    Hitch, Running Boards
    Always did unless it threads down.
    Irons likes this.
  13. Jan 5, 2025 at 5:03 AM
    Paddyd
    Paddyd Active Member
    Pat
    2021 Tacoma, Army Green TRD Off Road
    lift
    On this tacoma, no I don't. Where something like that will be really beneficial is on an older vehicle with those great big filters that would need to fill on startup before oil gets thru the engine. These canisters are so small and with the lightweight oil they use, they will be full a few milliseconds after it starts anyway. Doesn't hurt to do it tho, just highly doubtful its gonna add any significant or noticeable life to your engine.
    Chew likes this.
  14. Jan 5, 2025 at 6:17 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I've been driving and changing my own oil for almost 5 decades now and never once prefilled a filter with oil. I haven't lost an engine yet!
    I certainly don't think it's a waste of time but I also don't think it makes a hill of beans difference to the long term health of the engine.
    PS: I'm also a fucking klutz and would make a mess doing it!
    Chew likes this.
  15. Jan 5, 2025 at 6:43 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    When I was a technician at a Volvo dealer the factory rep told us never to fill a filter due to the fact you’re sending unfiltered oil into the motor and several particles 80 or more microns could end up in the oil galley.
    Bulk oil being dispensed into an open oil jug (that sits around the shop oil drum) is one example of how the contaminants could get in there. Someone using a cut off wheel or grinding something in the next bay over……I’m sure it’s happened to somebody.
    Paddyd, Chew and fathomblue like this.
  16. Jan 5, 2025 at 8:06 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I always pre-filled, both in my job as a Toyota tech, and in my retired life.
    This is a simple method to shorten the amount of time the engine runs dry when first started.
  17. Jan 5, 2025 at 8:35 AM
    2023tacomer
    2023tacomer Well-Known Member
    Never. Not needed. Just like warming up the oil before a change, nope.
    The engines will outlast the time the overall truck will last.
    Chew likes this.
  18. Jan 5, 2025 at 11:14 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    I'm retired now but I spent nearly 50 years working with heavy construction equipment. In Caterpillar seminars and training sessions they always warned against prefilling filters. Their research had shown an actual measurable increase in wear in engines that had filters consistently prefilled.
    Some of those engines can cost tens of thousands to repair and upward of 100k to replace. I'm going to continue to install my filters empty and not worry about the fraction of a second it takes the oil pump to fill them when the engine starts.
  19. Jan 6, 2025 at 2:17 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I put 6 quarts even to make things simple sometimes. The dip stick show the oil level near the middle is good enough for me.
    I really like cars that take 5.5 quarts, my Sienna. The used oil fits perfectly in the big 5 quarts container. The big 5 quarts container has a bigger opening making the filling easy without the need of a funnel unlike the 1 quart container.
    Barsoom likes this.
  20. Jan 6, 2025 at 3:52 PM
    Mike Z
    Mike Z Well-Known Member
    On a Tacoma canister filter you can pre fill from the outside edge (slowly) instead of the center hole if you are worried about the oil not being filtered. The Car Care Nut guy videos sometimes show him disconnecting the crank sensor and cranking for a bit to avoid dry starts. On a late model Subaru the filters are horizontal or upright next to the oil fill and can't be pre filled. They have a clear flood mode you can use by holding the brake and gas pedal all the way which Toyota does not have. Hearing that metallic noise when the rpms go up over a thousand during the first dry startup can't be a good thing.
