Pre-Collision System Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AeroCooper, Aug 21, 2018.
  1. Aug 21, 2018 at 5:16 AM
    AeroCooper
    AeroCooper [OP] Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    2018 Off Road, bought new and now has 3100 miles. I replaced the grille with a pro and garnish on the first day. This morning when I started the truck I saw "Pre-Collision System Malfunction - See Dealer", "Check Brake System" and "Check Anti-lock Brake System" warnings.
    I checked the connections and cleaned the garnish but no change.
    I'm wondering if they are going to say the pro grille is to blame and try to make me pay?
    Your thoughts?
    PvilleJohn likes this.
  2. Aug 21, 2018 at 5:21 AM
    Chewy16
    Chewy16 Well-Known Member
    Northern Virginia
    '16 Tacoma TRD Off-Road
    https://www.youtube.com/watch?v=ZjRzcxgc9GM
    This may help. I think there is a period of time that your computer needs to adjust. I don't have TSS myself, so I can't speak from experience.
  3. Aug 21, 2018 at 5:30 AM
    ccotner112
    ccotner112 Well-Known Member
    Saint Louis Missouri
    2018 Tacoma TRD Sport
    17' TRD rims/BFG Ko2, OEM Roof Rack, TRD Pro Grill, Locker down console , Snugtop Rebel, lots MESO mods
    Have had mine installed since March with no issues at all. I did remove battery ground when installing as suggested by others to reset the radar.
    Not one issue except in heavy rain.
  4. Aug 21, 2018 at 5:35 AM
    ninja15
    ninja15 Member
    2018 Tacoma 4X4 DC LB, 2006 Tacoma 4x4 AC LB
    The system needs re-calibrated at Toyota. If you installed the Pro Grille you have moved the sensor down about 4 or 5 inches. The system may seem to work fine. But when you really need it in an accident, are you 100% sure it is working correctly.
  5. Aug 21, 2018 at 5:41 AM
    AeroCooper
    NH
    Am I 100% sure it is working? No, ...but I am sure that it went 3000 miles and 5 months without giving any indication it wasn't working. It seems odd that it wouldn't have acted up sooner than this. I'm thinking something must have changed or malfunctioned. Thanks for the input.
  6. Aug 21, 2018 at 8:54 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes they will. Even if the problem is not caused by the grille its going to be on you as you modded it.
  7. Aug 21, 2018 at 8:58 AM
    AeroCooper
    NH
    I thought they had to prove that the mod caused the issue though. Being Toyota parts, I can't see how they could, although I wouldn't doubt they might try to blame it on that.
  8. Aug 21, 2018 at 8:59 AM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    I think the problem is you put a TRD Pro grill on a non-TRD Pro truck...
  9. Aug 21, 2018 at 9:12 AM
    AmericanDrug
    AmericanDrug Well-Known Member
    Rod
    Valdosta, GA
    2018 TRD OR 4x4 6mt
    May sound dumb but, did you plug the sensor on the grill back in? I had that happen and forgot to plug it back in..
  10. Aug 21, 2018 at 9:12 AM
    AeroCooper
    NH
    Sketchy logic though. They're all Tacomas with the same frames and body parts, and mechanicals for the most part. Again, I don't doubt they will try though.
  11. Aug 21, 2018 at 9:13 AM
    AeroCooper
    NH
    Yes, I did have it plugged in.
  12. Aug 21, 2018 at 9:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You modified a critical part of the system. Meaning, you changed the mounting platform. Yes, it is a Toyota part, but it did not come from the factory that way.
    Toyota does not "try" to get out of paying warranty claims. They happily pay if it is something they did wrong or had a defective part. They also have a set of rules. Good luck I hope you get it resolved. Trying to figure out if its their problem or your problem is a gray area. My point is, if you were still stock and had this issue then there would be no question. You modding it, even if the mod is not the issue, creates that gray area.
  13. Aug 21, 2018 at 9:27 AM
    TailHook
    TailHook Oh, what shall we do with a drunken sailor?
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    It's like the universe is telling you to not be a poser :rofl:
    :crapstorm:
    BlackGT99, Colnajoe, AxisCab and 5 others like this.
  14. Aug 21, 2018 at 9:33 AM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
  15. Aug 21, 2018 at 9:40 AM
    phsycle
    phsycle Well-Known Member
    CA
    Yeah, I bet that's going to be tough to point the blame away from the grill. As I've looked into getting a BSM compatible aftermarket rear bumper, I've come to the realization that those "sensing" parts are highly calibrated and very sensitive--no pun (which is why you see subpar performance with some of those supposedly BSM friendly bumpers). Having Toyota calibrate is not cheap, either. Expensive equipment and few tech hours.
    I'd just move to an SR grill. It looks better than the Pro anyway. :D
  16. Aug 21, 2018 at 9:41 AM
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    I turned on my car without my TSS sensor plugged in and I got the same messages. After it was plugged back in and the truck was restarted, the errors went away. It looks like your car is having trouble communicating with the sensor.
    I would pull it apart, unplug all the connections and verify all the pins in the connectors are good (not bent, oily, etc.). After that, re connect everything and make sure the latch closes on all the connectors. Give each connection a tug to make sure its latched.
    AeroCooper[OP] likes this.
  17. Aug 21, 2018 at 9:47 AM
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    Shouldn't have had to cut anything off to get it removed or to fit the Pro grille.
  18. Aug 21, 2018 at 9:51 AM
    Mnmlod
    Mnmlod Newb
    Yosemite
    2018 TRD Pro
    Re: Magnuson Act
  19. Aug 21, 2018 at 10:06 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    LOL pulling this old gem out .
    doesn't apply here, especially to sensors which require specific orientation, calibration and specific
    types of materials to pass through for the sensor to work
    OP needs to eat this one or remedy on his own
    he messed with some sensors, sensors now out of whack
    Gunshot-6A and Mnmlod[QUOTED] like this.
  20. Aug 21, 2018 at 10:07 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    this^
    it's gotta be something simple. maybe disco battery for 1/2 hour reset everything
