Pre-collision sensor. Comes on and off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Aznboyz, Jan 8, 2020.
  1. Jan 8, 2020 at 7:51 PM
    Aznboyz
    Aznboyz [OP] Member
    2019 toyota tacoma 4x4 sports
    Hello all! Pre-collision sensor comes on and off after installed aftermarket trd grill. Dose anyone have this problem? And any thought of fixing it? Any help will be appreciated!!
  2. Jan 8, 2020 at 8:00 PM
    toottootbeepbeep
    toottootbeepbeep Well-Known Member
    2019 MGM DCLB TRD SPORT~
    there's a big thread about this but i'll just give you my two cents, since i went through it myself.
    according to some people, you'll need to drive it around 100 miles so it can re-calibrate itself. if that doesn't solve the issue, which it didn't for me, i had to install a washer on the top hole of the sensor, between the sensor and the grille. that way, it'll slightly angle the sensor up a bit, since the sensor placement on the pro grille is lower than where it's mounted on the stock sport grille. So far, it's been okay for me. i do get false readings here and there, but not too frequent. i did take my truck into the dealership and they said they scanned my system and said that even though i have an aftermarket pro grille on there, there isn't anything wrong with my sensor or how it reads.
    days after installing my grille, the PCS error kept coming on at the same distance on my commute to work. i made a mental note of that and after i made my adjustments, i used that as a landmark to see if it was still giving me that error or not.
    sidenote: i have a 19 trd sport on stock wheels/suspension. if you modified anything that changes your height, you'll have to mess with the sensor accordingly if it doesn't recalibrate itself.
    again, this worked for me. hope you figure yours out.
    HP11 and MOC221_ like this.
  3. Jan 8, 2020 at 10:13 PM
    Aznboyz
    Aznboyz [OP] Member
    I have the same model. I had the grill installed and drove more then 3000km still keeping come on and off. Took it to the dealership and say the same thing... I'll give that a try. Thank you!
    MOC221_ likes this.
  4. Jan 9, 2020 at 3:45 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Interesting..
    I also have a '19 Sport with faux Pro grille/OEM garnish that I bought from Taco Garage. No issues whatsoever with PCS/Adaptive cruise etc. (except in heavy snow lol). My truck is 1/2 inch higher than stock, in that I'm running 265/70/17 tires.
  5. Jan 9, 2020 at 4:12 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Are there people who didnt unplug the sensor that havent had the issue? Im still waiting to install mine.
  6. Jan 9, 2020 at 4:25 AM
    el Gringo
    el Gringo Well-Known Member
    Brian
    2018 Tacoma TRD Pro
  7. Jan 9, 2020 at 6:00 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    As others have said, there are big threads on here about that. BUT, and I also installed an aftermarket grill about a week after getting my 2019 TRD Sport, and for the first 2000 miles or so, the PCS OFF light was coming on here and there. Then, it seemed to work fine without the PCS light coming on. Then, when I took my cross country trip from CA to NC and back to CA last October, the PCS OFF light came on about an hour after leaving my home in the SF Bay area of CA. It would go off only when I filled up at gas stations, only to come back on again about 15 minutes into the drive again. This went on all the way across the country until I got to the Outer Banks of NC. Then, it seems to have "learned" and the PCS OFF light has not come on again since. I complained to the dealer about the dang thing not working going east on my journey, and he indeed said that it was a "learning system", and as such, that was why it took a while to learn. In any case, as others have alluded to, you have to put miles on the vehicle and have it learn before the PCS OFF light will quit coming on and going off. Also, as someone else pointed out, installing a washer between the sensor and the new grill, will also help to put the angle back to compensate for the change in sensor height with the new prostyle grill.
  8. Feb 12, 2021 at 4:13 PM
    Randymshot
    Randymshot New Member
    Randy
    2011 Tacoma Access SR5
    I have a 2019 Tacoma. Bought a Chinese trd grill and then a OEM trd grilland toyota garnish, To no avail. It was driving me nuts! It just wouldn`t work and the message on the dash would not go away for 2 months. Call it a hunch or just dumb luck, I decided to try and bought a new wire plug piece thinking NO WAY it`s gonna do anything and BAM! I can`t believe it, IT WORKS! I`m talking about the wire with plugs on each end one end go into the sensor and the other connects up top into a wire into the engine compartment. I`m so happy right now. I almost paid Toyota $265.00 to re calibrate the sensor but the new plug worked! $25.00! Hope this may help someone else.
  9. Feb 12, 2021 at 4:24 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Heres my personal experience..
    I installed the TRD Pro grille back in August 2019 and I instantly had an error that said something like "sensor malfunction - clean sensor" and it went away within two weeks. A few months later, I removed the grille to install new headlights and the error came back, except it only lasted for 1 day. Then I installed raptor lights, fog lights, lightbars, etc. I've probably removed the grill and unplugged the sensor at least 20 times in the past year. I only had errors the first two times. I'm assuming the sensor recalibrates itself after any adjustment. If its not doing that, try putting the OEM grille back on until the warning goes away, and then try the TRD Pro grille again.
    And also... If you have Toyota Safety Sense, please put the OEM grille back on whenever you make a trip to the dealership because they'll do anything to disarm the sensor because "liability".
    If I'm not mistaken, they've denied warranty work on trucks with aftermarket grilles before so thats also something to be aware of.
  10. Jun 18, 2021 at 8:06 AM
    davegoroun
    davegoroun Well-Known Member
    USA
    '19 DCLB TRD Offroad
    Do you have a link or part number?
