PowerStop Z36 Caliper and Rotor Reviews?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by acbeer, May 29, 2021.
  1. May 29, 2021 at 8:14 PM
    acbeer
    acbeer [OP] Member
    Iowa
    2007 Double Cab TRD Sport Long Bed
    Has anyone installed the PowerStop caliper and rotors on their truck (Tow version Z36)?
    How have they worked for you? Since I have 146K on my original OEM set, I’m leaning towards an OEM replacement, but considering the slotted and drilled rotors for added heat dissipation for the few times a year I tow heavier loads.
    Anyone with experience with this rotor and caliper set? Thanks for any guidance.
  2. Jun 18, 2021 at 10:57 AM
    BeastyDirtSlut
    BeastyDirtSlut Well-Known Member
    2003 Toyota Tacoma 4x4 TRD SR5 3.4 Auto
    2nd Gen Supercharger, URD 7th injector, 6" Fabtech lift, King coilovers, Alcan lift springs 800# over
    I put some PowerStop 13WL tundra calipers with their slotted and drilled rotors and Z36 pads on a 2002 double cab 4x4 a while ago. I no longer have the truck but I put 15k on it with that setup. The calipers seemed decent, remanufactured and stamped 13WL. The rotors held up well and with the surface size I had zero fade coming down steep grades loaded with gear. The brake pads seemed decent, average brake dust, nothing too special. I am about to do another 13WL setup on my 03 in the next couple weeks with some different components. I liked the idea of slotted and drilled rotors until I helped somone pull a rock out of theirs at a camp site. So this time I will be going with some solid rotors and some good pads. Not sure exactly what brand yet, OEM is never a bad idea. As for the calipers, having them show up powder coated is definitely nice. While looking at recent reviews of their calipers I am noticing a recent trend of people complaining about seals being bad straight out of the box. Because of that, I am considering going with a local reman from NAPA for its lifetime warranty and painting it myself. I cant say anything bad about PowerStop though, I would just make sure your okay with whatever warranty or return policy your getting.
  3. Jun 18, 2021 at 2:13 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    45K ago I put the Powerstop drilled/slotted rotors and Z36 pads on and they are wearing well and expect about 60-70k before changing. I did not put their calipers on but will next time as will be around 190-200k. Stops better and no fade. I towed a 6000lb trailer and a 4000lb boat so needed some help. Better stops but the 2nd gens brake systems are NOT the best/most powerful. I've driven other newer trucks and much more boost. Many posts and many opinions on the best brakes. I only got 80k on OEM fronts so you must not tow or carry big loads.
    BassAckwards likes this.
  4. Jun 18, 2021 at 4:19 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    Do slotted but not drilled rotors. They can crack between the holes after time
  5. Jun 18, 2021 at 4:56 PM
    muddog321
    FL
    True of cheap rotors that do not have the holes chamfered or a 45 degree taper cut on them which Powerstops do.
  6. Jul 25, 2021 at 7:09 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I got about 40k out of the oem stuff and I'm getting low on the z36 stuff but they've been great for over 40k. I plan to get the pads and rotors again but the calipers are starting to seize so I'm considering powerstops calipers as well.
  7. Jul 25, 2021 at 10:40 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I installed the Powerstop rotors and pads, overall pleased with them but the pads wore pretty fast in my opinion (25K miles).
    Replaced pads with the Toyota TRD pads and that has been outstanding for stopping!! No clue how many miles I’ll get out of them though.
  8. Jul 25, 2021 at 11:55 AM
    RecklessTLS
    Rowdy
    I only got 30k out of my TRD pads
  9. Jul 27, 2021 at 3:15 PM
    pyrite4t3
    pyrite4t3 Well-Known Member
    12 TRD OR AC
    I just put this kit on my truck a couple of weeks ago. Being that it is so recent I cannot quote on longevity.
    The parts themselves are prefect fitment, and other than 'rusty truck' issues (o_O) the install and subsequent performance is great.
    If you already know your calipers are done I'd suggest just buying the complete kit. I started off with just the pads and rotors, and had to go back for the calipers, even going through Rock Auto I spent probably 150 more than buying the complete kit at the onset.
  10. Jul 27, 2021 at 3:19 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I’m on my second set. Got about 45k miles out of the rotors and 20-25k miles out of the pads.
    They are an upgrade over stock for stopping power with larger heavier tires.
  11. Jul 27, 2021 at 3:25 PM
    EGBTER
    EGBTER Well-Known Member
    Wayne
    Denver CO
    2016 TRD SPORT
    I went with the Stoptech slotted rotors, braided lines and ceramic pads a year ago and haven't had any problems. Feels better than stock for sure.
  12. Jul 27, 2021 at 3:27 PM
    DG92071
    DG92071 Well-Known Member
  13. Jul 27, 2021 at 4:39 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I have the PowerStop Z36 kit on two of my Tacoma's (2014 and 2003). I replaced both brakes because they were shuddering when I'd be coming to a stop. "Warped" rotors. I'd say about 30K on the 2014 so far and they've been performing great.
