Power stop Z36 brake kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TWTaco, Mar 10, 2020.
  1. Mar 10, 2020 at 3:44 PM
    TWTaco
    TWTaco [OP] Well-Known Member
    Dave
    Who is running these pads and rotors? Want to get some feedback on this kit. Thanks
  2. Mar 10, 2020 at 7:05 PM
    TWTaco
    Dave
    Looks like no one is using this Power stop brake kit!
    Myles G likes this.
  3. Mar 10, 2020 at 7:06 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s only been a couple hours dude....
  4. Mar 10, 2020 at 7:11 PM
    TWTaco
    Dave
    Was hoping to get a little feedback . Auto Anything has them on sale for a couple more hours.
  5. Mar 10, 2020 at 7:18 PM
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    I don't understand why people run drilled and slotted rotors on brakes that aren't a big brake kit that is being ran hard at the track. I guess for the look? The big difference maker on daily used brakes is the pad itself. They can definitely improve braking performance without doing a major upgrade as say a big brake kit. Rotors not so much.
  6. Mar 10, 2020 at 7:18 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Drilled rotors are not typically recommended on trucks. Dirt/mud/debri can get in holes, they reduce overall mass and they can lead to cracking. Slotted may help if you tow or drive aggressively in the mountains. Otherwise focus on size and weight of the rotor. Mass helps with heat dissipation.
  7. Mar 10, 2020 at 7:30 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Chew and TWTaco[OP] like this.
  8. Mar 10, 2020 at 8:07 PM
    TWTaco
    Dave
    Chew likes this.
  9. Mar 10, 2020 at 8:10 PM
    RushT
    North Texas
    Anything by CrashnBurn80 is going to be well researched and presented. You should check out his lighting work.
  10. Mar 10, 2020 at 8:10 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    I'm running the Z36 kit on my 2nd gen. No problems and they seem to work great. I tow a boat and a utility trailer.
    TWTaco[OP] likes this.
  11. Mar 10, 2020 at 8:12 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Not sure what kit that is, but I've had the Stoptech big brake kit along with rears since I got the truck. They perform excellent both on and off road. Exact info elude me a bit as it's been 4 years, but definitely not dissapointed.
  12. Mar 10, 2020 at 8:18 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Not much is going to be better than stock. The issue is the calipers and a few members here put on aftermarket ones with little to no improvement, one guy was even worse with bad brake fade he couldn't resolve.
  13. Mar 10, 2020 at 8:47 PM
    TheAredub
    TheAredub Well-Known Member
    USA
    AG Taco Pro - Sold
    Mods - Yep, a few ...
    Yep. My experience with slotted rotors comes from running EBCs with Yellows on my Gen 1 Tundra. I was trying to achieve better braking performance (which I did), but at 8k miles on the slotted rotors, the pads/rotors were done. Went back to OE and probably won’t ever run the cheese graters on a truck again.
    HTeeAre[QUOTED] likes this.
  14. Mar 10, 2020 at 8:59 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I had these exact Powerstop Z36 pads and rotors on my 2001 Tacoma. They worked great! I frequently experienced brake fade and vibration from the stock pads and rotors while going downhill. Although, I'm sure it was mainly due to the extra weight of my Northstar Cab Over Camper. These Z36's Truck and Tow brakes held up the best. They lasted the longest, and even at the end of life, they didn't fade or vibrate. :thumbsup:
    liquidmike likes this.
