Power Stop k137 front brake kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stizo, Jan 25, 2017.
  1. Aug 17, 2019 at 7:32 AM
    #61
    ogg
    ogg Well-Known Member
    Eric
    Ohio
    2015 TRD OR
    Supercharged with 2.85 pulley King ext travel with resi's Total Chaos Uppers All Pro Expo leafs Fox 2.0 with resi's rear Level 8 wheels 285/75r16 Mickey Thompson ATZ Prinsu rack SOS sliders, front and rear bumpers, skids
    sprede likes this.
  2. Aug 27, 2019 at 11:10 AM
    #62
    b.miller123
    b.miller123 Well-Known Member
    Everett, WA
    2015 Super White Limited Double Cab Long Bed 4x4
    EBC's point is to not buy crappy knock-off drilled rotors, not that rotors are inherently dangerous if they've been drilled. If that was the case, then they have some explaining to do when it comes to their motorcycle offerings.... https://www.motosport.com/search?textsearch=EBC rotors&tracksearch=1 Holes all over the place. EBC, and powerstop aren't going to sell faulty rotors, and if holes were going to cause their products to kill people or ruin their reputation, they wouldn't be selling them and people wouldn't be buying them.
    I also understand the concern raised in this thread: https://www.tacomaworld.com/threads/brake-upgrade-stoptech-rotors-trd-performance-pads.523829/ and that it is coming from a "vehicle design engineer". Well, I'm also an engineer, and I have holes in plenty of my rotors and if I were to design one, it's probably going to have holes too.
    The sky isn't falling, just don't buy super cheap rotors from no-name companies on ebay.
    #62
    PasswordIsTaco123 likes this.
  3. Aug 27, 2019 at 11:36 AM
    #63
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    I've had them on my rig for 2 weeks now, definitely tell a difference, feel like they grab a little better, but who knows, I replaced mine due to shimmy when braking at speed, happy so far. Worth it!
  4. Aug 27, 2019 at 11:51 AM
    #64
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I put this break kit on my ride 2 years ago and they work great. I also tow a 27' travel trailer and these breaks are just what the truck needed to help stop the truck with trailer in tow.
  5. Sep 11, 2019 at 8:43 AM
    #65
    sprede
    sprede Well-Known Member
  6. Sep 11, 2019 at 8:46 AM
    #66
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Yep! I installed this same K137-36 kit on my 2013 Tacoma about a month or so ago now. I have been extremely happy w/ their performance and installation was no problem.
    sprede[QUOTED] likes this.
  7. Sep 11, 2019 at 8:50 AM
    #67
    sprede
    Did you happen to also install the Stainless Steel Braided brake lines? I heard of others doing so and seeing a difference in braking.
  8. Sep 11, 2019 at 8:53 AM
    #68
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    I have not, but mainly b/c I have those coming soon as part of my new suspension/lift that will be installed this fall at which time I will be installing these front/rear.
  9. Sep 11, 2019 at 8:57 AM
    #69
    sprede
    I got some in my shopping cart right now from Amazon. I feel it wouldn't be a bad thing to do but still looking to see if they have them cheaper somewhere else.
  10. Sep 11, 2019 at 9:01 AM
    #70
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
  11. Sep 11, 2019 at 9:06 AM
    #71
    DerbyCityTaco
    DerbyCityTaco The Air Cargo Guy
    Louisville Ky
    08 DCSB TRD OR
    Installed that exact kit april of 2018. They fit fine, just make sure to spread the caliper all the way. I took a screw driver and used the old rotor for leverage. Figured i'm replacing it anyway...
    Performance is solid. Plenty of breaking power empty and with a loaded trailer. Haven't noticed a squeak, shudder or dust to be honest.
    Also, I did not do the steel brake lines. I will once I swap suspensions but as far as better braking, I doubt it.
  12. Sep 11, 2019 at 9:13 AM
    #72
    sprede
    Ya I have heard both. No they don't see a difference and yes they do see a difference. In my case, I have done nothing to my Tacoma other than have the frame replaced due to the recall. I have changed pads before but never had to do the rotors till now. So, since I am down there might as well do that and I am sure I will see a difference either way.
  13. Sep 11, 2019 at 9:53 AM
    #73
    DerbyCityTaco
    Louisville Ky
    08 DCSB TRD OR
    Look at it this way. Its a hydraulic system. The hose doesn't do anything but give the fluid a path to flow. The stopping power comes from the pads and rotors causing friction. The friction is powered by the hydraulic pressure which comes from the master cylinder. Sure a hose can allow for more brake fluid flow, which would increase efficiency and make the system not have to work as hard which you may or may not be able to notice.
    Either way, it cant hurt. But your big stopping power changes will come from either the friction side (pads and rotors) or the hydraulic side (cylinder).
  14. Sep 16, 2019 at 1:58 PM
    #74
    b.miller123
    Everett, WA
    Braided stainless steel brake lines are used over rubber brake lines to reduce the expansion of the lines during braking.
  15. Dec 4, 2019 at 1:12 PM
    #75
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Alright, looking for an update from y'all with these rotors/pads.
    Bonus points if you are near or past 100k miles on them, but I'm sure that is unlikely.
  16. Dec 5, 2019 at 6:12 AM
    #76
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    So far I have been very happy w/ them. Done some light wheeling and plenty of trips up & down the mountains and they have been great. Only have put about 5700 miles on them though. But no fade or vibrations of any kind under hard braking and no squealing or noise whatsoever.
  17. Dec 5, 2019 at 6:14 AM
    #77
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have 30-40k on them. I tow a small enclosed trailer weekly with no brakes. I have been very happy so far. Looked like lots of pad meat left last time I rotated the tires.
    CowboyTaco[QUOTED] likes this.
  18. Dec 5, 2019 at 11:58 AM
    #78
    96carboard
    96carboard Well-Known Member
    I recently did front brakes with powerstop parts.
    But I went a slightly different way with it;
    Rotors: JBR1121EV -- that is the same rotor as the "K137" rotor, except NOT drilled or slotted since I don't have any hello kitty accessories they need to match.
    Pads: Z36976 -- the supposedly "more stop for hauling" ones.
    The rotors are $35.79 each, the pads are $32.79, so total $104.37 from rockauto.
    HawkShot99 likes this.
  19. Dec 5, 2019 at 1:06 PM
    #79
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road
    I've had mines for a couple years now with around 15k on them. It's been great so far. Replace the stocks because of some shuddering on deceleration. I don't tow, but haul gear every weekend up and over the volcano. Off-road frequently in dusty areas. No issues.
  20. Dec 6, 2019 at 5:19 AM
    #80
    DerbyCityTaco
    Louisville Ky
    08 DCSB TRD OR
    Year and a half, around 15k miles, several towing trips from Louisville Ky over to Greensboro NC, Gatlinburg TN and Myrtle Beach SC. No issues with an moderate weight trailer or a fully loaded bed going over, through or all around the Appalachian mountains.
