Power Steering will not Bleed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Freeheelbillie, Dec 15, 2018.
  1. Dec 15, 2018 at 8:48 AM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    System will not bleed the air after many hours of vacuum pumping...new rack, power steering pump, new high pressure line and reservoir. No visable leaks and system holds pressure.
    I am loosing my mind!
  2. Dec 15, 2018 at 10:15 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Is it reasonable to assume that the air will bleed out on its own via just driving?
    Whine is only at higher RMP not idle...
  3. Dec 15, 2018 at 11:30 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Have you tried jacking the front end up and turning the wheel from full lock to lock several times?
    wilcam47 likes this.
  4. Dec 15, 2018 at 11:32 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you are having issues bleeding the system I would assume either the pump, or the high pressure line internal check valve is bad.
  5. Dec 15, 2018 at 11:43 AM
    Muddinfun
    Muddinfun Well-Known Member
    Continued running just makes the air bubbles circulate round and round. Run it, shut it off, wait for the bubbles to float to the top of the reservoir, run it, wait, run it, wait, etc.
    Lester Lugnut and wilcam47 like this.
  6. Dec 17, 2018 at 5:36 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
  7. Dec 17, 2018 at 5:38 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Damn, I really don't want to have to test that theory...but I am running out of patience and options.
  8. Dec 17, 2018 at 5:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Impatience is the last thing you ever want to have in these sort of situations because that same impatience leads to desperation.
    The issue is not the fluid. As standard Valvoline ATF is good stuff.
    What brand of parts did you use?
    Sandman614 likes this.
  9. Dec 17, 2018 at 5:50 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Agreed.
    OE Re-man from O'reilly's
  10. Dec 17, 2018 at 5:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is your problem right there. Remove the pump (the high pressure line is even suspect, but lesser than the two evils of being bad) and re- replace with a quality remanufactured unit.
  11. Dec 17, 2018 at 5:56 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    It was what was available...can you recommend a quality re-man?
    Whats strange is that the whine is the same as before I replaced everything...a bit better but the same none the less.
  12. Dec 17, 2018 at 6:02 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I think someone asked but have you jacked the tires off the ground, remove reservoir cap and turn steering wheel lock to lock? I’ve always for this and it works for me. I even start off without the engine running and then start it after turning a few times.
  13. Dec 17, 2018 at 6:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Nothing really strange about it. O'Reilly's and Autozone carry garbage parts. All either made in China, or junkyard takeoff's which have been hot tanked, bead blasted, slapped with new packaging labeled "remanufactured" and then resold for hundreds over what it cost to "rebuild" the units. In their defense the majority of brands that you find nowadays have been bought out by the same central manufacturer based out of China who is producing the same junk parts, so even if you buy XY brand, you are still getting the same questionable quality that XYZ brand makes as well. There is no pride of craftsmanship anymore.
    I always recommend OE for major parts like those. Buy once, cry once.
    If not available for whatever reason I recommend you buy Maval for power steering units, they are usually who build the steering components for Toyota. Electronics go to Denso.
    Stick to OE manufacturer's for the big, difficult to replace or access items.
    You need to properly identify where this noise is coming from, however, throwing the kitchen sink at the truck may often make matters worse and leave you in a worst position than the one that you first started in.
    He shouldn't have to. If he can't bleed the system with the tires on the ground by simply turning the wheel then he has defective components.
  14. Dec 17, 2018 at 6:06 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Countless times, including a vacuum pump and the Toyota manual system;
    BLEED POWER STEERING SYSTEM (a) Check the fluid level. (b) Jack up the front of the vehicle and support it with stands. (c) Turn the steering wheel. (1) With the engine stopped, turn the wheel slowly from lock to lock several times. (d) Lower the vehicle. (e) Start the engine. (1) Run the engine at idle for a few minutes. (f) Turn the steering wheel. (1) With the engine idling, turn the wheel to the left or right full lock position and keep it there for 2 to 3 seconds. Then turn the wheel to the opposite full lock position and keep it there for 2 to 3 seconds (step A). (2) Repeat step A several times. (g) Stop the engine. (h) Check for foaming or emulsification. Especially, if the system has to be bled twice because of foaming or emulsification, check for fluid leakage in the system. (i) Check the fluid level.
    3. INSPECT FLUID LEVEL (a) Keep the vehicle level. (b) With the engine stopped, check the fluid level in the oil reservoir. If necessary, add fluid. Fluid: ATF "DEXRON" II or III HINT: Check that the fluid level is within the HOT level range in the reservoir tank. If the fluid is cold, check that it is within the COLD level range. (c) Start the engine and let it idle. (d) Turn the steering wheel from lock to lock several times to raise fluid temperature. Fluid temperature: 75 to 80°C (167 to 176°F)
    beikokupilot likes this.
  15. Dec 17, 2018 at 6:14 PM
    maxtherat
    Inland Northwest
    Well shit you’ve got the procedure down I’d say!!! Here’s where I’d go next: verify no leaks on suction side of pump and if this has all happened recently I’d let it sit with the cap slightly off and let it sit to make sure if any entrained air will release from the fluid. Could be a check valve of some type and depending on the type of check valve it doesn’t take much to hold it open. Don’t know enough about the internals of these to say either way.
  16. Dec 17, 2018 at 6:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Do you have fluid circulation at least?
    I'm sure the noise you are hearing is a whine when you turn the wheel isn't it?
  17. Dec 17, 2018 at 6:25 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Good circulation. Noise is only during acceleration (higher RPM) silent at idle and turning wheel...only a faint noise at full lock.
    I get a bit more noise when I have the system under vacuum pressure, but thats expected.
    I am leaning toward a bad "new" part. Either the pump or a check valve in a line...it better not be the rack :bananadead:
  18. Dec 17, 2018 at 6:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sort of sounds like a bad PS pump bearing which is unable to hold its own under higher loads.
    Which is, admittedly incredibly common on these "reman" units. *flaming banana* Haha.
    Freeheelbillie[OP] likes this.
  19. Dec 17, 2018 at 6:41 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Guess I'll be pulling it out...:pray:
  20. Dec 17, 2018 at 6:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I kinda skipped through the thread but is the fluid still frothy? It should be normal color atf with no pink bubbles. If it is it may have a small leak on the return side of the system. That will suck air in, the fluid will never settle down and the pump will whine. Check the hoses and clamps really close.
    But if the fluid is normal dark color and the pump is still whining then yea, it could be a bad pump
