Power Steering Replacement Cost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KJM_SLC, Jan 16, 2016.
  1. Jan 16, 2016 at 4:30 PM
    KJM_SLC
    KJM_SLC [OP] Member
    Hi everyone,
    I did a search and couldn't find too much regarding the price on what people have paid for this. My power steering pump and reservoir are leaking according to the dealership. I noticed it was leaking after having the same dealer replace the valve timing cover. The leak is fast enough that I would have hoped the dealer would have seen it when the entire front end was off for the valve cover.
    They are quoting me $1068.04 to replace the pump, reservoir, and flush the system. This seems really high to me and I'm going to get a 2nd opinion but was curious what others have paid.
    Quote from dealer for pump:
    Part: Price:
    Pump Assy, Vane $436.99
    Power Steering Fluid $3.83
    Hose, Oil Reservoir $59.99
    Gasket, Pressure Por $5.99
    Labor $376.69
    Misc $31.80
    Tax $43.16
    Quote for flush:
    Part:
    P/S Flush $38.48
    Labor $61.47
    Misc $6.36
    Tax $3.28
    Edit: Sorry for my formatting, my spaces were removed after posting.
  2. Jan 17, 2016 at 9:00 AM
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    Go to another mechanic shop. That seams high. It might not all be bad. I don't use the Toyota shop for anything that I have to pay for. They fixed me of that when they quoted me 975$ to change a front wheel bearing.
  3. Jan 17, 2016 at 9:06 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Did it just start leaking after they did valve cover?
  4. Jan 17, 2016 at 9:20 AM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    X2. Take it to a private shop for a second opinion. Ask around to your buddies to see who has used a good shop in your area with good results. I'll trust a good family-owned mechanic's shop any day of the week, and will never, ever pay a dealership to do anything. Bad experiences.
    Let us know what ends up happening!
    jokker1978[QUOTED] likes this.
  5. Jan 17, 2016 at 9:48 AM
    KJM_SLC
    KJM_SLC [OP] Member
    Yes. I had the valve timing done back in July at 87000 miles and I'm at 89000 miles right now and the reservoir leaks significantly now. There isn't much I can do but take it somewhere else as I don't have the space to do the work myself.
    I priced the parts and I'm seeing they have a huge markup on parts. Pump online is about ~$300 and they are quoting me $437 so I'll be checking other places out. They also quoted me shocks and assembly arms that were about 50% higher than average online prices.
    Should know more tomorrow, thanks for the replies!
    TacoTaco15 likes this.
  6. Jan 17, 2016 at 11:45 AM
    TacoTaco15
    Jake
    VA
    Yeah, dealership prices.
    Let us know how it turns out - best of luck!
  7. Jan 17, 2016 at 12:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    First I would confirm what is actually leaking. Highly unlikely that the power steering pump and reservoir are both leaking. Clean it all up using simple green or a good cleaner of your choice. Then monitor for leaks to see exactly where it is coming from. It may be as simple as a hose replacement.
    I have been driving Toyota since I was 19 ( I'm now almost 61 ) and I have never replaced a power steering pump on one. More than likely just a hose or the reservoir. I would not take their word for it.
    Benny123 and R0dzilla75 like this.
  8. Jan 19, 2016 at 2:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The pump in my 2002 F250 went out two years ago. I paid just shy of $500 for the entire replacement by Firestone. Why in the hell would I need to flush a brand new pump? I just had then drain it and refill it despite their woes that the old fluid could destroy the new Pump. Well I'm still waiting for that to happen.
    What the hell are you doing getting a quote from a dealership out of warranty?
    KJM_SLC[OP] likes this.
  9. Jan 19, 2016 at 7:10 AM
    KJM_SLC
    KJM_SLC [OP] Member
    I travel for work and needed it done quick. Didn't think it would cost that much though ha!
  10. Jan 19, 2016 at 2:07 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Realistically it could. Ther could be bits of matter from the defective pump in the system and they in turn could damage the new pump.
  11. Jan 19, 2016 at 2:18 PM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    The price is way out of line. The pump and high pressure line are only $250, tops. It's an easy job to do yourself. Doubtful if your reservoir is bad, and if it is leaking then replacing the pressure line and cap should do the trick. I'd do it myself if it were me. As far as flushing, you will do that as part of the work. You drain the system putting in a new line and pump. You then refill the reservoir with clean fluid, and run the engine while you cycle the steering side to side to get all the air out of it. you should run the old fluid (whatever is left) into a drain pan and keep the reservoir full while cycling to remove air. Once you are done you can hook up the return line, top it off and call it a day, cause you have flushed your system by cycling new fluid through it in removing the air. Good luck
  12. Jan 25, 2016 at 11:34 AM
    KJM_SLC
    KJM_SLC [OP] Member
    If I had the time I would do it myself, I'm not worried about the work it's more the time. Took the truck to an independent shop and they found the same thing but are able to do it for about $700 (pump and hose are about $330 online average). I had the dealer quote me fixing a clunk in the front suspension at the same time as the pump and they quoted me $3500. That was for new uppers, lowers, and struts. Turns out it's only a ball joint so it looks like I'll be out of there with everything at about $1300.
