Power steering pressure switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by 67tone67, Mar 5, 2011.
  1. Mar 5, 2011 at 5:45 AM
    67tone67
    67tone67 [OP] Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    Hey guys i was wondering what symptoms do tacos have have the power steering pressure switch goes bad? Ive recently replaced my rack n pinion and im due for a new or rebuilt pump.... So shud i just change switch too? Or how can i chck it?
  2. Dec 21, 2012 at 1:18 PM
    jdtoothnail
    jdtoothnail Member
    Joey
    Wapato, WA
    05 TRD Sport DC 4x4 w/ 3" Toytec Lift
    3" Toytec/Eibach Coilover lift w/ 5100s in front, Toytec rear BOSS shocks, Light Racing UCAs, OME Dakar Rear Leaf Packs w/ rear axle degree shims, Toyo Open Country A/T II LT285/75R16 (33"), Gear Alloy 712MB Injectors (Machined Black & Chrome wheels), Airaid Cool Air Intake System, TRD Exhaust, Black Head Light Mod, GrillCraft Black Mesh Upper & Lower Grill, Removed Mudflaps, Jensen VM9324 DVD player (secret e-brake override code on all Jensens) w/ Streaming Bluetooth Adapter, Steering Wheel Adapter & Rear Back-up Camera... ALL done by me, thanks to all the info here on TW. If I can do it, you can DEFINITELY do it!
    Did you ever figure this out? My 05 Tacoma suddenly has tight steering, intermittent tightness through a full turn. Took it to Firestone and they said "Remove & Replace Power Steering Pressure Switch". Can't seem to find much on it. They quoted $119 + $95 labor. Stealership quoted $159 + $140 labor! Seems like something I could remove and replace myself given enough instruction. I found it online for only $32. This has to be something we can fix ourselves.
