Power Steering is failing but problem goes away after it rains
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Feb 4, 2024.
  1. Feb 4, 2024 at 12:47 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey guys. I have a leak in my rack and pinion and I can see where it leaks on the ground on the passenger side. The fluid level does not change at all in the resevoir or at least it is ever so slight that I can't see a big difference. The power steering is intermittent at this point and it will almost completely stop working, making it very difficult to turn the wheels. Recently, we had really heavy rains and when I took the truck for a drive the problem was completely gone, allowing me to drive with one hand again with ease. Does this have something to do with the rain? Is moisture getting into the system? I'm pretty baffled by this but maybe someone can help. Thank you.
  2. Feb 4, 2024 at 1:27 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I’m going to guess the rain lowers the tire to ground resistance. I cant say whether this is indicative of a bad rack/pinion, or PS pump, or both. The leak may be controlled with a leak-stop additive. I’ve had good experience with ATP AT205 on a leaking Corolla. About to use it for a leak in my Taco diff.
    Wulf and SH10151 like this.
  3. Feb 4, 2024 at 1:54 PM
    2009Access4x4
    Shane
    I might try this! There's nothing to lose right? If it's already on the way out, at least it will hopefully delay the need to fix it.
    Chuy[QUOTED] likes this.
  4. Feb 4, 2024 at 5:32 PM
    TacoTuesday1
    FL
    pump could be leaking.
    hopefully there is not a suction leak which causes air entry that stiffens steering and ruins pumps.
    after 10/100 it’s common for a rack and pump to be having issues.
  5. Feb 4, 2024 at 5:43 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Don't put the whole bottle in! Maybe a quarter of it. Then drive about two hundred miles before adding more.
  6. Feb 4, 2024 at 6:46 PM
    2009Access4x4
    Shane
    I
    had it diagnosed and they said it was the rack but who knows. It’s weird that it’s been so intermittent and it will completely fix itself and then go back to being an absolute workout to turn the wheel. What do you mean by 10/100?
  7. Feb 4, 2024 at 7:46 PM
    Chuy
    Lakeside, CA
    Silver Taco
    10yr, 100K miles.
  8. Feb 4, 2024 at 8:17 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    If heavy rain makes it work, I would look for the belt slipping on the ps pump pulley. Assuming the rain was not coincidence, this is the only thing that makes any sense. If it is not rain related, then bad seals in the rack are allowing the chamber’s to fill with air. This explains why it doesn’t lose fluid,but still not assist.
    Leomania likes this.
  9. Feb 4, 2024 at 8:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    rain rejuvenate the intermediate shaft u joint. Spray some penetrating oil on the U joints of the steering shaft.
  10. Feb 4, 2024 at 8:40 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    I agree about the belt slipping idea. Years ago when I worked at a gas station, one of the diagnostic test for a slipping belt was to spray a little bit of water, and see if the squeal stopped. But it doesn’t last very long, so, unless water was getting on the belt continuously, I’m not sure how it wouldn’t have gone back to difficult steering after a few minutes.
  11. Feb 5, 2024 at 4:30 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    This. Try it. Worked for me.
    Tacoma Mike likes this.
  12. Feb 5, 2024 at 8:47 AM
    2009Access4x4
    Shane
    Would that mean that the steering shaft could be the problem and replacing the rack and pinion won't fix the problem?
    Marc70 likes this.
  13. Feb 5, 2024 at 8:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes that's what he means. Spray some penetrating oil on the steering shaft u-joint and see if it helps the problem.
    The shop will just replace the steering rack and then shrug when it doesn't fix the problem
  14. Feb 5, 2024 at 9:02 AM
    2009Access4x4
    Shane
    Ok! Should be easy enough to get to. Can the u joint be replaced or do I need the whole assembly? Only thing I'm curious about is the fact that I am seeing power steering fluid on the ground, passenger side. The resevoir never changes though.
  15. Feb 5, 2024 at 9:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The joint is part of the lower column, outside in the engine bay
    If the reservoir isn't dropping then make sure you're correctly identifying whatever you're seeing on the ground. Have you crawled underneath and looked yourself?
  16. Feb 5, 2024 at 1:13 PM
    nd4spdbh
    SoCal
    The fluid has to come from somewhere, if the res never changes level its another liquid.
    Marc70 likes this.
  17. Feb 5, 2024 at 1:51 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Rain makes turning the tires a LOT easier on the wet surface.
  18. Feb 5, 2024 at 7:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That is possible, in the 1980s a lot of GM cars had bad steering racks and at first the issue was intermittent.
    But I think you should try this first. You're about at the age, my 2010 just had this issue last year. Open the hood and lean in from the driver's side fender with a can of PB Blaster. Spray the joint of the intermediate shaft and turn the wheel about 1/5 turn, spray again, repeat until you have done the whole joint. If that fixes it I would replace the joint..my shop was about $600 for it on my 2WD.
  19. Feb 6, 2024 at 4:22 AM
    Marc70
    Marc70
    Northern Ontario
  20. Feb 16, 2024 at 7:27 PM
    2009Access4x4
    Shane
    Can I do this from the engine bay or do I need to open the wheel fender lining?
