Power Steering flush idea
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thrasher204, Jan 29, 2021.
  1. Jan 29, 2021 at 7:06 PM
    thrasher204
    thrasher204 [OP] Member
    2013 Tacoma
    So I'm lazy and had this idea to flush the power steering fluid and see no reason why it wouldn't work.
    1 suck out the fluid until its lower than the return inlet
    2 detach the return inlet and hook that up to a vacuum pump
    3 attach a piece of hose to the return inlet and pop the other end in a fresh bottle of fluid
    4 turn on the vacuum pump and stop when the fluid being pumped out is sufficiently clean
    Anyone see any problems with this? I for sure am just making things more complicated but hey like I said I'm lazy and don't feel like running back and forth turning the wheel and jacking up the truck.
  2. Jan 29, 2021 at 7:20 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You need to work the valves......
    Get the front end off the ground. You can turn the wheels lock to lock using one wheel. No need to use the steering wheel. Don't get in a hurry. The fluid will trickle out, but it will come.
    I screwed up when I flushed mine. I got the bright idea to start the truck and let it idle while I worked the wheels..........well, the pump quickly emptied the reservoir and my bottle. It ran for a little time without fluid. When the "OH SH1T!!" moment dawned, I shut off the engine. Connected everything back together, filled reservoir, cycled the wheels to purge the air, filled, purged, filled, purged.......eventually was able to button everything up. I have not detected any damage, been running since Oct '20 without any abnormalities.
    thrasher204[OP] likes this.
  3. Jan 29, 2021 at 7:28 PM
    thrasher204
    2013 Tacoma
    Well that was a short lived idea. Think there would be enough suction by turning the wheel for the bottle on inlet idea? I guess worst case scenario it wouldn't work and I would just have to do manual fill.
  4. Jan 29, 2021 at 7:29 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Honestly it sounds like more work to do it that way haha.
    Drain reservoir, unhook return line, cap return nipple, re-direct hose into empty bottle. Turn wheels back and forth while refilling the reservoir with new fluid.
    No chance of getting air sucked in and no need for a vac pump :thumbsup:
  5. Jan 29, 2021 at 7:32 PM
    Bishop84
    Bishop84 Well-Known Member
    Lots of techs use your method.
    I find it lazy and ineffective.
    ATF/Dex3 PS fluid is a detergent and the pump and rack need to be moving and worked when flushing.
    I suck as much old fluid out as possible, get it warm, and keep cycling the reservoir until I've used a liter.
  6. Jan 29, 2021 at 7:48 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I kind of want to do this, but still don’t know what power steering fluid to use... any recommendations without screwing up the system?
  7. Jan 29, 2021 at 7:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    this
    but when its running half the fluid you're sucking out is the clean stuff you just put in. The above way displaces the fluid pretty well IMO
    Merc/Dex 3 (auto trans fluid)
  8. Jan 29, 2021 at 9:05 PM
    Bishop84
    I actually make it take a long time, heat and time are my secret. I usually suck it out, fill it up, let it run and torque wheels etc.
    I actually consider P/S flushes to be unnecessary unless really high miles. Tacomas tend to wear out the rack before the fluid becomes an issue.
    tcjacado and b_r_o[QUOTED] like this.
  9. Jan 30, 2021 at 9:04 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I am lazy. So I use a gear oil bottle style pump, place in reservoir , pump some out, top off with ATF. I usually do this every oil change , since 90k
  10. Jan 30, 2021 at 9:33 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    This is what I do:
    1) Grab beer or whiskey. I’m a whiskey man.
    2) **this step is for married or live in GF’s, cuz you know damn well you don’t have one of these** While your by the kitchen grabbing a drink, steal the old ladies turkey baster. Take a drink or two.
    3) Suck as much out of the reservoir as possible. Take drink or two.
    4) Refill reservoir and place cap back on. Start vehicle and turn steering wheel back and fourth. Lift the front end if you so desire. Take a drink or two.
    5) Remove reservoir cap, suck out as much of the dirty fluid as possible. Repeat step 4. Take a drink or two.
    Under no circumstances do you try and clean out the turkey baster. Go out and get the lady a new one. I do this every 25k miles. Been doing this since 16 and have never lost a PS pump or rack except for my rock crawlers with full hydraulic steering.
    TexasWhiteIce and tcjacado like this.
  11. Jan 30, 2021 at 9:44 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I found the turkey baster, always leaking back out as i am trying to remove the fluid
    SR-71A and ColoradoTJ like this.
  12. Jan 30, 2021 at 10:02 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had problems with the Turkey baster also so I got one of these on eBay. They work great. Just add about 5” of tubing to the end.
  13. Jan 30, 2021 at 10:21 AM
    ColoradoTJ
    Colorado
    I just don’t let the pressure all the way off on the bulb so when bringing out you can slowly let out on the bulb. Not saying you won’t drop a little though.
  14. Jan 30, 2021 at 10:22 AM
    ColoradoTJ
    Colorado
    bet that works like a champ. Good idea.
  15. Jan 30, 2021 at 10:31 AM
    spitdog
    Another trick instead of jacking up the front end to make the wheels turn easy. Put a couple of pieces of Cardboard under each front tire, it will eliminate tire friction with the ground so you don’t need to take the weight of the front tires. Even some plastic squares would probably even work better.
    a400ryan and SR-71A like this.
  16. Jan 30, 2021 at 10:40 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    You're a genius! I've been stealing my wives Turkey baster for years only to get dirty looks and drips everywhere.
    spitdog[QUOTED] likes this.
  17. Jan 30, 2021 at 10:44 AM
    spitdog
    This is how I have always done it. Really works good!
  18. Jan 30, 2021 at 12:06 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Yeah this is the best way to do it, you just have to jack the front wheels up so you can turn them side to side to pump out all the old fluid, do not start the truck while doing this.
    SR-71A[QUOTED] likes this.
  19. Jan 30, 2021 at 12:15 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The top of your PS reservoir will say what to fill it with. Mine says use ATF fluid. I went with Valvoline MaxLife.
