Power Steering Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mediocre Dude, Jul 23, 2022.
  1. Jul 23, 2022 at 10:04 AM
    Mediocre Dude
    Mediocre Dude [OP] Member
    2017 Tacoma TRD Sport
    Good afternoon !
    I just Finished changing the oil on my 2017 tacoma TRD sport. I was checking all my fluid levels and noticed my power steering fluid is below the cold min line. Truck has 74k miles and was purchased from the dealer with 69k on it.
    my thought process is to just top off the fluid and monitor for a leak vice drain /replace all the fluid. Any thoughts on this ? I’m by no means mechanically inclined but all things are possible through father YouTube so just trying to get input from those with the knowledge/experience.
  2. Jul 23, 2022 at 10:22 AM
    Bishop84
    Bishop84 Well-Known Member
    Check your steering rack boots. The rack is likely leaking and the boots are collecting it.
    Top off with any dextron III oil. You can buy it at 7-11's lol.
  3. Jul 23, 2022 at 10:25 AM
    EarthCruzn
    EarthCruzn Well-Known Member
    Florida
    2022 TRD V6 4WD Manual 6 Speed
    DCSB SPORT
    If you do not see any fluid leaking anywhere now and if the fluid level is below the line (make sure your on-level ground) add to the full cold line (if the engine is overnight cold).
    Then watch it for leaks or loss of fluid level.
    Take note where the level is when the engine is HOT and mark it with a sharpie (factory uses blue ink to mark when filled the first time)
    So now you have a cold level and hot level "marked" watch the level and look for leaks.
    It is not unusual for the rubber hoses to "swell" a bit over time and that will make a greater volume in the system,
    (Not much of a volume 1-2 ounces) but it is noticeable at the reservoir level line.
    Mediocre Dude[OP] likes this.
  4. Jul 23, 2022 at 10:53 AM
    Mediocre Dude
    Thanks for this just checked the boot. Looks like there’s some minor fluid build up on the passenger boot from what I could see.
    Lt. Dangle likes this.
  5. Jul 23, 2022 at 2:08 PM
    Mediocre Dude
    This should suffice or should i run full a full synthetic ?
  6. Jul 23, 2022 at 2:10 PM
    Bishop84
    It's perfect, now you can decide on top up, or suck out some, refill and repeat a few times.
  7. Jul 23, 2022 at 3:05 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    I think Prestone makes clear PS fluid for "Asian Vehicles", with a red cap. Stuff isn't exactly cheap, but you can keep your clear, colorless, um color.
    shotgunbilly420 likes this.
  8. Jul 23, 2022 at 3:08 PM
    Mediocre Dude
    from my understanding you don’t want to use actual PS it should be ATF… if they are the same forgive my ignorance this is a whole new world to me…
    Plain Jane Taco likes this.
  9. Jul 23, 2022 at 3:14 PM
    AxisCab
    Dave
    The Dexrons are red, and PS is almost clear. Factory fill is clear.
  10. Jul 23, 2022 at 3:19 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    car care nut recommend power steering specific fluid over Toyota WS ATF because it has more power steering additives.
  11. Jul 23, 2022 at 3:26 PM
    Mediocre Dude
    think that’s because they use a dye free atf ? Something I had read earlier again could be way off either way appreciate the input.
  12. Jul 23, 2022 at 3:34 PM
    AxisCab
    Dave
    You should be OK, using a specifically, purpose built fluid by a major automotive fluid company. They specifically list Toyota in the app list.
  13. Jul 23, 2022 at 3:44 PM
    EarthCruzn
    Florida
    DCSB SPORT
    What state do you live in,.. cold temps can make the steering squeal if you use certain fluid types.
  14. Jul 23, 2022 at 3:45 PM
    Mediocre Dude
    I’m in Texas where the only cold weather occurs in my dreams
    AxisCab likes this.
  15. Jul 23, 2022 at 4:06 PM
    EarthCruzn
    Florida
    DCSB SPORT
    Your good,
  16. Jul 23, 2022 at 5:02 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    My truck was just barely below the cold min line when I bought it new.
    No big deal. Topped it up with Dexron III and haven't thought about it.
    Add some Dexron III ATF and check it in a few months. You're probably good.
  17. Jul 23, 2022 at 6:22 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    It'd be easy to suck some out and refill drive and repeat a few times. However don't use a turkey baster. The rubber will fall apart in contact with the fluid. Tractor supply sells a tool made for this.
    It's not special fluid. It's only Dexron like others said the color doesn't matter.
  18. Jul 23, 2022 at 7:21 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    The owners manual literally says Dexon III ATF. Why anyone is suggesting otherwise is beyond me. Guess they know more than Toyota. Any way I have replaced mine since it was and the low line by removing and refilling every few days till it all seem the same color as new.
  19. Jul 23, 2022 at 7:25 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Just an FYI, but this is a common issue on these trucks. My boots have been wet for years and I have had to add PS fluid all of 2 times in 5 years of ownership. The clamps on the boots are of much better quality than the seals on the rack lol.
  20. Jul 23, 2022 at 8:06 PM
    verlaryder
    verlaryder Well-Known Member
    These are all dedicated Dexron III fluids that can be used:
    asuchemist likes this.
