Power steering fluid, not Dexron from factory
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DAS POWDER, Mar 27, 2024.
  1. Mar 27, 2024 at 4:45 PM
    DAS POWDER
    DAS POWDER [OP] Active Member
    2021 MGM TACOMA TRD OFFROAD, MT
    TRD Lift Kit, 17" TRD wheels, B&M short shifter, Oil catch can, extra bed tie-down points
    I have a 2021 Tacoma TRD OFFROAD 35k miles. Noticed the power steering fluid was kinda low. So I check the fluid. Keep in mind I have not topped off or changed the power steering fluid since buying new from dealer.
    The fluid was a carmel color. Photo of it on the dip stick best I could show you.
    I thought this was odd as it should be Dexron that has a reddish tint. Even old Dexron has a little red or black color to it.
    So I smell it, and I'll be damned if it isn't power steering fluid. Power steering fluid and Dexron II or III smell very different.
    The fluid on the top is power steering from the truck with 35k miles. Fluid on the bottom is new Dexron II or III.
    Just curious if anyone else has power steering fluid from the factory. And also confused why they would do that, if Toyota says Dexron II or III.
    Also flushing my power steering system and putting Dexron II or III in. Time now
    HondaGM likes this.
  2. Mar 27, 2024 at 4:49 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Damn now I’ll have to check mine when I leave the beach.
    HondaGM and HazMatKat413 like this.
  3. Mar 27, 2024 at 4:50 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It's dirty.
    HondaGM likes this.
  4. Mar 27, 2024 at 4:55 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That is the OEM fluid, Toyota uses fluid that just doesn’t have red dye in it.
    Speedfreak, wi_taco, joeyv141 and 3 others like this.
  5. Mar 27, 2024 at 5:00 PM
    DAS POWDER
    I can understand Toyota "dye free" Dexron II or III. I may need to confirm that. But the smell is definitely power steering fluid. I wonder if there's a way to confirm that other than, smell.
    HondaGM likes this.
  6. Mar 27, 2024 at 5:04 PM
    Bishop84
    Bishop84 Well-Known Member
    It's just factory fluid with no dye.
    Check your steering boots for leakage.
    Junkhead, HondaGM and Superdave1.0 like this.
  7. Mar 27, 2024 at 5:10 PM
    DAS POWDER
    Rack and pinion is dry as a bone. But will keep an eye on it.
    HondaGM likes this.
  8. Mar 27, 2024 at 5:12 PM
    DAS POWDER
    Honestly I just didn't want to mix power steering fluid with DEXRON II or III.
    HondaGM likes this.
  9. Mar 27, 2024 at 5:49 PM
    The Mink
    The Mink Well-Known Member
    Happyrock, Oregon
    2017 OR AC
    Here is what the dealership sold me when my rack was leaking and had to top it off. It’s multi-functional :rolleyes: IMG_0028.jpgIMG_0029.jpg
    eurowner, HondaGM and MGMDesertTaco like this.
  10. Mar 27, 2024 at 5:52 PM
    MGMDesertTaco
    That's normal factory fill. ATF Dexron 3 is what's in the owners manual. My dealer uses johnsen's power steering fluid.
    I bought the Toyota ATF and power steering fluid in the post above. 3 quarts for a full flush.
    HondaGM likes this.
  11. Mar 27, 2024 at 6:08 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I just use the BG power steering fluid…
  12. Mar 27, 2024 at 6:09 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Just be a man and loops the lines, remove the reservoir and shorten the belt. Instant power increase and a daily arm workout. Win win.
  13. Mar 27, 2024 at 6:15 PM
    DAS POWDER
    I had a 2002 Camaro while in the Marines. It takes power steering fluid only. Not a multi purpose like toyota. The fluid in my truck smelled exactly like GM power steering fluid. I was just hesitant mixing dexron with what I believe is not Toyota ATF/Power steering fluid.
    Looks like I need to get my hands on a bottle of the toyota fluid and smell it. "Science for Marines"
    The Mink likes this.
  14. Mar 27, 2024 at 6:19 PM
    MGMDesertTaco
    It only takes 3 quarts of dexron 3 for a full flush on the Tacoma.
    I had a couple of those 02 catfishes. Red 35th anniversary, t-tops, 6spd, full hotchkis suspension and a SOM hard top 6sp SLP#260. Prestone power steering fluid for both. Red one was my favorite.
  15. Mar 28, 2024 at 1:37 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    If they say it's supposed to run dextron 3 then i'd just top it up and call it a day despite the colour differences. They wouldn't tell you a fluid that was incompatible to the factory fill.
    Of course monitor for if the level drops more or you notice a leak.
    If mixing it concerns you then just flush a couple litres through the system of the fluid you want to use. You could probably even flush it through with a single litre.
    These trucks aren't picky for fluid. I've been running Pentosin CHF 202 for over 150'000kms in my truck with no ill effects or leaks. Reason for that fluid choice is just because I have tons of it.
    When I run out of the Pentosin i'll most likely just run my favourite flavour atf that's readily available as the Pentosin fluid is quite expensive last I checked.
    If I remember correctly, GM specifically has a Dextron III(K) fluid which was ONLY for manual transmissions and power steering systems that specified Dextron 3 fluid and it differed from the normal dextron 3 which I think was Dextron III(H), in that the K fluid didn't have friction modifiers in the fluid which are used to facilitate smoother shifts in an automatic. According to the service bulletin of the time, the lack of friction modifiers was also better for the power steering system. How? I don't know.
    The K fluid would be similar to the Motorcraft Type F fluid and I consider them equivalent.
    I can't say that i've ever noticed a difference between the two different Dextron 3 fluids or any atf for power steering applications though in either performance or reliability. I would just recommend a thinner fluid if you experience cold winters
    DAS POWDER[OP] likes this.
  16. Mar 28, 2024 at 7:46 AM
    DAS POWDER
    Thank you for the info. Flushed system last night with AMSOIL ATF.
    joba27n, The Mink and faawrenchbndr like this.
  17. Mar 28, 2024 at 1:28 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Does Dexron III fluid even still exist (officially)?
    Asking because GM's "Dexron III" fluid specification (along with Ford's nearly identical "Mercon" spec) were superseded long ago with new formulations (Ford's is now Mercon V, not sure what GM's is other than it's no longer Dexron III). The names for these specifications were licensed to other companies (such as Valvoline, etc.) to be able to sell the fluid as well, but they have long since been nullified.
    Dexron III (and Mercon) is still available aftermarket (it is now called "Dex/Merc" because of said license thing), but for a car company to continue recommending something no longer officially made seems odd... (even the Toyota fluid above says "Formulated to replace Dexron III in applicable Toyota models", so it too is not an official Dexron III product).
    Maybe there's something here I'm missing?
  18. Mar 28, 2024 at 7:25 PM
    joba27n
    Nolan
    Alberta
    Officially, no Dextron III is superseded to Dextron IV. GM still sells a "Dextron III" but only the version for Manuals and Power steering. Various other companies sell a Dextron III fluid but technically GM no longer issues that license so fluids claiming to meet that spec are self proclaiming that. GM only currently licenses Dextron IV which is supposed to be backwards compatible with the legacy version
    I would assume this to also be the case with Ford's Mercon fluid but I can't say for sure as I was only ever a GM technician.
    I would guess they just stated dextron III as the power steering spec as it's the easiest spec that meets their requirments but is readily available. My question though has always been why does it matter? Why not just Toyota Ws fluid or even the older Toyota fluid. I'm not a tribologist though. Maybe a fluid expert like @hiPSI could educate us
    4x4junkie[QUOTED] likes this.
  19. Mar 29, 2024 at 11:35 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
  20. Mar 29, 2024 at 11:42 AM
    Bishop84
    joba27n likes this.
