Power steering fluid low. Can't find leak.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoser1, Apr 9, 2017.
  1. Apr 9, 2017 at 7:02 AM
    hoser1
    hoser1 [OP] Well-Known Member
    Hi,
    I was hoping some of you could point me in the right direction as to what to look for regarding a possible power steering leak. I took some pictures of reservoir prior to topping off as well as the hoses near the reservoir. I did not find any residue near the clamps. I followed the hoses all the way down and did not see any residue (no picture of that unfortunately). I just topped off with ATF Dextron III (last picture). I also turned on my car and turned the steering wheel from side to side while I had some cardboard underneath my car. Nothing found on the cardboard. Any help would be greatly appreciated.
    Hoser
  2. Apr 9, 2017 at 7:04 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    look on the bottom of your steering rod boots. Also check your rack.
    see on mine, how the bottoms are darker? thats where the fluid goes.
    E3F7D594-9CB8-4173-83C8-F61B203E3142_zps_b7da582eeecb7d123b26a369c62bc4c255423dac.jpg
    hoser1[OP] and Alexely999 like this.
  3. Apr 9, 2017 at 7:09 AM
    hoser1
  4. Apr 9, 2017 at 7:11 AM
    hoser1
    So are you saying your's had a leak because they were darker on the bottoms.
  5. Apr 9, 2017 at 7:17 AM
    fatfurious2
    David
    Ashburn, VA
    for mine, its a crazy small leak. Like I dont need to add any fluid for several months. Just keep an eye on it every time you change your oil
    If yours is faster than that, Id do more tracing. You could also do a leak down test. I do not know the details of that.
  6. Apr 9, 2017 at 7:18 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    The missing fluid is most likely in the boots at the end of the rack. Squeeze them by hand and see if any comes out. Been there too...
    fatfurious2 likes this.
  7. Apr 9, 2017 at 7:28 AM
    hoser1
    Gonna do that later today. Thanks for the tips. What did you end up replacing?
  8. Apr 9, 2017 at 7:30 AM
    hoser1
    Yeah, gonna check it daily. I was worried I would forget exactly where I topped off the reservoir, that's why I have the last pic for reference.
  9. Apr 9, 2017 at 7:36 AM
    fatfurious2
    David
    Ashburn, VA
    I think daily is excessive if you arent seeing anything on cardboard. But its up to you!
  10. Apr 9, 2017 at 7:57 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I've had the rack replaced in my truck twice because I was losing fluid. Both times there were no drips anywhere, and it slowly got worse and worse. I don't remember exactly how often I was adding fluid, but it was a few weeks to a month between top offs. The first replacement rack lasted less than 6 months. :rofl:
  11. Apr 9, 2017 at 9:16 AM
    Canoehead
    Canoehead Well-Known Member
    Duncan
    Dartmouth, NS Canada
    2007 DCSB, lots of scratches
    Rearview mirror upside down
    My power steering has been leaking extremely slowly for a long time, at least two years. Usually the only way I could tell is by looking at the rubber boot on the rack, where I see the oil as in the picture above. Once or twice, when working the truck through some mud or snow, I cranked the steering over to the stops quite a bit, and probably held it there unnecessarily. On those occasions I lost a lot of fluid.
    All to say, you might be fine so long as you don't over work your steering pump and you are okay with a bit of fluid on the outside of your steering rack.
  12. Apr 9, 2017 at 9:19 AM
    Kadowampus
    Kadowampus Well-Known Member
    Ventura County
    2011 SR5 4x4 extended cab
    front & rear 5100 Bilstein shocks, eibach/toytec coils, .5" lean spacer, 2" AAL, Derped wheels, Smittybuilt 8000, Technora line, Factor 55 Flatlink, ARB Bumper, Curt receiver, frontrunner load bars, eezi-awn 1600, Lightforce lights, pop-n-lock
    Idk how many miles is on that fluid but it wouldn't be a bad idea to change it out. It looks kinda dirty. Changing that kinda stuff out is cheap insurance imho
  13. Apr 9, 2017 at 1:42 PM
    hoser1
    Yeah, it looks like I will make the change once I figure out where the leak is coming from. I am the original owner and my trucks currently at 73K miles. I was planning on 100K change. I guess I felt changing it too frequently or early can sometimes do more harm than good.
    Kadowampus[QUOTED] likes this.
  14. Apr 9, 2017 at 1:43 PM
    hoser1
    I'm borderline OCD. Once I figure out the leak, I will want to fix it.
    Kadowampus likes this.
