Power steering fluid foaming
Discussion in '1st Gen. Tacomas (1995-2004)' started by Riley0226, Jan 29, 2025.
  1. Jan 29, 2025 at 10:01 AM
    Riley0226
    Riley0226 [OP] Active Member
    98’ Tacoma sr5 4x4
    The other day I left my truck on in park for almost an hour. When I started driving again the pump was noisy and the fluid was foaming. I left it overnight and it was completely fine the next day. Drive it around maybe 30 miles and nothing happened until I hit a small dip in the road and then it was noisy again and started foaming. Same thing this morning, completely fine but I’m sure if I drive it long enough it’ll start foaming again. Fluid is new, just flushed it recently and bled the air out maybe 3 weeks ago. Level was halfway to the cold mark so I topped it off but other than that I’m not sure what to check. I looked around for any signs of leaks but couldn’t find any. Should I try bleeding again?
  2. Jan 29, 2025 at 10:05 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You must have a leaky return line. Pulling in air and causing the pump cavitate and make that whiny noise.
    Hunter gatherer and Kwikvette like this.
  3. Jan 29, 2025 at 10:51 AM
    Riley0226
    98’ Tacoma sr5 4x4
    Which one is the return line?
  4. Jan 29, 2025 at 10:53 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This.
    Air is being sucked in.
  5. Jan 29, 2025 at 10:56 AM
    koditten
    Kirk
    Central Michigan
    I don't know exactly. Id start by looking for oil seepage.
  6. Jan 29, 2025 at 11:02 AM
    Riley0226
    98’ Tacoma sr5 4x4
    The rack has been leaking very slowly through the inner tie rod boot for about a year now but never caused me any issue. I’m guessing this is probably where the air is getting in at?
  7. Jan 29, 2025 at 11:11 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Have you bled your system at all after repairing/replacing anything steering related?
    On my Land Cruiser, I had rebuilt the power steering pump along with replacing my low pressure and high pressure lines.
    Did a quick bleed and test drive only to have it cavitate so I propped the front up, pulled the cap, and did a lot of lock-to-lock turning on my steering and topped off as needed.
    No more foam, no more whining, and my power steering was back to feeling like new.
  8. Jan 29, 2025 at 2:48 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Riley0226
    Return hose either #9 or #10
    says 4wd “serviced w/pressure tube”
    That is what is confusing
  9. Jan 29, 2025 at 2:53 PM
    ControlCar
    Steven
    Sugar Land TX
    So look at the ends of #8 and one end of #9…..they bolt into a connector (pump/hard line from rack)
    All 3 of those connectors have small O-ring that fails (leaking or sucking in air to system and making that foam u saw)
    this is common problem for Honda/Acura
    But awesome news to fix….one 10mm bolt and a $5 oring(s)
    GL
    koditten and THatt like this.
