Power rear window mod for $50!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by batt700, Apr 29, 2022.
  1. Apr 29, 2022 at 7:59 AM
    batt700
    batt700 [OP] Well-Known Member
    2017 SR5 Premium 4Runner
    Hello TW,
    I know I'm not the first person to do this mod and make the rear window powered by a switch but figured I would share anyway. For less than $50 (products linked below) and an hour of time it's a great mod.
    Simply mount the 12" stroke linear actuator on the rear window with epoxy resin for it to hold and wire the switch up and into existing button holes in dash. Also, utilize black zip ties to hold the rear window latch open.
    https://www.amazon.com/gp/product/B07L7XCSDW?ie=UTF8&th=1
    https://www.amazon.com/gp/product/B07W72XJQH?ie=UTF8
    Example picture not mine, (I'll post pics of mine tomorrow if anyone is interested):
  2. Apr 29, 2022 at 8:12 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    question, that rocker switch in your link, does it lock one way or the other. In other words, when you push the button to open the window, does the window fully open and stay there, or is it a true rocker where you push it and the window begins to open and when you release the button the window stops in place?
    Looks easy enough and probably easier then the other option that I've seen guys using to get their rear window to slide open by the push of a button.
  3. Apr 29, 2022 at 10:01 AM
    dimigon
    dimigon Active Member
    Aaron
    Vancouver Island, BC, Canada
    2013 Super White Tacoma TRD OR Access Cab
    subd. would be great if you add a write-up! Wanting to do this myself and the other methods I've read seem to be a little more involved than the product you linked.
    elioregon and batt700[OP] like this.
  4. Apr 29, 2022 at 10:11 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    From the link:
    "A maintain switch changes its position when actuated and will remain in the position until actuated again. Stays / Maintains / Latched / Lock/ Locked/ Locking in position placed."
    What you describe is a momentary switch.
  5. Apr 29, 2022 at 10:17 AM
    batt700
    It is a maintained switch that locks one way or other. you can use a momentary switch to make it like the other windows. I used a maintained switch because it takes about 5-7 seconds to open and I didn't want to click and hold. The actuator has limit switches within it so it will never go past its 12" stroke.
    davidstacoma likes this.
  6. Apr 29, 2022 at 10:24 AM
    batt700
    Will create a write-up and update and post here this weekend!
    Edit: Yeah this one is super simple and doesn't require pulling the rear glass window and such, literally only took 30 minutes to do.
  7. Apr 29, 2022 at 11:27 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Subbed for pics and a write up.
  8. Apr 29, 2022 at 11:53 AM
    KetoClutch
    KetoClutch Well-Known Member
    Whit
    Borger, TX
    2012 DCLB
    Bilstein 6112/5100, OME heavy springs, SPC UCAs, Sumimoto bumpstops, Ultimate headlight upgrade, Grille, Raptor lights, Sound deadening, foam insulation, Speakers, Sub, Head unit, Power rear sliding window, Locked center console & bed cubbies, Shark fin delete, Hood struts, Bug visor, Window visors
    subbed for pics and a write up.
  9. Apr 29, 2022 at 1:06 PM
    TRnCO
    Tim
    Elizabeth, CO
    I like the sound of it. I've been wanting to do the "slider window" upgrade for a while, and this sure looks like the easiest way to do it.
  10. Apr 29, 2022 at 1:24 PM
    batt700
    For sure, it's way easier than pulling the whole rear window and trying to retrofit an actual power rear window unit/bracket. Simply glue the two included mounts to the window and wire up the actuator to power and switch.
  11. Apr 29, 2022 at 1:25 PM
    KetoClutch
    Whit
    Borger, TX
    2012 DCLB
    Went ahead and ordered the parts, arriving Monday, so it would seem this will be a next weekend install
    Steves104x4 and Marc70 like this.
  12. Apr 29, 2022 at 5:41 PM
    TRnCO
    Tim
    Elizabeth, CO
    yep, I went ahead and ordered the parts as well.
  13. Apr 29, 2022 at 8:12 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Definitely interested since I prefer to roll the window down when it's not too hot or cold and I like leaving the rear window open when it's hot (I have a shell on the back).
  14. Apr 30, 2022 at 12:36 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Thanks for the links. Those actuators seem to have enough force to automate the side windows on my shell, will post up here if it works out.
    Steves104x4 and 007fodo like this.
  15. Apr 30, 2022 at 1:01 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Front shell slider with rear truck slider would be a nice combo
    KetoClutch and tacoma_ca like this.
  16. Apr 30, 2022 at 1:05 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    But with the latching switch, you are applying power all the time.
  17. Apr 30, 2022 at 1:09 PM
    tacoma_ca
    True until the limit switches interrupt the current. If the linear actuators seem to work in testing, I'll try momentary switches just to avoid having to rely on the limit switches.
    Marc70 likes this.
  18. Apr 30, 2022 at 3:01 PM
    batt700
    Until you pop it back to the middle position that sends no power. I wouldn't leave it on left or right selection forever, just long enough to open the window and the limit switches in the actuator prevent anymore draw. You can always run a momentary switch of course, I just didn't want to hold a switch button for 7 seconds when I could be focusing on driving away while it opens.
    davidstacoma, tacoma_ca and Marc70 like this.
  19. Apr 30, 2022 at 7:37 PM
    OldSchlPunk
    Rich
    East Central Wisco
    It's interesting, I never use the rear slider just because it's such a pain in the ass to do manually.
  20. Apr 30, 2022 at 7:46 PM
    sah3167
    sah3167 Well-Known Member
    16 Tacoma TRD Sport 4x4 DCLB
    Kicker speakers all around Remote Start Screen ProTech Bed Lighting Pro Grille
    Can you see the actuator when the seat is put back up? Would be great if it sits below the eye line
