Power mirror mod conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by slodoug, Nov 30, 2024.
  1. Nov 30, 2024 at 3:55 PM
    slodoug
    slodoug [OP] Well-Known Member
    2002 taco, sr5, 2.4l, power nothing. I have added OEM cruise, aftermarket power windows/locks and now power mirrors.
    1. mirrors used: https://www.amazon.com/dp/B0DLK75M7Q?ref=ppx_yo2ov_dt_b_fed_asin_title
    2. switch from here: https://www.amazon.com/dp/B0DHQRPN7G?ref=fed_asin_title
    but i used the front mask from an ebay switch i bought that was faulty.
    3. Wire used: https://www.amazon.com/dp/B0CFJVT74B?ref=ppx_yo2ov_dt_b_fed_asin_title
    The hard part was getting a good connection to the mirror wires, had to unseat the pins from the tiny socket and manually wire them. as long as you follow the color codes and get a switch harness off ebay that still has the wires, its pretty simple. 1st set of mirrors from https://www.amazon.com/dp/B07VVH7768?ref=ppx_yo2ov_dt_b_fed_asin_title were not only wrong drivers mirror but used boxes and the other one died.
    I have the 3d printed file to adapt so i can put anything into that clock area. Used black petg.
  2. Dec 1, 2024 at 10:13 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Question, can you also press to move them or will that break them?
  3. Dec 1, 2024 at 12:45 PM
    slodoug
    gently yes, they do move.
    treyus30 likes this.
  4. Dec 1, 2024 at 12:50 PM
    slodoug
    Laxtoy and cruiserguy like this.
  5. Dec 3, 2024 at 10:39 AM
    slodoug
    cruiserguy likes this.
  6. Dec 9, 2024 at 6:16 PM
    slodoug
    follow up, the drivers mirror was shaking but i didnt have the bolts tight enough. so far they are working great.
    Laxtoy likes this.
  7. Dec 9, 2024 at 8:07 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Nice job.
  8. Dec 29, 2024 at 8:11 PM
    slodoug
    1 more follow up, drivers side does wobble a little at high speeds. not enough for me to replace it yet though.
  9. Dec 30, 2024 at 1:34 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I had an after market TYC mirror on my passenger side for a few weeks, and I replaced it with a used OEM one because the shaking was too bad. It went away with OEM.
    I also did this conversion, manual to all power windows locks and mirrors, but I used the OEM door harnesses up to the kick panels. From there I made my own harness and control system to drive everything.
    I swapped in the 2001-2004 door panels as well, they’re a lot more ergonomic and durable than the 1995-2000 ones.
