Power inverter problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HelloFelix, Aug 19, 2021.
  1. Aug 19, 2021 at 8:11 PM
    HelloFelix
    HelloFelix [OP] Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    No power to the socket . The relay clicks , the lights on the switch won’t stay on and everything is plugged In . I can’t figure out what to check next . Any fix’s out there ?
  2. Aug 19, 2021 at 10:01 PM
    HelloFelix
    Felix
    Las Vegas
    Still nothing
    whatstcp likes this.
  3. Aug 19, 2021 at 10:39 PM
    HelloFelix
    Felix
    Las Vegas
    No , I tried that too . Hoping I don’t need a new inverter .
  4. Aug 19, 2021 at 10:51 PM
    HelloFelix
    Felix
    Las Vegas
    Thanks for the help , I’ll keep trouble shooting .
  5. Aug 19, 2021 at 11:09 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    If you’re already check the fuse and relay, now check for an open somewhere between the battery all the way to the outlet. Pretty easy with a multimeter. Your inverter is under ur center console. If your inverter is bad, might as well upgrade to a higher wattage inverter. If the new inverter doesn’t fit in the stock location, mount it behind the back seat or something. You might need new, bigger gauge wire due to higher wattage from the battery to the outlet.
    HelloFelix[OP] likes this.
  6. Aug 20, 2021 at 6:09 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Not trying to be a wise-guy here- are you using an item that draws more watts than what the outlet is rated for? Maybe try to plug in a different item and see if it that works.
    Kev250R likes this.
  7. Aug 20, 2021 at 6:49 AM
    HelloFelix
    Felix
    Las Vegas
    Haven’t been able to use it . The inverter is not powering on . And the inverter switch doesn’t stay on . Relay and fuse are good .
  8. Aug 20, 2021 at 6:57 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    How do you know the relay is good?
  9. Aug 20, 2021 at 6:59 AM
    HelloFelix
    Felix
    Las Vegas
    have a second relay both have an audible click .
  10. Aug 20, 2021 at 7:00 AM
    tirediron
    That's a good indication, but not a certainty. Have you verified the input voltages at the socket; both control and load?
    Kev250R likes this.
  11. Aug 22, 2021 at 1:33 PM
    Philipp
    Philipp Member
    Philipp
    2017 Tacoma TRD V6
    TRD
    The relay clicks...
    Seems you have a lower power on the input on the inverter than it requires to work properly...
  12. Aug 22, 2021 at 5:30 PM
    HelloFelix
    Felix
    Las Vegas
    Can you elaborate on that ? To to much technical knowledge on that. any possible fix?
  13. Aug 22, 2021 at 5:57 PM
    caribe makaira
    Caribbean, Puerto Rico
    The inverter has a fuse, the relay shares a fuse. So even if you hear a click, it's just the relay doing its thing.
    The inverter fuse:
  14. Aug 29, 2021 at 12:34 PM
    Philipp
    Philipp Member
    Philipp
    2017 Tacoma TRD V6
    TRD
    Try to check how much power (multimeter helps) do you have along the entire circuit that goes up to the inverter. And if it is less than necessary, look for the reason why...
  15. Dec 30, 2023 at 6:46 AM
    C-F
    C-F Member
    2017 Tacoma TRD
    Sorry to bump an old thread. Where is the relay located. Am having difficulty finding it
  16. Dec 30, 2023 at 7:17 AM
    caribe makaira
