Power Door Lock Assembly Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmah!, Sep 21, 2020.
  1. Sep 21, 2020 at 2:54 PM
    Timmah!
    Timmah! [OP] Well-Known Member
    TIM
    Hey My Tacoma Brothers and Sisters,
    My buddy Sean and I have another video for you. If you had a door lock actuator failure and you want to replace it, this video will walk you through the steps to do it. For my buddy Alex who's truck I used for this video, the repair unfortunately didn't work because his problem is an electrical wiring issue that I wasn't able to figure out.
    I would eventually like to figure out how to just replace the motor for these actuators like you can easily do for a 3rd Gen 4runner.
    Here's the video and Enjoy the Show!
    https://www.youtube.com/embed/78yoVyTRUHU
    Aescalon777, Winkle99 and eon_blue like this.
  2. Sep 21, 2020 at 8:25 PM
    Green Blur
    Green Blur Active Member
    Aram
    1997 Black Tacoma 3.4L 4x4 manual
    3 inch lift on 33s
    I have the strange problem of my keys not turning in the driver side door, but it will in my passenger side. So I'm always unlocking my passenger door that automatically unlocks both.
  3. Sep 21, 2020 at 8:26 PM
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    I am curious to find out if you opened the Chinese actuator assembly to see which style motor they used, the Tacoma style or 4Runner style.
    dankthetank likes this.
  4. Sep 21, 2020 at 8:54 PM
    Timmah!
    TIM
    I didn't but maybe I should have. I almost did, but since i messed up the OEM lock actuator fooling around with it, I didn't want to take a chance and screw that one up as well. I just wanted to get the door locks back working the way they were before I started messing with my buddy's rig. Even though the driver door lock doesn't lock or unlock electrically, it will send a signal to the other doors to lock and unlock when you operate the door lock with the key. It's a pretty weird issue that's going on with with his driver door lock. There's communication from the driver door lock back to the ECU to communicate with the other door locks but there's no communication the other way to tell the driver door to lock and unlock.
    Winkle99[QUOTED] likes this.
  5. Sep 21, 2020 at 10:03 PM
    dankthetank
    dankthetank Well-Known Member
    So Cal
    01 3.4L 5-spd 4x4
    Oh man, you're into the fun stuff when you start chasing electrical issues...
    The fact that the front right and rear doors lock/unlock but the front left doesn't helps narrow it down quite a bit since the front left lock is only separated from the front right lock by 2 points (splice point I5 and junction block 3B). Of course the problem could also be on the front left door lock actuator plug but you'd be back tearing apart the door to confirm that anyway.
    Green Blur likes this.
  6. Sep 23, 2020 at 2:48 PM
    Aescalon777
    Aescalon777 New Member
    A
    2002 Toyota Tacoma
    Hey Tim,
    Appreciate your detailed video.
    I am currently attempting to replace my 2002 Tacoma driver side door actuator. Not necessarily the whole actuator. The motor is (surprisingly) working but the interior plastics gears are worn.
    The actuators are so expensive.
