Post your superstrut/strut channel photos and ideas.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Volt, Nov 19, 2018.
  1. Nov 19, 2018 at 9:33 PM
    Volt
    Volt [OP] Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I work in a large industrial facility. We put quite a few things together with superstruts. In fact superstuts are used extensively at my work. A superstrut is a metal channel strut beam that can be used in a lot of creative ways. You can get all sorts of attachments for them. They are similar to the slot rails on the Tacoma.
    I can dumpster dive at my work and get discard superstruts without much effort. So I am trying to come up with ideas for using superstruts with my Tacoma.
    If you have done something with superstruts with your Tacoma can you post some photos? Ideas?
    https://www.homedepot.com/b/Electrical-Electrical-Boxes-Conduit-Fittings-Struts/N-5yc1vZbm55
  2. Nov 19, 2018 at 10:02 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I work in telecommunications and unistrut is the building material of choice... way over used... hate that stuff.
    Skydvrr likes this.
  3. Nov 19, 2018 at 10:20 PM
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    If you have stainless go for it. If it's galvanized keep it way. Any piece of strut I've worked on that has see weather rusts and corodes Pronto.
    But to maybe get some wheels spinning this is a dinghy holder slide I built a few years back. Mounted on the swimstep of a larger boat and allowed the tender to be slid forwards and rolled a little to the side to move the CG and give a better ride when underway.
    TacoManOne, ShirtTucker and Volt[OP] like this.
  4. Nov 20, 2018 at 7:04 AM
    GMP
    GMP Well-Known Member
    Glenn
    2018 DCSB TRD OR Quicksand
    I'm planning a bed rack fab from it. Kayaks or cargo basket, plus outboard mtn. bike mounts. For vacation travel/camping, no hard off roading. Should be fine, hold up when primed and painted, and cheap. For this occasional, basic light duty use, no RTT, this makes a lot more sense than a commercial bedrack, which is stupid $$.
  5. Nov 20, 2018 at 7:37 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    That fine piece of engineering does not fit with your username. :thumbsup:
  6. Nov 20, 2018 at 2:17 PM
    Volt
    I'm mulling maybe something for bicycles.
  7. Nov 20, 2018 at 2:19 PM
    DrFunker
    DrFunker Well-Known Member
  8. Nov 20, 2018 at 4:51 PM
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    The user name is there to cover my ass when the engineering is not so fine
  9. Nov 20, 2018 at 5:10 PM
    GMP
    Glenn
    With nothing else in the bed I use Rocky Mounts fork mounts in the front channel I added for two mtn bikes. For kayaks or a cargo basket and bikes, I'll use the same fork mounts on short Unistrut extensions outboard of the main rack, in line with the bed rail of the truck.
    Volt[QUOTED][OP] likes this.
  10. Nov 20, 2018 at 6:26 PM
    soft-taco
    soft-taco Member
    Do they really have to call it "Super White II"?
    38 miles on it so nothing yet.
    I'm working on a design for a bed rack made with unistrut. I'll probably use aluminum for the ease of cutting and corrosion resistance. I think I can replicate an "overland" style rack for pretty cheap.
  11. Nov 20, 2018 at 6:49 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
  12. Nov 21, 2018 at 6:37 AM
    GMP
    Glenn
    I agree it can be done well for a reasonable price. I plan on using the Unistrut angle connectors just as a guide/holder, and welding the basic structure. Only have a stick welder so aluminum is out. Zinc Chromate marine primer and bed coating will be fine on the steel. It will be about 6 inches high with the uprights at 45 deg angles, so it clears the bikes on outboard mounts. Kayaks when carried will sit in mounts I already have attached to the rack, more rearward off the back of the truck rather than over the cab. I can also add a cheap basket if needed, as well as ski racks I have. Universal. I will also design adapters so it can be used on top of a utility trailer if needed.
  13. May 19, 2019 at 12:33 PM
    mattlock38
    mattlock38 New Member
    East Alabama
    '19 SR5 Magnetic Grey
