Possible totaled brand new 2019 Toyota Tacoma!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by andrearobertsxo, Apr 11, 2019.
Frame bent?
  1. Yes
    138 vote(s)
    87.9%
  2. No
    22 vote(s)
    14.0%
Multiple votes are allowed.
  1. Apr 11, 2019 at 1:25 PM
    #61
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Did a quick quote for the parts I think the truck will need (see below), about $23,000 in parts if they don't repair any panels and don't use any aftermarket or used parts. The truck is probably worth around $38,000, so that leaves somewhere in the $6,000-10,000 range for labour, which seems relatively reasonable.
    Would love to see an update on what the insurance company does, but it could be repaired in my opinion.
    Jeff
    Part Number Qty Description Price Price-Ext
    63111-04190 1 Roof skin $ 796.55 $ 796.55
    53301-04220 1 Hood $ 552.89 $ 552.89
    53393-04010 1 Hood Protector $ 11.09 $ 11.09
    53510-04070 1 Hood Latch $ 83.61 $ 83.61
    53825-04010 1 Fender Protector RH $ 50.02 $ 50.02
    53826-04010 1 Fender Protector LH $ 50.02 $ 50.02
    53811-04120 1 RH Fender $ 311.18 $ 311.18
    53812-04120 1 LH Fender $ 311.18 $ 311.18
    53875-04080 1 RH Fender Liner $ 90.85 $ 90.85
    90189-06236 26 Fender Liner Clips $ 1.24 $ 32.24
    90467-07215 2 Fender Liner Clips $ 1.26 $ 2.52
    75871-04060 1 RH Fender Flare $ 217.02 $ 217.02
    53853-04070 1 RH Fender Flare Pad $ 13.62 $ 13.62
    53851-04100 1 RH Fender Flare Pad $ 2.16 $ 2.16
    53855-04010 1 RH Fender Flare Pad $ 16.38 $ 16.38
    75395-35070 16 Fender Flare Clips $ 3.53 $ 56.48
    75396-35020 22 Fender Flare Clips $ 1.24 $ 27.28
    65500-04460 1 RH Bed Side Panel $ 699.36 $ 699.36
    65600-04400 1 LH Bed Side Panel $ 699.36 $ 699.36
    77305-04080 1 Fuel Filler Door $ 56.00 $ 56.00
    76925-04040 1 RH Bed Side Panel Protector $ 22.61 $ 22.61
    76926-04040 1 LH Bed Side Panel Protector $ 22.61 $ 22.61
    75996-0C080-A2 2 Bed Side Panel "TRD Off Road" Decal $ 80.62 $ 161.24
    51405-04010 1 Front Skid Plate $ 231.15 $ 231.15
    52119-04907 1 Front Bumper Cover $ 273.92 $ 273.92
    52161-02020 6 Front Bumper Cover Upper Clips $ 2.70 $ 16.20
    53879-28010 2 Front Bumper Cover to Fender Liner Retainers $ 6.41 $ 12.82
    90467-05138 2 Front Bumper Cover Lower Clips $ 3.96 $ 7.92
    90189-06234 2 Front Bumper Cover Lower Clips $ 0.98 $ 1.96
    52115-04070 1 RH Front Bumper Cover to Fender Retainer $ 31.63 $ 31.63
    52116-04070 1 LH Front Bumper Cover to Fender Retainer $ 31.63 $ 31.63
    75101-04011 1 Front Bumper License Plate Bracket $ 13.82 $ 13.82
    53112-04050 1 Front Bumper Grille $ 61.89 $ 61.89
    53911-04210 1 Front Bumper Valance $ 186.62 $ 186.62
    75392-04010 2 Front Bumper Valance Retainers $ 2.04 $ 4.08
    52521-04060 1 Front Bumper Upper Retainer $ 49.51 $ 49.51
    53273-04040 1 RH Front Bumper Mounting Arm $ 36.17 $ 36.17
    53274-04040 1 LH Front Bumper Mounting Arm $ 36.17 $ 36.17
    52611-04010 1 Front Bumper Absorber $ 59.25 $ 59.25
    52131-04031 1 Front Bumper Reinforcement Bar $ 196.49 $ 196.49
    52025-04010 1 RH Front Bumper Rebar Extension $ 158.63 $ 158.63
    52026-04010 1 LH Front Bumper Rebar Extension $ 158.63 $ 158.63
    52137-04050 1 RH Front Bumper Rebar Inner Arm $ 31.17 $ 31.17
    52138-04040 1 LH Front Bumper Rebar Inner Arm $ 31.17 $ 31.17
    52127-04020 1 RH Fog Lamp Cover $ 35.05 $ 35.05
    52128-04020 1 LH Fog Lamp Cover $ 35.05 $ 35.05
    81210-02160 1 RH Fog Lamp $ 210.92 $ 210.92
    81220-02160 1 LH Fog Lamp $ 210.92 $ 210.92
    52155-04900 1 RH Rear Bumper Cover $ 118.85 $ 118.85
    52153-04010 1 RH Rear Bumper Stay $ 242.24 $ 242.24
    53101-04040-A0 1 Radiator Grille $ 395.37 $ 395.37
    52161-02020 2 Radiator Grille Clips $ 2.70 $ 5.40
    53141-71010 1 Radiator Emblem $ 413.54 $ 413.54
    53707-04900 1 RH Fender Apron $ 383.06 $ 383.06
    53705-04900 1 RH Fender Apron to Fender Member $ 117.57 $ 117.57
    53835-04010 1 RH Fender Apron Member to Fender Brace $ 9.02 $ 9.02
    90080-46327 20 Fender Apron Protector Clips $ 1.47 $ 29.40
    53293-04010 1 RH Radiator Deflector $ 89.21 $ 89.21
    53294-04010 1 LH Radiator Deflector $ 89.21 $ 89.21
    90467-07215 2 Radiator Deflector Clips $ 1.26 $ 2.52
    53028-04010 1 RH Radiator Support $ 102.89 $ 102.89
    53721-04020 1 RH Radiator Support Bracket $ 29.16 $ 29.16
    53257-04020 1 RH Radiator Support Bracket $ 13.48 $ 13.48
    53202-04010 1 RH Radiator Support Bracket $ 36.63 $ 36.63
    53209-04030 1 Vertical Hood Latch Support $ 15.86 $ 15.86
    57104-04040 1 Radiator Lower Support Cross Member $ 168.98 $ 168.98
    57167-04010 1 RH Lower Cross Member Bracket $ 22.81 $ 22.81
    57168-04010 1 LH Lower Cross Member Bracket $ 22.81 $ 22.81
    56101-04081 1 Windshield $ 566.13 $ 566.13
    75551-04080 1 RH Roof Drip Rail Moulding $ 110.39 $ 110.39
    75561-02020 4 Roof Drip Rail Moulding Clips $ 1.67 $ 6.68
    61131-04071 1 RH A-Pillar $ 291.35 $ 291.35
    61108-04030 1 RH A-Pillar Reinforcement $ 338.90 $ 338.90
    61411-04071 1 RH B-Pillar $ 297.84 $ 297.84
    61611-04071 1 RH C-Pillar $ 488.12 $ 488.12
    61412-04071 1 LH B-Pillar $ 297.44 $ 297.44
    61612-04071 1 LH C-Pillar $ 488.12 $ 488.12
    68101-04120 1 RH Door Glass $ 216.04 $ 216.04
    67001-04210 1 RH Front Door $ 776.72 $ 776.72
    67113-04040 1 RH Rear Door Skin $ 364.93 $ 364.93
    67114-04040 1 LH Rear Door Skin $ 364.93 $ 364.93
    75921-04010 1 RH Front Door Blackout Tape $ 34.22 $ 34.22
    75922-04010 1 LH Front Door Blackout Tape $ 34.22 $ 34.22
    75923-04010 1 RH Rear Door Blackout Tape $ 32.24 $ 32.24
    75924-04010 1 LH Rear Door Blackout Tape $ 32.24 $ 32.24
    75427-04030 1 RH Door Nameplate $ 56.72 $ 56.72
    75428-04010 1 LH Door Nameplate $ 56.72 $ 56.72
    73210-04260-C0 1 RH Front Seat Belt $ 274.86 $ 274.86
    73220-04260-C0 1 LH Front Seat Belt $ 274.86 $ 274.86
    89173-09491 2 Front Airbag Sensors $ 117.14 $ 234.28
    45130-04140-C0 1 Steering Wheel Airbag $ 783.17 $ 783.17
    62170-04050 1 RH Curtain Airbag $ 1,551.66 $ 1,551.66
    62180-04050 1 LH Curtain Airbag $ 1,551.66 $ 1,551.66
    81110-04270 1 RH Headlamp $ 786.68 $ 786.68
    81150-04270 1 LH Headlamp $ 786.68 $ 786.68
    53271-0B010 2 Headlamp Brackets $ 12.58 $ 25.16
    90189-05142 4 Headlamp Clips $ 1.24 $ 4.96
    81560-04181 1 LH Tail Lamp $ 196.18 $ 196.18
    82114-04010 1 Front Bumper Wiring Harness $ 70.19 $ 70.19
    89747-0R020 1 Keyless Entry Buzzer $ 72.41 $ 72.41
    86510-0E040 1 High-Pitched Horn $ 77.81 $ 77.81
    86520-0E020 1 Low-Pitched Horn $ 77.81 $ 77.81
    87910-04240 1 RH Rearview Mirror $ 387.14 $ 387.14
    87915-04070-A0 1 RH Rearview Mirror Cap $ 52.18 $ 52.18
    43211-04060 1 RH Steering Knuckle $ 410.64 $ 410.64
    48610-04021 1 RH Upper Control Arm $ 401.91 $ 401.91
    48068-04060 1 RH Lower Control Arm $ 371.89 $ 371.89
    48510-8Z253 1 Front Shock Absorber $ 121.14 $ 121.14
    88450-04011 1 Condenser $ 426.62 $ 426.62
    16410-0P300 1 Radiator $ 380.93 $ 380.93
    TOTAL $ 22,891.82
  2. Apr 11, 2019 at 1:29 PM
    #62
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Wow you got a lot of time on your hands
  3. Apr 11, 2019 at 1:29 PM
    #63
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Sorry to see this. Hope you walked away without injury.
    Start shopping for a new rig
    Welcome to the forum
  4. Apr 11, 2019 at 1:31 PM
    #64
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    For sale, clean title, air blows cold
  5. Apr 11, 2019 at 1:34 PM
    #65
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Somebody needs to get a life... ;)
    drewskie likes this.
  6. Apr 11, 2019 at 1:35 PM
    #66
    Jeff Lange
    Calgary, Canada
    I like to pretend I'm a parts guy.
    Jeff
  7. Apr 11, 2019 at 1:39 PM
    #67
    mbarbay
    mbarbay Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    I didnt read all of it, but did you account for the TSS sensors? and the costs to recalibrate them.....i just had to have my BSM recalibrated to the tune of $273, just for the calibration.
  8. Apr 11, 2019 at 1:42 PM
    #68
    Jeff Lange
    Calgary, Canada
    Picture 1 and 2 show the grille and emblem intact, so the TSS sensor should be fine, ditto for the camera on the windshield. Recalibration would be a labour item if required, but assuming the same sensor is reused (it should be), recalibration should not be required.
    Jeff
  9. Apr 11, 2019 at 1:58 PM
    #69
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    If insurance estimates could be done over a forum from 3 photos, adjusters would be out of a job. That being said, a lot of the people in this thread have no idea what they are talking about. Nothing is an "automatic total." Airbags deployed, rollover, frame damage can all be repaired, and insurance companies do it regularly. Pretty much the only determining factor in totaling a car is if the cost of repairs(and chance of future repairs) is more than the payout for totaling(or whatever percentage they have set). That's it. Considering its a brand new ~$35k truck, you can repair a lot for 70%. I wouldn't be surprised if they total it, but also wouldn't be surprised if they wanted to repair.
    hellppy, ET340f and FLA_Hoosier like this.
  10. Apr 11, 2019 at 2:24 PM
    #70
    Sungod
    Sungod Well-Known Member
    St Augustine
    I don't see a slow speed roll over causing a bent frame, but that is the least of your worries. If it isn't totaled, you have a very optimistic estimator.
    AxisCab likes this.
  11. Apr 11, 2019 at 2:28 PM
    #71
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Did the same in my last 1st gen and it was 12k for the fender to bedside. Couldn't imagine the cost involved on a newer truck. I vote shes a goner. OP glad you are ok, the truck can be replaced.
  12. Apr 11, 2019 at 2:33 PM
    #72
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    It'd be fine except for the stain in the driver seat!
  13. Apr 11, 2019 at 2:34 PM
    #73
    andrearobertsxo
    andrearobertsxo [OP] Member
    Andrea
    2019 Toyota Tacoma TRD off road 4x4
    Adjuster just called, truck is totalled! Got good news. Said we will get everything we paid for it..down payment, tax license, everything. We put a lot down so that was stressing me out!
    styk, splitbolt, Paul631 and 16 others like this.
  14. Apr 11, 2019 at 2:38 PM
    #74
    5500
    5500 Active Member
    Ed
    Cape Cod
    2019 Cement Sport
    Great news. You're ok, your investment is safe and you get to buy another new truck..... Woooo Hoooo…. 2 new Tacos in a month!
  15. Apr 11, 2019 at 2:50 PM
    #75
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Buy that truck back from insurnce and drop it off to get a roll cage, full fiberglass and long travel.
    hellppy likes this.
  16. Apr 11, 2019 at 2:51 PM
    #76
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    Frame not bent but definitely a write off.
  17. Apr 11, 2019 at 3:16 PM
    #77
    TacomaIvan19
    TacomaIvan19 Well-Known Member
    2019 TRD Sport
    Tailgate Inserts Black Weather Tech Mats Rekgen Mud Flaps
    Yep, I hear them sum biches are expensive. On the other hand it sounds like the truck did a good job of protecting you from serious injury. They will make more trucks. Unless you have a twin there's only one of you!
    5500 likes this.
  18. Apr 11, 2019 at 5:55 PM
    #78
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Glad you can type. Totaled
  19. Apr 11, 2019 at 7:16 PM
    #79
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    :thumbsup: Thank you… copied and paste for future reference. It’s always good to have pt#s
    Dakotataco77 likes this.
  20. Apr 11, 2019 at 7:19 PM
    #80
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Hope you're okay. It's just a truck that insurance can take care of. As long as you're good, then can always buy another!
