Possible to roll all the windows down with the key fob?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TejasTaco, May 18, 2017.
  1. May 18, 2017 at 9:24 AM
    TejasTaco
    TejasTaco [OP] Grab a taco
    Hello,
    I did some searches and didn't manage to turn up the answer I am looking for so here's the question.
    Is it possible to program the truck to roll all the windows down via key fob press?
    I already have the Veepeak OBD2 adaptor and Carista app. I don't see this as an option in the configurable options. I did program my 4Runner and would like to do the same thing with the Taco.
    Anyone have this set on your Tacoma?
  2. May 18, 2017 at 9:27 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Unfortunately there in no option to program all windows down on the Tacoma.
    Love this option on my 4Runner.
  3. May 18, 2017 at 11:10 AM
    TejasTaco
    Bummer. Thanks for confirming.
  4. May 19, 2017 at 10:43 PM
    TejasTaco
    Next question...
    Is it possible to roll down any windows when the truck isn't running?
    So, a window like the drivers window from the fob?
    Or the drivers window and back drivers side window from the opened drivers door?
    The issue here is Texas heat and coming back from a dog walk. With the 4Runner I can remotely roll down the windows.
    Is it possible to roll any combination of windows down without having to jump in the drivers seat, press the brake peddle and hit start?
    Thanks!
  5. May 20, 2017 at 6:04 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    I've not looked into anything specific on this 3rd gen or otherwise for aftermarket alarm installs but you should be able to do it with an aftermarket alarms auxiliary option. I was always partial to the Compustar branded devices. Their higher end features can be found on their drone mobile.
    TejasTaco[QUOTED][OP] likes this.
  6. Oct 2, 2023 at 5:23 PM
    JakeSouliere
    JakeSouliere Active Member
    2022 Red Tacoma Sport Prem
    All stock.
    To roll down or up the windows you only need to be in accessory mode. The vehicle does not need to be running, or at least my ‘18 RAV didn’t. To enter ACC mode with the fob, do NOT press the brake, just press Start once. This will turn on all the accessories without turning on the engine. You do not need to be in the driver seat, nor pressing the brake unless you want to start the engine. Then just press it again to turn off the ACC, or press the brake and Start to fire up the engine. I can’t try it out on my ‘22 Taco because it has an actual key.
  7. Oct 2, 2023 at 5:27 PM
    Glaese
    Glaese Unknown Member
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Lol you don’t say
  8. Oct 2, 2023 at 5:32 PM
    JakeSouliere
    All stock.
    Yup I do.
    Maybe I misunderstood the 3rd question twice removed.
  9. Oct 2, 2023 at 5:39 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    OP
    Stevie17 likes this.
