Possible to replace the entire extended cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Iamderanged!, Mar 15, 2022.
  1. Mar 15, 2022 at 4:02 PM
    Iamderanged!
    Iamderanged! [OP] New Member
    1994 Toyota DLX 6 4x4
    Lots of rust! 31x10x15 tires frame repairs 9 years of new parts.230000 miles
    Just saw my truck on lift where tech pointed out that all inner rockers, floor panels, and mounts are rotting out! Is it possible to replace the entire extended cab? or do I finally have to bid my Toyota Farewell? Just spent 2 grand last summer on frame repairs! I could salvage my doors but that's about all that could be saved from the cab. I will either repair and hang onto it, or with regret, advertise it for others to enjoy Haven't found anyone in New England that has an entire cab worthy of transplanting. Any suggestions for finding one are appreciated. Thanks.
  2. Mar 15, 2022 at 4:05 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Sorry for your loss
  3. Mar 15, 2022 at 4:14 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    There's a few folks on here who have done it. It's a good amount of work, but certainly doable.
  4. Mar 15, 2022 at 4:39 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    There is a guy in Sanbornville NH that has all of the first gen tacomas in New England. All jokes aside he does have a bunch of tacomas and 4Runners from what I can tell. If I were in your position I’d hit him up for a clean cab.
    He has a bunch of ads on Facebook. Here is one Id have to dig, but I remember there being a red extra cab for 2k. Looked real clean but the frame was split in half
    StihlToyota and foothill96tacoma like this.
  5. Mar 15, 2022 at 4:54 PM
    lowtaco94
    lowtaco94 Well-Known Member
    Jeff
    Maryland
    96 Toyota Ext Cab V6 4x4/ 99 Toyota Ext Cab V6 2wd/ 94 Toyota Pickup Bagged & Bodydropped
    96 Toyota - Current Project - 99 Toyota V6, 5 speed, Bagged, Back Halfed w/ 5 link suspension, 20" Boyd Wheels, Supercharged, URD Software. 94 Toyota 22RE, Bagged, Bodydropped on 20's w/ heat and a/c. Suicide Doors, sliding rag top, paint, interior.
    Swap cabs? I see guy on marketplace parting out these trucks fairly often.
  6. Mar 15, 2022 at 5:00 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Is it fully insured with comprehensive coverage?
  7. Mar 15, 2022 at 6:07 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Possible? Absolutely. But if you're going to pay someone to do this, it's going to be dozens and dozens of billable hours. This is not a cheap endeavor, unless you do it youself.
  8. Mar 15, 2022 at 8:36 PM
    Jeremy Martin
    Jeremy Martin Well-Known Member
    1st Gen Taco
    Rust is not a covered loss. Cab swaps are doable, body shops do frame swaps all the time and a good body tech can get it done in two days or less. A lift really does make it much easier. With the time and cost of the replacement cab it might just be better to sell it and find a clean replacement truck.
  9. Mar 15, 2022 at 8:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    With that much body rust, I'm betting that's not the only rust on your truck.
    Usually, it's the frame that rusts out first, at least judging by the number of rusted frames with near perfect bodies I've seen, so I'd be especially concerned about that, too.
    So yes, body swaps or panel replacements are absolutely doable. But just be prepared to get half way into the project and find out it's FUBAR.
    TACOTU3 and Jeremy Martin like this.
  10. Mar 15, 2022 at 8:54 PM
    01 dhrracer
    Still Shopping
    A unfortunate accident might be.
    MalinoisDad likes this.
  11. Mar 15, 2022 at 8:54 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    How much work can you do?? Paying Labor this will get real expensive.
    You might need to go pretty far south to find a new cab.
    It would be possible to build a whole new floor pan and weld it to what you have .
    I did quite a Few Ford and Chevy 4x4`s over the years The cabs rusted the frames lasted for ever.
    Good Luck.
  12. Mar 17, 2022 at 11:35 AM
    choopes
    choopes Well-Known Member
    Troy, Al.
    2004 reg cab
    Stock
    As a very last resort, you could get a salvage 1st gen with a good cab from Coparts. I say last resort because it is expensive. Lots of hidden costs. Cheaper to find one at a salvage yard, but my experience is they are hard to find, and usually all parted out, if you do find one.
    It is possible to build a gantry out of lumber you can buy at Lowes, if you have space and are inclined. If you are forced to abandon this one due to rot, hunt your next one from a non rustbelt state.
    Good luck to you in your quest.
  13. Mar 17, 2022 at 7:04 PM
    1965chevy
    1965chevy Active Member
    Wyoming
    1997 tacoma was a single cab
    If you know someone with a tractor or excavator ect. Some sort of lifting equipment. Or even a large tree and a chain hoist. You can swap out the cab relatively easily. The hard part is pulling the dash apart and then getting it back together. And finding a cab would be difficult with the price of tacos now a days. 20201115_132959.jpg
    Steves104x4 likes this.
  14. Mar 31, 2022 at 11:52 PM
    Dalé_Tha_truth_speaka
    Dalé_Tha_truth_speaka Active Member
    Buddy you posted this at the right time. I just finished my cab swap. I have a 1998 2.7 4 cyl. Im going to start a thread on it because its turned into an entire build but feel free to DM me with any questions. Ill be posting a full write up sometime over the next couple weeks but ill give you a few teaser pics and link it when i post.
    Area51Runner likes this.
  15. Apr 1, 2022 at 3:20 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Pulling the dash/interior is the easy part (I've pulled many dashes when I worked at Lexus). I think the difficult part would be how to lift/support the cab after unbolting it from the frame.
