Possible leaking H***g****t. Need tried and true block tester.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hockeyplayer79x, Oct 30, 2021.
  1. Oct 30, 2021 at 5:22 PM
    hockeyplayer79x
    hockeyplayer79x [OP] Member
    Nicholas
    05 tacoma SR5 CC LB 4x4
    Having my first problems with the notorious 05 head gasket. Overheated the other day, low coolant, filled on the road and drove home. Today I was burping the system when the bubbles kept coming and the dark realization of what the problem is sank in. I want to test coolant but I’ve seen mixed reviews on the block testers. Which work? Any advice helps
    steelcity2 likes this.
  2. Oct 30, 2021 at 5:38 PM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    I’ve found that it depends less on the actual tester, more on the quality of the liquid used to check for combustion gasses. I had good luck with the BT-700 tester off Amazon. Purchased it when I couldn’t find my old (no idea what brand) unit.
    Works great. Of course, my old one turned up to be right where I left it after the new one showed up.
    wi_taco likes this.
  3. Oct 30, 2021 at 8:21 PM
    Waasheem
    Waasheem
    2007 xrunner
    I think a block tester is the best method, what shaeff says makes sense regarding the quality of test fluid. Draining the motor oil to check for milky oil is another way. I’ve heard others say to look at the piston tops, see if any look steam cleaned from coolant leaking in. Others say to use a leak down tester, then watch for bubbles coming up in the radiator. When I had one go out, I was getting temp needle sorta bouncing all over and bubbling reservoir. Sure enough, upon disassembly the gasket was chewed. Iron block and aluminum head, dissimilar metals expanding and contracting at different rates.
  4. Oct 31, 2021 at 4:05 PM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    Another good way to check is give the coolant a smell. If you're getting combustion gasses in there, you'll know.
  5. Nov 3, 2021 at 7:49 PM
    hockeyplayer79x
    Nicholas
    SUCCESS WITH THE BLUE DEVIL!!(for now) Can’t believe it works! Thought I was wasting 70 bucks and 6 hours taking all the steps. Will keep updates on how long it lasts!
    First pic: Before treatment, while engine ran got constant never ending bubbles.
    (I know it requires pink fluid, I just bought the truck a few months ago I didn’t put it in)
    Second pic: after treatment, Zero bubbles while running, might look like bubbles but it was just a whirlpool. Couldn’t figure out how to upload videos.
  6. Nov 3, 2021 at 8:28 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    gnarly....i have an issue like this but the bubbles are a lot less and only happens after I drive the heck out of the truck and get the load up on the engine. wht is the blue devil supposed to do? how does it stop the leak?
  7. Nov 4, 2021 at 6:15 AM
    hockeyplayer79x
    Nicholas
    So the chemical is liquid glass and when it gets really hot, from the exhaust gas leaking, it hardens and clogs the leak.
    11 minutes into the video he’ll show a demonstration.
    https://m.youtube.com/watch?v=q3_kDiQb7lE
  8. Nov 7, 2021 at 5:54 PM
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    glad it worked. how many miles on the truck when it went?
  9. Nov 7, 2021 at 6:17 PM
    hockeyplayer79x
    Nicholas
    I spoke too soon, bubbles came back the next drive. And somewhere around 180k. The odometer broke two years ago so I dont know how many miles are on it. I think I’m gunna try one more gasket sealer before I commit to dig into the engine and replace the gasket.
