Porter-Cable 7424XP 6-Inch Variable-Speed Polisher
Discussion in 'Detailing' started by bonfire, May 16, 2011.
  1. May 16, 2011 at 10:29 AM
    bonfire
    bonfire [OP] Well-Known Member
    Seattle WA
    TRD Sport LB
  2. May 16, 2011 at 10:45 AM
    sxgt
    sxgt Member
    03 DC SR5 4WD TACO
    I havent used mine alot - but I use UBER pads from Detailers Domain. I have been very pleased with them. The main reason I chose them is that reviewer indicated the hook/loop backing doesnt come off like some pads. The only down side is you have to get them from a specialty provider.
  3. May 16, 2011 at 10:59 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    That is a very good machine. If you buy a 5in backing plate then you can use just about any hook and loop pad 5-6in. I recommend checking out detailedimage for any detailing supplies.
  4. May 17, 2011 at 1:01 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I would stick with Lake Country Mfg Pads. Although they offer a wide range of pads, I would stick w/ the 5.5" pads on a 5" flexible backing plate. I still prefer the ccs ones, however, flat or hydrotech will work equally as well.
