Portable Air Compressor Suggestions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Law950, Nov 8, 2020.
  1. Nov 8, 2020 at 12:13 PM
    Law950
    Law950 [OP] Well-Known Member
    Ed
    2017 White Tacoma TRD Off Road
    Leveled with Icon Stage-3 suspension Toyo Open Country MT's, (LT265/75/R16) TRD Performance Exhaust TRD performance Air Intake
    Can anyone recommend a portable, compact air compressor that is durable and quality made? I know there a many out there on the market, and I'd like to start carrying one but I don't have much experience with owning one of these. For portability, I'd like it to come with it's own case and easily power up via the battery or cig lighter, is there one out there that most here would recommend? I'm running 33 inch Toyo Open Country MT's on a 2017 TRD-OR.
    tacotoe likes this.
  2. Nov 8, 2020 at 12:18 PM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    Viair is a good brand. Get one that fits your budget.
    gillies66, dc7rr1, LoMa and 2 others like this.
  3. Nov 8, 2020 at 4:02 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I’ve got two cheap ones on the shelf waiting for me to try and fix them after they died.
    With air compressors you get what you pay for, spend the money and buy a decent one from a good name like Viair.
  4. Nov 8, 2020 at 5:26 PM
    Juliet Lima
    Juliet Lima Well-Known Member
    I have the smittybuilt version of the viair....
    https://www.partsengine.ca/2781-vp-...MIlY_1rZ707AIVQiCtBh2X5AtwEAQYASABEgJ9H_D_BwE
    The only reason I got the smitty was the price at the time....it is a rebranded product and they are identical.
    It’s a good unit and airs up tires pretty quick. Decent quality but like all compressors it will get hot doing 4x35’s
    Speaking of identical, the hose fittings are some weird metric size and the hose sucks as does the tire chuck.
    I cut the hose and fitted 1/2” quick connects and made my own hose. Using the tire filler with gauge that came with my arb.
    Speaking of....does anyone make a tire chuck with gauge that is accurate? I’ve had several and the built in gauge is always off by 10-15 psi???
  5. Nov 12, 2020 at 8:29 PM
    rrtx.tacotrd4x4
    rrtx.tacotrd4x4 Well-Known Member
    Round Rock, TX
    2018 Cement DCSB TRD OR 4x4
    IVD Suspension Stage3 | 17x8.5 Icon Alloys Rebound Wheels | Toyo Open Country M/T 285/70R17 | TRD Pro Grill | SSO Slimline tube bumper | Smittybilt X20 Gen2 winch | Baja Designs Squadron R-Sports | upTOP Overland Bravo Roof Rack | DiamondBack HD Bedcover with FrontRunner Load Bars | CaliRaised LED Ditch Lights
    Looking for options too and might look into the smittybilt version.
  6. Nov 12, 2020 at 9:19 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Law950[OP] likes this.
  7. Nov 12, 2020 at 9:33 PM
    Jyruiz
    Jyruiz Well-Known Member
    Juan
    La Mirada, CA
    2021 DCLB Off-Road 4x4
  8. Nov 12, 2020 at 10:01 PM
    brian2o0o
    brian2o0o Well-Known Member
    South Carolina
    2016 Quicksand TRD off-road
    ARE Cx HD camper shell 2” lift OME 887s with 5100s Weathertechs Bartact seat covers CVT RTT CVT awning Prinsu Cab rack Dometic CFX40 fridge/freezer Decked drawers SOS Concepts sliders SOS Concepts rear bumper/swingout Body Armor front bumper Superwinch 10k winch Lots of MESO and other smaller stuff
  9. Nov 13, 2020 at 7:13 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Another vote for Vair (88P) here. I like that it connects directly to the battery (although even on the cheapy's I cut-off the cigarette lighter plug and put on a set of Alligator clips). The Vair is also rated for 100% Duty Cycle, which some (/most) of the others in this category are not. Fair warning though, it's still slow. My off-road car has 33" tires in the rear, 31" in the front and the last time I used my Vair to re-fill my tires from 20 PSI to 40 it took ~40 Mins.
  10. Nov 13, 2020 at 7:22 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    MasterFlow MF1050 and variants is also a popular setup.
    RyanDCLB likes this.
  11. Nov 13, 2020 at 7:31 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I went with this air chuck. Just tested it out a couple days ago. It was pretty accurate compared to the TPMS on the dash. Within 1psi. https://www.amazon.com/gp/product/B076M3CLGR/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
    I can also vote for Viair. I had a 400p for a while. Worked every time I needed it. The things I disliked were having to dig it out and hook it up when I needed to use it and how hot it got. So I swapped it out for an ARB twin. Always hooked up. Just push a button and plug in the air line. Good to go.
  12. Nov 13, 2020 at 7:42 AM
    CortezJB
    CortezJB Well-Known Member
    Juan
    San Francisco
    2017 Tacoma TRD Sport
    NADA
    Yep!! ARB is a good option. here is my set up
  13. Nov 13, 2020 at 7:45 AM
    Law950
    Ed
    Damn...that looks nice! How difficult is it to set it up cleanly the way you did for a novice?
  14. Nov 13, 2020 at 7:50 AM
    T4RFTMFW
  15. Nov 13, 2020 at 7:51 AM
    LostHusker
    LostHusker Just one day at a time
    Mark
    South, TX
    2021 F150, 2015 T4R
    Looks good, which mounting plate did you go with?
    BTW, your engine compartment is toooo clean..:laugh:
  16. Nov 13, 2020 at 7:53 AM
    shaggy135
    It's a lot easier if you remove the air filter box. Just a couple bolts there and pull. Then route the cables along the firewall with everything else. Hardest part is popping a wire through for the button to turn it on. Unless you just service mount it somewhere under the hood.
    Law950[QUOTED][OP] likes this.
  17. Nov 13, 2020 at 7:59 AM
    NWTacoTime
    NWTacoTime Well-Known Member
    Nate
    WA - Seattle/Kent
    Cement SB 2019 TRD offroad -
    Car Seats
  18. Nov 13, 2020 at 9:13 AM
    CortezJB
    Juan
    San Francisco
    NADA
    This !!
  19. Nov 13, 2020 at 9:18 AM
    CortezJB
    Juan
    San Francisco
    NADA
    U used the SLEE compressor Mount, it worked out good and easy to install.
    https://sleeoffroad.com/products/sok0038/
    and yes the engine is too clean, I can't help it!! lol!!
  20. Nov 13, 2020 at 9:24 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    CO2 is the way to go. Either something like Power Tank sells or some thing like I did.
    tacotoe likes this.
