Portable air compressor for your truck
Discussion in 'Hawaii' started by trdtacomahi, Oct 31, 2023.
  1. Oct 31, 2023 at 3:21 PM
    trdtacomahi
    trdtacomahi [OP] 2018 trd off road 4x4
    Hawaii
    Currently being upgraded One @ a time
    Can someone reccoment a good portable air compressor i can keep in my truck
    Something that doesnt cost an arm and a leg
    Doesnt break the bank etc.
    But decent enough to do the job
  2. Nov 1, 2023 at 1:54 AM
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    pinktaco808 likes this.
  3. Nov 1, 2023 at 1:56 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Good
    Portable
    Cheap
    Pick two and live with your decision. :D
  4. Nov 1, 2023 at 1:59 AM
    Bubble Wrap
    Honolulu, HI
    2016 SR5 DCSB MGM
  5. Nov 1, 2023 at 7:06 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    I carry that compressor. (in my Jeep)
    I like it because one battery runs all of my cordless tools and this compressor. (Also has the lighter plug)
    So far it works good. (I've used it a few times and it's performed well)
    I also have the ARB Twin mounted in my Taco. (But that's really expensive)
  6. Nov 1, 2023 at 7:10 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I've had a Viair 450 for a while and it's been great. It does not have a cig lighter plug though, it needs to be clamped to battery posts. It fits nicely in the rear seat footwell.
  7. Nov 1, 2023 at 7:35 AM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    Define "the job". If you need something to keep around for once every few years when a stock size tire goes low/flat in the parking lot and dont mind waiting a while (10"+min) then any $30-$40 cigarette plug compressor will work fine. We keep an old craftsman one in the wifes camry and in my DD civic for that. If you're looking for something to air up 4 oversized tires when you get back to pavement...anything that plugs into a cigarette lighter will likely drive you nuts after it takes 2 hrs to get you back up to highway pressure, assuming it doesn't burst into flames in the process. You'll want something that draws enough power that it needs to clamp onto the battery posts for that. I bought a viair 300p for the latter situation back in 2020 for $147 and its "on sale" now for $180. It probably takes 10-15min to take all 4 33" tires on 16" rims from 20 to 40 and that includes setup and teardown time.
    https://www.amazon.com/dp/B000X90YUO
  8. Nov 1, 2023 at 7:46 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I ran a Lowes special for years. It was a $35 stocking stuffer, and it still lives in the fiancee's car at the minute. It was great - dial in the desired pressure, press go, come back 5 or maybe 15 minutes later to do the next tire. Slow, but it was cheap and reliable.
    I'm currently running a Viair 88P for the Tacoma. Its every bit as light and portable and will fit in the rear seat cubbies. It will also inflate all four tires in a (reasonable) hurry when needed. They make bigger and faster units, but for occasional air downs, seasonal maintenance, and emergency use, the little 88P works wonders. 20 -> 32 psi in two minutes, which is lightning fast compared to the little cigarette lighter pumps. Plus, it won't overheat when you need to go from 0-32 psi.
    Good for trucks:
    Good for cars:
    Road_Warrior likes this.
  9. Nov 1, 2023 at 8:09 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Viair 300P... works for tires up to 33". :thumbsup:
  10. Dec 5, 2023 at 8:30 PM
    808BOGEYMAN
    808BOGEYMAN Member
    Dino
    98 4x4 limited xtra cab 3.4
    Napa 300LPM Air compressor (formerly was MaxiTrac300LPM) is on sale this month at napaonline.com for $125. It was out of stock for over a year. It got some really good reviews for being strong, fast, and at a good price. I just picked one up for myself today.
    If you have the time check out Project Farm on YouTube and his reviews on tire inflators
