Portable AC installation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GarthVader03, Jul 1, 2024.
  1. Jul 1, 2024 at 2:38 PM
    GarthVader03
    GarthVader03 [OP] Member
    2021 SR 2WD 2.7L ACCESS CAB
    None yet
    Here's the issue. I need AC pretty much year round in my truck for 12 hours a day while at work. I don't want to idle for that much as I've had another truck eat a lifter from excess idling. I've seen other guys in full size trucks use a portable stand up AC unit like this https://www.amazon.com/dp/B01DLPUWL2 and vent the exhaust through the cab vents on the back of the cab. I however have a 2021 Tacoma Access Cab SR (no back seat or speakers). My question is how hard is it to remove the cover on the back wall of the cab? Has any done something similar? Have photos of setup? Tips and tricks to pass along?
  2. Jul 1, 2024 at 2:44 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    How are you going to power this? Is there always a power outlet where you park?
    3rd gen Tacoma's have a sliding back window. If using this type of AC unit you'd most likely want to make a custom insert that covers the window opening and has 2 holes for the AC intake and supply hoses.
  3. Jul 1, 2024 at 3:06 PM
    GarthVader03
    None yet
    No sliding back glass though
  4. Jul 1, 2024 at 3:12 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    What are u doing for power supply if running off the truck . It won’t push this voltage with the truck in accessory mode don’t think it will do it with it on either . .
  5. Jul 1, 2024 at 3:27 PM
    GarthVader03
    None yet
    Generator on site
    Mallcrawler20[QUOTED] likes this.
  6. Jul 1, 2024 at 3:34 PM
    Gen3TacomaOBX
    S
    Make a small custom insert that will fit the passenger window for the intake and supply piping.
    YF_Ryan likes this.
  7. Jul 1, 2024 at 4:05 PM
    GarthVader03
    None yet
    Hoping to make something I don't have to put up and take down everyday to drive unless necessary
  8. Jul 1, 2024 at 4:08 PM
    Gen3TacomaOBX
    S
    If it's designed/created properly it could be simple to roll down a window and insert. Your other options involve large holes in the cab which will impact resale and may not be any more convenient.
  9. Jul 1, 2024 at 4:51 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I gotta ask; why does the cab of your truck need to be kept cool while you are at work?
    Just curious, sounds interesting :D
    As far as exhausting the heat, maybe make a composite window insert that can be popped in and out.
  10. Jul 1, 2024 at 4:57 PM
    GarthVader03
    None yet
    I'm in the oilfield out of 12 hours on site I'm sitting in it for 10 on average.
    Chew[QUOTED] likes this.
