Port vs direct injection on Tacomas.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExGunner, Nov 11, 2023.
  1. Nov 13, 2023 at 3:40 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    I where In this entire article does it mention anything about “self cleaning fuel injectors” or engine going into “cleaning mode” hmm….
  2. Nov 13, 2023 at 3:59 PM
    ExGunner
    ExGunner [OP] Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    Thanks everyone. Great information and I got some reading to do. Would have checked in sooner but I'm on 24 hour shifts and finally got home.
    i don't think they are referring to self cleaning Injectors. BUT the port injection assists in cleaning the Intake valves and stopping carbon build up seen with strictly direct injected engines. One of the reasons Toyota put the port injection in these engines was for the "cleaning " properties of the port injection system.
  3. Nov 14, 2023 at 4:25 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    I hadn't read the entire thread before I posted the plot for the Tacoma before, but since there was some interesting discussion around 2GR-FKS variants, I thought I'd also post the (even less detailed) plot from the other Toyota/Lexus 2GR-FKS and the similar 7GR-FKS, which does show that at low speed/loads it can be either port or direct before switching to port and direct, and then finally direct only.
    Whether the Tacoma actually does that or not is probably up for debate, since the plot included in that document is more similar to the earlier 2GR-FSE plot.
    (Another interesting plot for the G16E-GTS D-4S system: )
    Jeff
    TacoTime55 likes this.
  4. Nov 14, 2023 at 4:31 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    What a thread!
    I just drive...with OTT Tune V9, Mild Drive/Spicy ECT.
  5. Nov 14, 2023 at 4:31 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Good info. I wish we could know when it actually switches. For example, let’s say I’m towing. I’m regeared which puts 5th gear @ 3200 rpm for 65 mph. That’s where I like to tow. That’s slightly past halfway up the rev range and that’s a decent load since I’m towing. Is it running the entire trip on the highway (4 hours recently) in DI only? Would be interesting to know more detail about what it chooses and when.
  6. Nov 14, 2023 at 4:33 PM
    Jeff Lange
    Calgary, Canada
    I'm sure one of the tuners like OV could probably provide some of that mapping, or you could log a few pulls at different ambient/engine temperatures and loads with TechStream and analyze the output. It's likely a complex surface though, especially if temperatures are not well controlled.
    Jeff
  7. Nov 14, 2023 at 4:36 PM
    BLtheP
    Plano, TX
    Yeah, I’ve got TS and VF and suppose I could log it someday. I only towed like that once ever (recently), but was just curious what it may have been doing for those 500 miles. I would imagine that it would still run the port injectors now and then to do the cleaning they’re designed to do, but who knows.
  8. Nov 14, 2023 at 4:48 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Tacoma variant does run Port only at low loads/rpms.
  9. Nov 14, 2023 at 4:49 PM
    Bishop84
    Bishop84 Well-Known Member
    I think the data list is misleading, it cant and doesnt run on port only.
  10. Nov 14, 2023 at 4:54 PM
    Vlady
    Issy, WA
    It does. Look at both injectors spray timing
