Port vs direct injection on Tacomas.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExGunner, Nov 11, 2023.
  1. Nov 11, 2023 at 7:24 PM
    ExGunner
    ExGunner [OP] Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    I know Tacomas use both types of injection systems on the Tacoma ( mines a 2017 TRD Sport) . What I was wondering , because I can’t seem to find a lot of information on this, is when specifically does the truck switch between the 2 systems? Is direct injection used when cruising with the Atkinson cycle and port used during acceleration ? Just trying to figure out when each is typically activated. Even a link to a document or paper describing this would be great.
  2. Nov 11, 2023 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Some engines run port and/or DI, the 2GR in tacoma does not. It cannot run port injection only by design.
    It runs DI 100% of the time, and port on warm up, during cycles at idle, and sometimes load.
    The idea is the keep the valves clean, which in turn keeps emissions consistent longer.
    They also raise combustion temps to warm up the catalytic converters faster without air pumps or egr.
    Ultimately the port injectors on tacoma is for emissions, it doesnt help with performance.
    I can't share toyota documents but hopefully someone can find the graph with DI+Port and DI only.
    G8R_Taco, b_r_o, RustyGreen and 3 others like this.
  3. Nov 11, 2023 at 7:40 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
  4. Nov 11, 2023 at 7:40 PM
    Bishop84
    The 2024 highlander switches, new tacoma may switch as well.
  5. Nov 11, 2023 at 7:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Page 104
    G8R_Taco, b_r_o and RustyGreen like this.
  6. Nov 11, 2023 at 7:45 PM
    Bishop84
    Holy moly did you find that fast, and what an obscure location lol.
    We reference that chart often when explaining operations.
    Techs ask why you cant switch all cylinders to port, only one at a time. I show this graph.
  7. Nov 11, 2023 at 7:52 PM
    Blak Shinobi
    taco
    n/a
    I wonder why on page 69 its says octane rating of 91 or higher:boom:
  8. Nov 11, 2023 at 7:54 PM
    Bishop84
    IS350 bruh
    It's the 2GR FKS data sheet, usually the first production of it gets the huge sheet.
    God damnit Im wrong.
    Look at the HP output.
    I'll leave this up to embarrass me.
    G8R_Taco, RustyGreen, joba27n and 4 others like this.
  9. Nov 11, 2023 at 7:57 PM
    Blak Shinobi
    taco
    n/a
    Its all good im sure someone knows , but nonetheless they share the same engine
    Bishop84[QUOTED] likes this.
  10. Nov 11, 2023 at 7:58 PM
    Bishop84
    I wish 91 octane unlocked 311hp and we could all love the 3rd gen unanimously.
  11. Nov 11, 2023 at 8:37 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Direct injection only mode starts when you reach above 70-75% of engine load . You can see it in 6th around 1700 rpms.direct injectors spray at 320°
    The rest, Either mode (direct injectors spray at 270°) and Port.
  12. Nov 11, 2023 at 8:43 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Is that 91 in the document maybe meant to be research? The owner’s manual says research octane 91, and 87 normal.
  13. Nov 11, 2023 at 8:47 PM
    TnShooter
    Deogee
    STOCK
    My guess is,
    It's there because the engine makes "the most" power with 91.
    A bigger "HP" number is better than a lower HP number.
    I am probably wrong. But it's an answer. :cool:
    joba27n likes this.
  14. Nov 11, 2023 at 8:50 PM
    BLtheP
    Plano, TX
    I could see it going either way. I definitely feel like mine makes more power on higher octane due to not retarding timing as much. But, considering sometimes they use the research number and not the normal number, it’s hard to say. 87 octane is 91 research octane, so I could see maybe the document meaning that.
    G8R_Taco likes this.
  15. Nov 11, 2023 at 8:57 PM
    TnShooter
    Deogee
    STOCK
    I have no idea.
    But not all 2GR-FKS engines are the same.
    It's in no less than 14 different vehicles.
    And each vehicle serves a different purpose.
    The car engine wont be tuned like a truck engine.
    Depending on the application, even the top RPM is different.
    I wouldn't be surprised if the cam profiles were different between applications.
  16. Nov 11, 2023 at 9:03 PM
    BLtheP
    Plano, TX
    Yeah, I understand all that and the Tacoma version is very differently tuned from the rest of them. Maybe for longevity while doing truck type of work? I don’t know.
    I do know that @Jeff Lange has detailed out the parts before and from what I remember, the Tacoma version was mostly only different on the block itself, and not much else. IIRC the cams, crank, valves, and some other parts (heads?) were all the same. The motor was almost called the 7GR since the block was much different than the other 2GRs. The Tacoma 2GR-FKS block is more similar to the 1GR-FE than it is the other 2GR-FKS’s. It has a different bellhousing and different strengthening ribs than the other 2GR-FKS motors.
    TnShooter[QUOTED] likes this.
  17. Nov 11, 2023 at 9:06 PM
    TnShooter
    Deogee
    STOCK
    I didn't know all that, I know more about the 4.0.
    And at that, I don't know much.
  18. Nov 11, 2023 at 9:07 PM
    Vlady
    Issy, WA
    It is the same part number for 300+hp Camry and Tacoma. Its all about ithe intake and tuning
    G8R_Taco and TnShooter[QUOTED] like this.
  19. Nov 11, 2023 at 9:14 PM
    TnShooter
    Deogee
    STOCK
    Seems like it. A quick search (not a thorough search by any means) shows this.
    https://www.tacomaworld.com/threads/redline-2gr-fks-tacoma-vs-highlander.742935/#post-26450219
    To be honest, I out grew "HP number days" years ago.
    I'm more of a "As long as it gets the job done" type of a guy these days.
    More than likely my next truck won't be a Tacoma. I find the extra power and capabilities of a full size truck better for towing my trailer.
    My Tacoma is getting the job done, and I plan to keep until it "dies". But I tow more now than I did back when I bought my truck. When the Tacoma dies, I'll look at a Tundra or an F-Series.
    ExGunner[OP] likes this.
  20. Nov 13, 2023 at 12:44 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Not extremely quantitative, but...
    Jeff
