Port and polish intake manifold, throttle body.
Discussion in 'Performance and Tuning' started by lmur, Apr 17, 2013.
  1. Apr 17, 2013 at 3:25 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    URD intake, Doug Thorley Y, TRD catback, Ported polished Intake manifolds and Throttle Body, Unichip, 3" spacer lift.
    I pulled off my stock lower intake manifold last week and gave it a look over to see if a port and polish job would be something worth while. There were definitely some imperfections in the lower manifold as well as upper manifold and throttle body. I decided to do a slight port and polish job on all three. There is definitely a difference in throttle response, and acceleration. I swear it sounds different too. I attached some before and after pics. How many of you have done this??
  2. Apr 17, 2013 at 4:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have done this as well. You did a very good job BTW.
    On the '09+ the lower plenum comes from the factory with the casting imperfections smoothed out. Just not on the prior models. :/
    The throttle body.....I have not messed with.
    There was a guy who was building his 1GR for some form of off road racing, and he did flow bench tests of before and after a porting as well as welding the two halves together in the runners. Picked up quite a good deal of flow.
  3. Apr 17, 2013 at 7:25 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    Thank you! Looks like you have an incredible amount of work done to your truck. Very impressive.
    I was curious about welding that gap in where the manifold comes together, but I figured on a N/A motor it probably wasn't all that necessary?
  4. Apr 18, 2013 at 8:44 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    P.S.
    If anyone is interested in having this done, I am a machinist and would love to tackle the job for you. PM me for info. Thanks!
  5. Apr 18, 2013 at 9:16 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Any photos of the throttle body?
    I worked mine a few years ago.
    Did you pull the throttle plate and shaft or work around it?
    Torspeed, by your comments, are you saying the newer trucks don't really need blending like the op did. I have not done mine yet, 2010, is it worth the effort?
    PK
  6. Apr 19, 2013 at 4:56 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    I can post some photos of the throttle body. The only thing I did was blend in the little ridge before the throttle plate and polish it very smooth. If you open up the diameter near the throttle plate too much, this will negatively effect idle and RPMs, causing weird shifts if automatic, unless you put in a larger throttle plate.
  7. Apr 19, 2013 at 5:04 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Just cleaning out all of the carbon build up and oil/dirt residue makes it flow better! Port/polish adds some extra:)
  8. Apr 19, 2013 at 8:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You can pull off the upper plenum and take a look at the runners in the lower plenum. It should be smoothed out by the factory.
    As for the TB.
    http://www.xr-underground.com/forum/showthread.php?p=909969#post909969
  9. Apr 19, 2013 at 2:59 PM
    PMK
    Florida
    10 DCLB TRD Sport
  10. Apr 19, 2013 at 3:01 PM
    PMK
    Florida
    10 DCLB TRD Sport
    Sounds pretty much like how I did mine a while back. Yes I should clean the manifold and TB, then install a catch can.
    PK
  11. Apr 19, 2013 at 3:02 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    I just did this but used Extrude hone with the whole intake track, the plastic upper was a pain but worked, does make a difference.;)
  12. Apr 20, 2013 at 5:10 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Extrude hone, a company I have not heard about in a long time.
    They always stated it was best to accomplish major blending by hand, then Extrude Hone after that.
    Is this how you did yours?
    PK
  13. Apr 21, 2013 at 1:04 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    Yes, if your going to perform a port polish job or even just clean it all out I would definitely recommend an oil catch can, its a very easy thing to install and will make it so you have to clean the intake system much less often, if ever. When you see how filthy it is when you take everything off, you wont want to have to clean it again;)
    Thanks everyone for the input, glad to be able to discuss with some cool people. My other car is an IS300 and the Lexus forum I am on carries a different attitude towards new people.
    Again, if any one wants this done that does not have the tools, experience, or time to mess with something like this, feel free to PM me for info. Performing this for a couple people right now locally and they will be posting reviews soon hopefully.
    RA77 likes this.
  14. Apr 21, 2013 at 2:00 AM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
  15. Apr 24, 2013 at 11:44 AM
    lmur
    lmur [OP] Member
    Utah
    06 Tacoma Trd Sport
    One of the local guys I am performing the lower, upper, and throttle body job for has agreed to do some before and after dynos the weekend of the 17th in May. Excited to see some data. Stay tuned:)
  16. Apr 24, 2013 at 11:45 AM
    SoCaltaco65
    whos they?
  17. Apr 24, 2013 at 11:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good deal!
  18. Apr 24, 2013 at 2:06 PM
    PMK
    Florida
    10 DCLB TRD Sport
    Magazine tests with engine builders. Before, after extrude hone, ported, then extrude hone over porting.
    Extrude Hone would blend and smooth but not change profiles or blend large defects.
    The port grinder would blend and work for better flow by removing problem areas, then Extrude Hone would provide a more optimum finish and smoothing.
    Both have their place, but combined always seemed best, but more work.
    PK
  19. Jun 8, 2013 at 7:37 AM
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    I have a lower being worked on now and I am sending a spare upper plenum for my V-6. Once done I am sending the lower out to Swaintech to have it coated with a thermal barrier coating. Should be a nice change.
  20. Jun 8, 2013 at 8:51 AM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Where you at in North Texas? Keep us updated with pics I might want this done as well. The thermal coating would be different on the plastic intake but a great idea!
