POR-15 to kill rust, then Fluid film process questions...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Oct 15, 2018.
  1. Oct 15, 2018 at 5:42 PM
    pearing
    pearing [OP] Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    So it seems POR-15 is the rust neutralizer of choice to save your frame (or 3 years and a trade in...) followed by fluid film. However, if I have this right you must rinse the POR-15 with water before treating with another product; but, doesn't that defeat the purpose? Water expedites the oxidation process (rust), so why? Doesn't make sense. Can you put the fluid film over the un rinsed POR-15? Does POR-15 cause problems if it isn't rinsed; like, rust? I want to do this right and I think you must kill the rust then cover the bare metal-but water makes me nervous. Anyone have experience and results to post up???
    Thanks in advance
    Pat
  2. Oct 15, 2018 at 6:13 PM
    4wheelslacker
    4wheelslacker Slacker by trade
    East Tenn
    2010 Taco crew shortbed
    2017 Trd struts,2018 Trd wheels,bakflip2 bed cover,ungraded sound system
    Interesting you brought this up today.l bought some POR-15 recently and had another use in mind.Be interesting to know more about it
  3. Oct 16, 2018 at 3:54 AM
    craigs1
    craigs1 Well-Known Member
    2007 4Runner Limited, 4.0L
    It's a solution of phosphoric acid, and the water is needed to neutralize and flush it away. Just blow the surface dry with a compressor, canned air, or a drive down the highway. Then paint it before applying Fluid Film. If you don't paint it, you're wasting your effort.
    4wheelslacker likes this.
  4. Oct 16, 2018 at 4:58 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    How bad is your frame?
    POR15 gets just as many bad reviews as it does good if you search around.
    Having used it before, I personally don’t think slapping it on a frame and calling it good is the right choice. My opinion is wire wheel the loose crap or if you have a compressor, buy a needle scaler to make your life easy. Get rid of all loose rust basically, then paint with your choice of black spray paint. Optionally you can use a phosphate rust converter between rust removal and paint. After you’ve let that cure for a week or so, come back and hit it with your fluid film/rust preventative coat of choice.
    POR15 will make you feel good inside because it looks good. But it has a habit of peeling off if the prep wasn’t quite right or other whatever else.
    I’ve used it on a set of wheels and it worked great. But it isn’t my choice for frame work.
    2002Tacoma4x4 and craigs1 like this.
  5. Oct 16, 2018 at 5:58 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Rust is not a living organism so you can’t kill it.
    You need to remove rust. You can’t spray a chemical on a surface and it removes all the rust. Unfortunately it doesn’t work that way.
  6. Oct 16, 2018 at 8:48 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
  7. Oct 16, 2018 at 6:46 PM
    crx7
    crx7 1997 FZJ80 Triple Locked
    Grand Junction Colorado
    1) you shouldn't attempt to remove the rust when using POR 15 as it flows into the rust and this is why it is so thin when applying. The porous rust is how it adheres well to the metal.
    2) on not rusty smooth areas, it doesn't stick that well, so if your frame isn't rusted then this isn't the best solution for you. for rusty frames it works very well.
  8. Oct 17, 2018 at 7:16 AM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    Well.. in the bodyshop world, we use a product call Prep-All... its a hydrocarbon solvent cleaner that leaves very little residue. Yes, you can use acetone but it's a little hot or aka " evaporates fast " Water wouldn't hurt the coating but anything around, technically, can start re-oxidizing or rusting. It's really no biggie and it's something a 3M Maroon scotch brite pad can't take care of.
    I put the POR 15 on some fresh welds without a top coat and minimal prep. ( acetone flood/ wipe down ) to see the coating's degradation rate and so far, I have yet to see the coating chalk or leach its pigments NOR have I seen rust break through. It's been over a year now.... The nice part of POR 15 is that it's very "oil" and tends to get into places that are hard to reach.
    TacoTuesday!! and 4wheelslacker like this.
  9. Oct 21, 2018 at 9:19 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I just got around to painting some of my passenger side frame with POR15 the other day. My truck has some welded on sliders and on the passenger side, it was never treated with anything so the welded areas were rusting. So I cleaned it up with a wire brush and did the factory welds as well and painted the outer frame section. I still want to do the inner frame, but the weather is probably too cold at this point for the POR15 to cure properly so that might need to wait until next year. I've used POR15 on several cars/trucks in the past with no problems.
    2002Tacoma4x4 likes this.
  10. Oct 22, 2018 at 8:04 AM
    Thebubble
    Southern California
    2006 GX470
    You'll be fine, POR-15 cures in the presence of humidity. It will dry faster in a garage while it rains vs. in a garage that's arid.
    Don't forget - this coating isn't UV stable which means it'll chalk in direct sun light... if you want to fully seal it, i'd go with an industrial coating but beware of it's high build coating thickness.... I've used Sherwin Williams' Sherloxane or PPG's PSX800-700 series polysiloxane coating...
  11. Oct 22, 2018 at 8:15 AM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    Master Series is another similar coating worth looking into. I used this on my last first gen with good success
