Popping sound after new ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Mar 23, 2016.
  1. Mar 23, 2016 at 10:50 AM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    last weekend I installed new upper and lower OEM ball joints. Now I'm noticing a popping sound from what sounds like the drivers side wheel area.
    In addition I also installed new inner and outter tie rods and OME 881/nitrochargers. An alignment has been done too.
    Any ideas?
  2. Mar 23, 2016 at 11:10 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Bad Ball joint out of the box?
  3. Mar 23, 2016 at 11:51 AM
    Trapperr
    Reno, NV
    Perhaps? To be more specific I hear it as you first start into a left turn such as taking off from s stop sign. I hear it on flat ground as much as I hear it pulling into a drive or turning as you go over a speed bump at low speed.
  4. Mar 23, 2016 at 12:11 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Jack up the front and leave the key turned and move the wheels back and forth. Only way to be sure.
  5. Mar 23, 2016 at 1:18 PM
    Trapperr
    Reno, NV
    I'll do that in a few hours when I get home. Thanks for the suggestion!
  6. Mar 23, 2016 at 1:56 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    *jack up the front by jacking up under the lower control arm!
    this will relieve all tension from the spring and allow you to easily move the wheel/knuckle to see if there is any play in the balljoints, upper control arm bushings or any other part that can potentially allow play.
    youll need to keep an eye on the lower control arm bushings to see if there's any play at the chassis while your lifting the truck. youll also want to lift the truck by the frame when inspecting the lower control arm bushings.
    Fenwick1993 likes this.
  7. Mar 23, 2016 at 2:00 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Did you loosen anything else?
    The lower control arm cam bolts? If you had an alignment done they may not have tightened them up enough. I've been through that before. And it's my best guess.
    Also how about the sway bar? Check the nuts and the rubber mounts to the frame.
  8. Mar 23, 2016 at 4:40 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I would sorta expect it to be something with the new coils and nitros vrs the LBJ's...idk though???
  9. Mar 23, 2016 at 4:45 PM
    pudge151
    Sean
    Connecticut
    Low control arm cam bolts. Torque them down. I bet it fixes it
  10. Mar 23, 2016 at 5:23 PM
    bry838
    oregon
    Pudge is right. I have read about that a couple of times atleast. Them suckers need to be torqued more than a guy thinks and since shops rarely use a torque wrench there is a good chance they are loose enough to cause that pop you're getting...
  11. Mar 24, 2016 at 7:42 AM
    Trapperr
    Reno, NV
    Thanks for the suggestion guys. Dumb question, are those the bolts on the front of the vehicle with the markings? Or are they the long bolts that secure the control arm to the vehicle? This won't tamper with the alighnment I'm assuming.
  12. Mar 24, 2016 at 7:47 AM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    I'd start with re-torquing everything just to make sure nothing is loose. Then focus on the sway bar, and the coils. Something is probably touching somewhere. I had the same issue and re-torquing and getting rid of the sway bar fixed it. (just don't know which was the issue)
  13. Mar 24, 2016 at 8:39 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    this will relieve all tension from the spring and allow you to easily move the wheel/knuckle to see if there is any play in the balljoints, upper control arm bushings or any other part that can potentially allow play.<<
    1. I can't visualize it right now, but I would think that since the bottom of the spring presses against the top of the LCA, and the top of the spring presses against the frame, that raising the truck by jacking up the LCA does not relieve any tension caused by the spring. The force is transmitted from the jack to the LCA to the spring and then to the frame.
    2. I agree with checking the sway bar mount bushings. I had a very soft "bump" at low speeds when I made left turns in my truck. It was fixed by putting grease on the rubber bushings. (I later replaced them.)
  14. Mar 24, 2016 at 10:53 AM
    pudge151
    Sean
    Connecticut
    Yes the bolts with the cams with the markings. 100 ft lbs I believe
  15. Mar 25, 2016 at 2:12 PM
    Trapperr
    Reno, NV
    I got the front end up on jacks. No play at 6 and 12 but noticeable play at 9 and 3. I shook the tire while laying and looking underneath. It appears my rack has 1/8-1/4" movement left to right when I shake the tire. Is that normal for the rack to move a little?
  16. Mar 25, 2016 at 5:05 PM
    CodeSeven
    Serge.
    Coachella Valley
    see video for visualization. this vehicle has torsion bars, but none the less, the force is still on the lower control arm just the same.
    Jnelsen likes this.
  17. Mar 25, 2016 at 6:12 PM
    Trapperr
    Reno, NV
    That makes perfect sense once you see it
  18. Mar 26, 2016 at 3:09 PM
    Trapperr
    Reno, NV
    So I'm going to check the torque on the cam bolts. Which below am I tightening to 100ft/lbs?
    pudge151 likes this.
  19. Mar 26, 2016 at 3:21 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Your problem is the rack bushings. Their cheap and fairly easy to replace. Replace them with poly bushings
  20. Mar 26, 2016 at 3:24 PM
    Trapperr
    Reno, NV
    I'll order a set of those bushing and hope that cures my pop
