Popping noise when accelerating.
Discussion in '1st Gen. Tacomas (1995-2004)' started by HoldTheMayo, Nov 15, 2018.
  1. Nov 15, 2018 at 12:01 PM
    HoldTheMayo
    HoldTheMayo [OP] Active Member
    I haven't been able to get it on video (yet) but if I had to take a guess it sounds like I have a suspension issue. The pop happens when I accelerate. It's about 2-3 popping sounds.
    I don't know where to look or what to really look for.
    Has anyone else experienced this?
  2. Nov 15, 2018 at 12:49 PM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Does it sound like its coming from the rear or the front ?
  3. Nov 15, 2018 at 12:50 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Anti lag bro
    E30325 likes this.
  4. Nov 15, 2018 at 1:22 PM
    HoldTheMayo
    It sounds like it's coming from the rear.
  5. Nov 15, 2018 at 1:25 PM
    Fatal_Paradox
    Bardstown, KY
    Does the popping increase or decrease depending on how hard you accelerate?
  6. Nov 15, 2018 at 1:32 PM
    HoldTheMayo
    I haven't really tried that. I baby it. I'll stomp on it on the way home and get back to ya. :)
  7. Nov 16, 2018 at 7:10 AM
    HoldTheMayo
    It doesn't get louder. It does pop faster.
  8. Nov 16, 2018 at 7:14 AM
    02hilux
    Planet: EARTH
    Check your ubolt, front leaf spring bolt and shackle, inspect leaf spring bushing, and shock nut and bushing
  9. Nov 18, 2018 at 8:56 PM
    1997tacomav6
    Denver
    If it’s a single type click noise it could be the drive shaft slip joint
  10. Nov 27, 2018 at 6:34 AM
    Fatal_Paradox
    Bardstown, KY
    @HoldTheMayo did you ever figure out where your noise was coming from ?
  11. Nov 27, 2018 at 6:54 AM
    HoldTheMayo
    I got under the truck and the suspension is gtg. I shook everything I could think of on the suspension and no sounds.
    I check the drive shaft and it looked good as well.
    I just happen to notice while changing out my drums that the exhaust was rubbing on the mud flap.
    I put on new exhaust and rubber hangers and they settled it into the flap.
    Cut here, smooth there and no more popping noise.
    Thanks for all the help and suggestions!
