Popping noise in suspension even after changing ball joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ironhead93, Jun 20, 2020.
  1. Jun 20, 2020 at 3:13 PM
    Ironhead93
    Ironhead93 [OP] New Member
    Ross
    06 Tacoma base 4wd
    I have a 2006 Tacoma and I just changed my ball joints along with tie rod outers. I’m still having the popping noise along with a new one and that’s like a stress crackling noise. I guess that’s a good way to put it. When I turn and stop is when I hear it most. Any Information will help out. Thanks in advance.
  2. Jun 20, 2020 at 3:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the lower control arm bolts.
    They come loose sometimes.
  3. Jun 20, 2020 at 3:21 PM
    Ironhead93
    Ross
    06 Tacoma base 4wd
    While I was under there I made sure everything was tightened because it has happened before. I’ll double check everything again. Thanks.
    TnShooter likes this.
  4. Jun 20, 2020 at 3:26 PM
    TnShooter
    Deogee
    STOCK
    I think the TQ Spec is 100 Ft/Lb
    You can check the TQ Spec Guide and see.
    It’s on the top of the forum. On the sticky section.
    Bikinaz and Ironhead93[OP] like this.
  5. Jun 20, 2020 at 8:00 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Also that torque should be set with the truck on the ground supporting its own weight.
    whatstcp and TnShooter[QUOTED] like this.
  6. Jun 21, 2020 at 6:42 AM
    mx07gt
    mx07gt Well-Known Member
    lower control arms did it for me. They were not torque'd to spec. After torquing, all good. GL
  7. Jun 21, 2020 at 8:50 AM
    rednext
    rednext Well-Known Member
    How many miles? My ride is at 226k and has been doing it for 5 or 10k, finally just figured out it was the lower control arm bushings causing it.
    Kolter45 likes this.
  8. Jun 21, 2020 at 9:10 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
