Popping Noise in Steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, Apr 14, 2009.
  1. Apr 14, 2009 at 9:35 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    Hello all, I need some help with a noise I am hearing. When I am driving straight I can't hear anything, but when I turn my steering wheel to make a cut or turn onto a road.... I can' hera anything, but when I release the wheel to come back straight... I can hear a popping noise... it sounds almost like a plastic popping noise. Any ideas?
  2. Apr 14, 2009 at 10:43 PM
    calicoupe
    calicoupe Well-Known Member
    I have the same problem as described. bump
  3. Apr 15, 2009 at 8:24 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    when did you start noticing yours?
  4. Apr 15, 2009 at 8:28 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Is it when your blinker turns off after you turn?
  5. Apr 15, 2009 at 8:29 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    No, it is when i make any type of left cut with my wheel... it is like a grinding noise more than a popping
  6. Apr 15, 2009 at 8:31 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Where does it sound like its coming from? Is it a loud popping, or is there a creak/squeal and then the pop? If you're lifted and it sounds like a 'creak'/'squeal' and then a 'pop' it may be your sway bar binding.
  7. Apr 15, 2009 at 8:32 PM
    Lentsnh
    hmmm and It feels like its coming from the steering? like the wheels and tires?
  8. Apr 15, 2009 at 8:33 PM
    Lentsnh
    X2 Thats what It sounds like now that you mention it, Eric
  9. Apr 15, 2009 at 8:35 PM
    jabrackin
    Knoxville, TN
    2008 TRD OffRoad
    I don't have a lift in my truck... I have a 2008 toyota tacoma double cab.... it sounds like a grinding noise when i turn my wheel to the left and i realease it then makes the grinding noise.
  10. Apr 15, 2009 at 9:05 PM
    RelentlessFab
    Eric
    Sparks, NV
    If its at factory height, and under warranty then take it to your dealer and take one of the guys for a test drive. They'll be able to figure it out and fix whatever's causing it. I wouldnt mess with it if its stock and under warranty- thats what it's for.
