Pop up slide in Camper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvparadise, May 3, 2020.
  1. May 3, 2020 at 4:26 PM
    mvparadise
    mvparadise [OP] Well-Known Member
    2013 Toyota Crew cab 4x4
    Anyone have a set up with a pop up truck camper. What size fits best and weight? Did you have to do anything to back shocks.
  2. May 3, 2020 at 5:54 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I don't have one but have done a bit of research. Very few companies make one for out trucks, and even fewer "recommend" them as they often very much overload the truck.
    The best is probably 4 Wheel Campers. And I honestly don't know of any other company currently making ones for our trucks. SixPac used to make one that fit, as well as Lance but I can't recall the models.
    Then there are the wedge camper style, like the ones that Go Fast Campers and Vagabond Outdoors makes. These don't have the sealed camper advantage, but are much lighter and more versatile.
    Then there are the old school flip over types like the flip-pac. There were a few other companies that made them, but they are old and hard to find nowadays.
    As far as dealing with the weight, yes you will have to upgrade your leaf springs or install airbags or both. This is highly dependent on how heavy your camper is and how much lift you want when it is loaded.
    tacoma_ca and mvparadise[OP] like this.
  3. May 3, 2020 at 6:06 PM
    JoosBox
    JoosBox Well-Known Member
    Pat
    Boise, ID
    2007 TRD OR
    Not super relevant but I’ll bet you’d be interested:
    https://youtu.be/N-B1bArm3rk
    I’m in love with his setup and if I had the $$$ I’d be going for something like this
    Edit: they’re called GoFastCampers. They have a website
    Skyway and mvparadise[OP] like this.
  4. May 15, 2020 at 5:41 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    @mvparadise
    I had a 2008 FWC eagle and lived out of it for two years.
    Toms2Yotas, 69L46Vert, Skyway and 2 others like this.
  5. May 15, 2020 at 7:43 PM
    mvparadise
    Nice.....
  6. May 15, 2020 at 8:58 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
  7. May 16, 2020 at 6:59 AM
    Jims85
    Jims85 Member
    Jim
    Milwaukie, Oregon
    85 Truck
    Lots
    I have a 4 Wheel Fleet camper for my 2010. I did the Boise Spring Works spring kit for the Tacoma. I also run E-rated tires. The camper rides fine, but I could use more horse power to put it mildly. I have the 2.7 liter 4 cylinder engine and 5 speed manual transmission. The camper weighs about 1200 lbs lightly loaded for a trip.
